GT85 and WD40
trevor saxe-coburg-gotha
PostPosted: 12:54 - 15 Mar 2013    Post subject: GT85 and WD40 Reply with quote
I used to think there was no real difference between GT85 and WD40 lubricant sprays but I read (here on BCF, iirc) that the former doesn't perish rubbery and/or flexible plastic parts (carb boots etc.). If you use either of these do you have a preference for one over the other, and why? And can anyone please explain why one might be better if it gets on plastic / rubber parts? Cheers all.
DrDonnyBrago
PostPosted: 12:59 - 15 Mar 2013    Post subject: Reply with quote
Also, one isn't a lubricant spray.
Islander
PostPosted: 13:01 - 15 Mar 2013    Post subject: Reply with quote
This ^
WD40 = Water Dispersant not lubricant, not penetrating oil, just a means of dispersing water from where it isn't wanted.
Alpha-9
PostPosted: 13:05 - 15 Mar 2013    Post subject: Reply with quote
WD40 is good for electrics and cleaning when you have nothing else
Penetrating oil is the good stuff for stuck bolts etc I use PlusGas
Grease is good for bolts, I always grease bolts up before putting them back, I used ACF50 grease
Copper slip is useful too for brakes etc although I don't have any
Then a good chain lube for the chain or ACF50 for anti-rusting, although that's expensive
Can of matt black engine paint for sorting the exhaust rust
Got some easy start too
All the good sprays Cool
Fzr-600 1999
Speed
PostPosted: 13:26 - 15 Mar 2013    Post subject: Reply with quote
We use GT85 at work instead on WD40. GT85 will go on and dry itself leaving a teflon coating. WD40 will go on and remain wet which attracts the dust and crap.
Although you can make better flame throwers with WD40 Thumbs Up
LordShaftesbu...
PostPosted: 14:01 - 15 Mar 2013    Post subject: Reply with quote
GT85 Spray
Drives out moisture
Cleans and protects from rust and corrosion
Stops squeaks, loosens rusty parts and frees sticky mechanisms
Can't see the difference between this and WD40.
evoboy
PostPosted: 14:04 - 15 Mar 2013    Post subject: Reply with quote
LordShaftesbury wrote:
GT85 Spray
Drives out moisture
It smells better.
APT Motorcycles
PostPosted: 14:35 - 15 Mar 2013    Post subject: Reply with quote
Some truth in that. But the smell of WD40 has changed over the years - and back in the '80s it was much better.
Anyway, I think I read on bcf somewhere that GT85 was 'synthetic' and thus didn't perish rubbery bits. Quite what that actually means I dunno.
LordShaftesbu...
PostPosted: 14:41 - 15 Mar 2013    Post subject: Reply with quote
So I shouldn't be spraying WD40 willy nilly all over the place?
PostPosted: 14:56 - 15 Mar 2013    Post subject: Reply with quote
I dunno! That's sort of why I started the thread. Perhaps it's more a case of "strictly speaking, there are solvents in WD40 that aren't in GT85 which with prolonged use i.e. when sprayed repeatedly on certain types of polymer and blah can be a bit more knackering." So basically don't worry. *is confuzzled*
evoboy
PostPosted: 15:54 - 15 Mar 2013    Post subject: Reply with quote
It does seem to attract dirt, where GT85 doesnt.
APT Motorcycles
LordShaftesbu...
PostPosted: 15:56 - 15 Mar 2013    Post subject: Reply with quote
I've heard (here on BCF, iirc) that GT85 doesn't perish rubbery and/or flexible plastic parts (carb boots etc.). Not sure though.
PostPosted: 17:03 - 15 Mar 2013    Post subject: Reply with quote
Hate these chinese whispers. I stay out of it, at all times. One must, if one is to retain a shred of dignity and credibility. I urge you to do the same. Mr. Green
LordShaftesbu...
PostPosted: 19:20 - 15 Mar 2013    Post subject: Reply with quote
Vincent wrote:
I'd pick GT85 for cleaning electrics over WD40 all day but wouldn't use either as a penetrating fluid.
What would you use?
Alpha-9
PostPosted: 19:21 - 15 Mar 2013    Post subject: Reply with quote
I didn't know petrol rots rubber..
Then who's the genius who decided to make fuel lines out of rubber Rolling Eyes Razz
Fzr-600 1999
Islander
PostPosted: 19:22 - 15 Mar 2013    Post subject: Reply with quote
What would you use?
A penetrating oil. Plus Gas is a common brand but there are others. Thumbs Up
Islander
Depends on the type of rubber Wink Razz
c_dug
PostPosted: 19:41 - 15 Mar 2013    Post subject: Reply with quote
WD40 is good for stopping skiddies on the toilet bowl Thumbs Up
Islander
PostPosted: 20:00 - 15 Mar 2013    Post subject: Reply with quote
Teflon coating, that's what you want.
No. Not the wordy one. Laughing
keggyhander
PostPosted: 21:02 - 15 Mar 2013    Post subject: Reply with quote
If protecting electrics is your aim, then "White Grease" is what you need.
sidewinder
PostPosted: 21:26 - 15 Mar 2013    Post subject: Reply with quote
Gt 85 the best smell ever Very Happy
andyscooter
PostPosted: 22:53 - 15 Mar 2013    Post subject: Reply with quote
So gt85 isnt aftershave
It doesnt disovle as quick as wd
Imo
The last post was made 13 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 126.95 Kb
