Nuts and bolts.
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 13:22 - 14 Mar 2013    Post subject: Reply with quote
Banjo bolts are more than likely to specialised for a standard company to stock.
Sandpaper should not be required for you bike, leave it alone.
I like that new nut.
PostPosted: 13:25 - 14 Mar 2013    Post subject: Reply with quote
Brake banjos and banjo bolts are automotive specific, so I'd go to a motorcycle shop and buy one if I were you.
There are normally two different thread pitches available, so check which one fits your calliper before buying.
PostPosted: 13:56 - 14 Mar 2013    Post subject: Reply with quote
Just order the specific bolts from a Daelim specific dealer.
DrDonnyBrago
PostPosted: 14:27 - 14 Mar 2013    Post subject: Reply with quote
Invest in a thread pitch gauge if you are going to be replacing bolts, they cost about £2. If a bolt/nut is the correct width but won screw on, the pitch isn't right.
Use a washer on the axle nut?
PostPosted: 14:55 - 14 Mar 2013    Post subject: Reply with quote
JiveBunny wrote:
it is a quality part Korean not Chinese.
You'll probably find its all chinese parts, assembled in dog eating land.
Timmeh
PostPosted: 15:48 - 14 Mar 2013    Post subject: Reply with quote
JiveBunny wrote:
Not one bit of corrosion ridden through the entire winter. Middle Finger
That's cos it's German, the metal in it is prolly stronger than the rest of your bike put together.
DrDonnyBrago
PostPosted: 15:51 - 14 Mar 2013    Post subject: Reply with quote
Ordered one. I don't think it is the correct width it drops right down the axle I have a washer yes.
The axle is Daelim quality unsure of the grade but it is a quality part Korean not Chinese.
Ah I get ya, I thought you meant the nut falls into a recess on the swingarm. If it slips over the threads and down the axle, it is definitely not the correct size.
The grade 8.8 thing I mentioned is a standard used to test bolts/nuts for strength. A cheap mild/stainless steel nut could strip and snap if torqued down hard enough for an axle, a grade 8.8+ will handle the tightness. I wouldn't worry about the axle, but it is worth buying a half decent nut.
The last post was made 13 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 76.22 Kb
