2007 cg125 drinks oil
xz130
PostPosted: 18:21 - 13 Mar 2013    Post subject: 2007 cg125 drinks oil Reply with quote
My cg seems to be drinking a lot of oil what could cause this and what can I do to fix it Question Question Question Question
2 litre
PostPosted: 18:30 - 13 Mar 2013    Post subject: Reply with quote
Any smoke out of the exhaust ?
xz130
PostPosted: 18:34 - 13 Mar 2013    Post subject: Reply with quote
Nope no smoke out the exhaust
kramdra
PostPosted: 19:23 - 13 Mar 2013    Post subject: Reply with quote
causes:
1) Its leaking out onto road. Clean engine, look for fresh leaks.
2) Its getting sucked through the breather into air intake. Have a look, see if engine oil is coating filter or throttle body.
3) getting past valve seals. Usually a very small amount.
4) piston rings. Being the most expensive - you can get new cylinder/piston kits for £70, or just new rings and a hone for less, or even another engine they go cheap on ebay sometimes.
4 usually only happens at high RPM or when starting from cold. Significant amoount will give clouds of smoke.
Keep her topped up and she will still run forever.
However, its still a shit bike. Pass your test, get a proper one Thumbs Up
The last post was made 13 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 38.74 Kb
