| Alpha-9 |
 Alpha-9 Super Spammer
| haroman666 |
 haroman666 World Chat Champion
| Alpha-9 |
 Posted: 15:56 - 12 Mar 2013 Post subject: |
Are you certain?
Pretty sure that's incorrect, I know what you mean though i've been having trouble finding the right stuff
I bought that one, it doesn't quite fit, unless there's a weird shaped strip under it
https://s21.postimage.org/t7imukc6v/IMG_20130312_00123.jpg ____________________ Fzr-600 1999 |
| haroman666 |
 Posted: 16:48 - 12 Mar 2013 Post subject: |
https://www.suzukicycles.org/GSX-R-series/GSX-R400.shtml
That's generally my source of info regarding the GSXR/Bandit 4's.
Your fairings look like the GK71f. I'd double check the year if I were you dude. It's possibly an 86, according to that link. Unless ofcourse you have some sort of GSXR Mongrel.
That does look rather funny though  ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| Speed |
 Speed Could Be A Chat Bot
| Blau Zedong |
 Blau Zedong Banned
| Alpha-9 |
 Posted: 18:39 - 12 Mar 2013 Post subject: |
I know I have, I looked at it and the holes and it looked like they'd line up so I took a chance on it, wasn't expensive, might give it away on the thread
Aha yes I came across this one browsing at work, i'm guessing it doesn't look like the picture
Ta for the link  ____________________ Fzr-600 1999 |
| Alpha-9 |
 Posted: 13:44 - 13 Mar 2013 Post subject: |
Dropped them an email, was assured it'd fit, seems legit
Changed all the plugs yesterday, the one in cylinder 3 REALLY wanted to be cross threaded so I learned from my mistakes and instead of raging at it I removed the radiator pipe and made some more space and sat on the bike so it was upright and tried again, got it in straight now seemingly
First signs of life in the thing after some easy start and a battery charge, and boy-o-boy it sounds nice
Not got it idling yet though, hmm ____________________ Fzr-600 1999 |
| haroman666 |
| Alpha-9 |
| haroman666 |
| Alpha-9 |
| Alpha-9 |
 Posted: 10:53 - 14 Mar 2013 Post subject: |
Hey haroman
As it's duel carbs to balance it do I only need 2 balancers? As I was going to buy a set of 4 which is twice the price for ease of use
As I noticed there is a flat head screw on each one that just comes out and is just a hole, which is I think where you put the balancing thing
I need some newb help
https://s10.postimage.org/5w7b37wfd/asdfasdf.jpg
So I could take those bowls off and clean out the insides and I should be gravy?
Seems easy
https://img216.imageshack.us/img216/9889/airboxside9id.jpg
Whats the nob thing I? Seems to tighten up the throttle or something?
The sticky out things at the bottom, they the mix screws? ____________________ Fzr-600 1999 |
| P.addy |
 P.addy Red Rocket
 Posted: 10:57 - 14 Mar 2013 Post subject: |
Knob is idle adjust. Big circled jets are main jets.
Long skinny one, I do not know...  |
| haroman666 |
 Posted: 12:08 - 14 Mar 2013 Post subject: |
I'm doing all this from memory so bear with me.
I cant tell, from the pictures, whether you have 2 or 4 balancing ports. My advice is get 4, as in the future you may need 4. Although you can do anything with a 2 balancer, but it kinda makes it more long winded as you have to take it off and put it on over and over again. A balancer obviously just uses rubber tubes that attach somewhere on the carb, normally near the top, so if it looks like a pipe attaches there, then that's probably it.
The black tops are caps for the "slide valves" to come out. You shouldn't need to take those off.
The float bowls are on the bottom. Take those off and you'll see the next picture.
The gold bits with the slot (big ones), are your main jets. These are what the fuel goes through from about 1/8th throttle onwards. Might be worth taking them out and blowing through them. There's no adjustment, they just screw up til just tight.
The long gold pin is, I think, is your starting circuit jet, which is basically what the choke cable actuates open and closed. Only adjustment for this is likely to be on the cable.
If it isn't it's your pilot jet which is what sucks up the fuel for idling. There's no adjustment to this fuel jet, it's all on the pilot screw, which meters the air that passes through the main body of the carb.
The gold hole next to the black screw is what your float valve pushes into, and this controls the level of fuel in the float bowl. By fuck don't let your float valve get stuck open. I got a bit of shit in one of mine once and it flooded the float bowl, which flooded the cylinder and hydro-locked the engine. I got away with it, but you can crack piston crowns and bend con-rods if you're not so lucky.
Float valve is part of the plastic float assembly and you'll see, if you push the float up and down, the valve that actuates. There's adjustment for this but I don't know it myself. It's normally around the 1mm mark but don't quote me on that.
Get yourself some carb cleaner/brake cleaner and just give everything a good spray through and wipe. Dont leave any shit in there, especially big bits
When you stick them back on the bike, you'll need to crank the engine over and over in order for the carbs to draw fuel from the tank and fill up the float bowls. Hopefully you have a battery charger
Cant remember if I posted this, but [url=I'm doing all this from memory so bear with me.]THIS[/url] tells you the basic theory behind these types of carb.
And as reluctant as I am to post it, cause I sound like a right knob, THIS is a video I made from when I took apart my carbs. It may be of help. It may not be. ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| Alpha-9 |
 Posted: 16:01 - 14 Mar 2013 Post subject: |
Awww yes, fucking aces again haroman, cheers for that gonna come in well handy
Have had a look at them today...
FUCKING CROSSHEAD SCREWS Y U SUCK SO MUCH?
Not worked out how to use my impact screwdriver properly
Need a better hammer...
Sprayed it all over with carb cleaner and in the intakes and took the top things off and sprayed down them, they have weird diaphragm things that seem to lift up when they fill, I assume some sort of overflow as there's a pipe coming out too, which was blocked before I blasted it
The carbs feel kinda loose, like I could just pull them off, can't actually see where they fix in, need a good day on it
Battery deaded for now, it wasn't happy about my starting attempts yesterday, back on charge now!
& Cheers Pads, thought so, seemed like a 'throttle' stop of sorts as it just stops it closing fully, handy easy idle adjustment
This is all a learning experience, these carbs seem like they'll be easy to sort as they're quite accessible other than the tank and airbox which i've gotten so very used to taking off now
Wasn't aware of the filling of the float bowls, I guess that means it needs a good amount of fuel i nit rather than the like, cup fulls i'm scavenging from the bikes
Can see the picture I posted is obviously the bottom not the top, silly me! ____________________ Fzr-600 1999 |
| haroman666 |
 Posted: 17:24 - 14 Mar 2013 Post subject: |
Yeah I have a few mangled screws on mine! They do go eventually though so persistance is key.
A guy on Banditforums replaced all of his carb screws with stainless stell allen key ones, so if you want to get really flashy and do a full-rebuild then that might be something to take into account.
Impact driver is just a case of, getting it seated in the screw, apply as much turning force as you can without it slipping, and then bash the end with a hammer.
The whole unit should push into the inlet rubbers and then maybe be tightened in with a jubilee clip or equivalent. Have a look between the carbs and engine and see what's there. If the wont budge easily, give it a spray with a bit of WD40 and then they tend to slide out nicely. Which means they also go back in easily (Giggity).
Just realised that first link for the carb theory has been completely potatoed by myself.
Here it is properly this time.
I knew nothing about carbs really until I reaad that link, and then pulled mine apart.
It all looks complicated as there's shit loads of little bits all in one place. But really, once you've sussed it, it all seems quite easy. ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| Blau Zedong |
 Blau Zedong Banned
 Posted: 18:10 - 14 Mar 2013 Post subject: |
Oh, the old Daihatsu Charade carb set up  ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
The last post was made 13 years, 209 days ago. Instead of replying here, would creating a new thread be more useful? |
