What to use for ground anchor...
alan0259
PostPosted: 21:39 - 16 Mar 2013    Post subject: What to use for ground anchor... Reply with quote
Just about to build a shed, I'm looking for something made from hardened steel (like a U shape) that I can sink into concrete to put under my base.
I've had a look on eBay but can't find anything apart from ones made from mild steel.
I don't want to pay a lot as I don't need anything pretty, just solid steel.
Any ideas?
Cheers Thumbs Up
_mjs_
PostPosted: 21:47 - 16 Mar 2013    Post subject: Reply with quote
One o' these bastids.
https://www.bracketsandbolts.com/content/images/products/scaffold1_1.jpg
PostPosted: 22:09 - 16 Mar 2013    Post subject: Reply with quote
You don't want hardened steel.
Hardened steel is brittle and can shatter if hit with a hammer. It will be nearly as quick to cut if someone comes with power tools or a gas-axe.
What you want is a really BIG bit of mild steel.
Get a wide, U-shaped piece of steel pipe and set it into the concrete with the bottom of the U down and the top of the pipe flush with the surface of the concrete. Set two long bits of rebar into the concrete in an X-shape across the middle of the U.
Run your chain down through the U-bend.
yen_powell
PostPosted: 23:00 - 16 Mar 2013    Post subject: Reply with quote
I used an old Kryptonite U lock after the lock barrel seized up (it fell into the sea, long story).
I set it deep into a concrete shed base with just the top of the U shaped part sticking out vertically.
XT1200Z and a DR350 in bits
Slacker24seve...
PostPosted: 23:31 - 16 Mar 2013    Post subject: Reply with quote
I welded an enormous D-shackle shut and then sunk it into concrete with rebar. Cheap and simple.
Banger rallies are ace
FireStorm-X
PostPosted: 02:19 - 17 Mar 2013    Post subject: Reply with quote
I was lucky with making mine as I used some old 1/4in steel plate and some thick steel pipe cut down. 4 holes drilled through the steel plate, welded the pipe to the plate, painted it all up then bolted it to the floor Smile
Lexmoto Street 125 (sold) - Kawasaki ZR7S
Dazbo666
PostPosted: 03:38 - 17 Mar 2013    Post subject: Reply with quote
I've used old D-locks a couple of times in the past.
I had one concreted into a garage floor, and one was built in to a wall
Word of the day : DILLIGAF
alan0259
PostPosted: 10:14 - 17 Mar 2013    Post subject: Reply with quote
Thanks everyone, what about these? This guys local and it seems cheap and simple.
https://www.ebay.co.uk/itm/ROLL-BAR-ROLL-CAGE-MILD-STEEL-TUBE-BENDS-90-DEG-/290441737731?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439fad3603
PostPosted: 11:13 - 17 Mar 2013    Post subject: Reply with quote
I mentioned the U-bend thing because I've seen it done elsewhere and it doesn't stick up out of the floor.
The more I think about it, If you're in there at the concreting stage, a plastic U-bend like you'd use under a sink would be fine, as long as you remember to use the rebar set into the concrete across it. All you need is a tunnel under the rebar to put the chain through.
Then any potential thief would essentially have to lift or smash a large area of the concrete floor to get the chain off. Cutting into steel reinforced concrete is very difficult.
A bit of rebar mesh would be even better.
Killer Rat
PostPosted: 12:46 - 17 Mar 2013    Post subject: Reply with quote
An empty gas bottle concreted in.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
willis1337
PostPosted: 14:21 - 17 Mar 2013    Post subject: Reply with quote
https://www.yanchor.com/index.html
£60 but it seems good and worth putting in if you're doing a concrete base. Might even save you a bit of cash off your insurance.
Current bike: KTM SD1290GT
Previous bike: BMW K1300S
PostPosted: 14:44 - 17 Mar 2013    Post subject: Reply with quote
Use a Mooring Ring.
https://sheridanmarine.com/public/assets/images/shop/stock/1304204400/stainless-steel-mooring-ring--base-1306593340-l.jpg
Some long cap-head bolts with nuts to give the concrete something to hold onto. Concrete shrinks ever so slightly when curing.
I like mine so much I built my shed around it. Very Happy
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF0337-1.jpg
zapmole
PostPosted: 18:33 - 17 Mar 2013    Post subject: Reply with quote
https://i435.photobucket.com/albums/qq79/connieboobie/IMAG1625.jpg
2 bits of solid.metal from work I.just chopped them up and got it welded seemed cheaper and stronger than other ground anchors as its on block paving AMD bricks
Just an.idea
Honda CG 125 red 1991
Whosthedaddy
PostPosted: 20:36 - 17 Mar 2013    Post subject: Reply with quote
Waterbutt filled with concrete or the likes and chain around that?
manc33
PostPosted: 20:43 - 17 Mar 2013    Post subject: Reply with quote
im sure this wont help but if your looking for something to sink in the ground thats heavy and you can fill with concrete i could send the mother in law round Laughing
PostPosted: 20:55 - 17 Mar 2013    Post subject: Reply with quote
I could cut through that in about a minute with a normal hacksaw. Or one good hard smack with a hammer to break the welds.
I once made a bolt-down one something similar but I used a piece of 8mm thick 100mm box section and bolted it down to the ground and the side of the house using security bolts.
SQL
PostPosted: 21:08 - 17 Mar 2013    Post subject: Reply with quote
I use this
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_729605_langId_-1_categoryId_273911
Depleted
PostPosted: 21:13 - 17 Mar 2013    Post subject: Reply with quote
you could look for those giant chain links they used on old steam engine trains, only the jaws of life will be able to cut one of those bad boys apart.
sidewinder
PostPosted: 21:48 - 17 Mar 2013    Post subject: Reply with quote
I found 3 large links of chain of a crane so sank two of them in ground with part of the third link sticking out Thumbs Up
UnspeedySam
PostPosted: 22:22 - 17 Mar 2013    Post subject: Reply with quote
Mine were made by a friend. Bits of steel box section with holes drilled in them, then screwed into the concrete with expansion bolts.
Im-a-Ridah
PostPosted: 02:18 - 18 Mar 2013    Post subject: Reply with quote
It depends how determined you are to stop them. What you really want is quantity, and a range of complementary materials. Steel mesh reinforced concrete with steel bars through it, forming a large diameter u-shape, deep into a big slab of concrete floor is ideal. The bike quickly becomes the "weak point" however if they are willing to leave the wheels.
Beyond that a "shed" made from steel mesh and concrete with a steel/concrete door is going to be much more effective at stopping a bike thief. Bashing their way through 1ft or 2ft of that is going to take a while...
DottyDuck
PostPosted: 03:38 - 18 Mar 2013    Post subject: Reply with quote
https://www.google.co.uk/search?q=sold+secure+ground+anchor&hl=en&source=lnms&tbm=isch&sa=X&ei=Y31GUeCaOoGqOqfQgLgC&ved=0CAcQ_AUoAQ&biw=1138&bih=525#imgrc=1_O2XDKgCotYhM%3A%3B04IlJHda12ZXmM%3Bhttp%253A%252F%252Fimages.esellerpro.com%252F2189%252FI%252F121%252F85%252FOxford-Anchor-Force-Wall-Ground-Anchor-1.jpeg%3Bhttp%253A%252F%252Fwww.ebay.co.uk%252Fitm%252FOXFORD-ANCHOR-FORCE-MOTORCYCLE-SOLD-SECURE-WALL-GROUND-%252F400273534333%3B600%3B600
that is the one i have lol cost me about 50-60... cant remember as i bought it last year lol but it seems very solid!!! my bike is on the front of my drive.. and this anchor is put into the wall on front of my house.. as the drive as been done with "sets" so they could just lift up the brick things (not sure what they are called) so make sure what you are attaching it to can not be moved! could be a very costly mistake!
Yoyo This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
RyanTZR125
PostPosted: 09:45 - 18 Mar 2013    Post subject: Reply with quote
https://item.mobileweb.ebay.co.uk/viewitem?itemId=281056087727&index=4&nav=SEARCH&nid=95708605036
I use this bolted to the wall outside my house, along with a heavy duty chain and padlock
1980 Honda H100A, Cafe racer. (SOLD)
1998 Yamaha TZR 125 4HX.
1999 Yamaha R6 YZF
Cardinal
PostPosted: 22:25 - 18 Mar 2013    Post subject: Reply with quote
I'm looking at one of these.
https://www.barriersdirect.co.uk/barriers-and-bollards-c1118/hoop-barriers-c1012/knee-rail-or-perimeter-barrier-p930
The last post was made 13 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 128.89 Kb
