| alan0259 |
 alan0259 Nova Slayer
 Posted: 21:39 - 16 Mar 2013 Post subject: What to use for ground anchor... |
Just about to build a shed, I'm looking for something made from hardened steel (like a U shape) that I can sink into concrete to put under my base.
I've had a look on eBay but can't find anything apart from ones made from mild steel.
I don't want to pay a lot as I don't need anything pretty, just solid steel.
Any ideas?
Cheers  |
| _mjs_ |
 _mjs_ Could Be A Chat Bot
| stinkwheel |
 Posted: 22:09 - 16 Mar 2013 Post subject: |
You don't want hardened steel.
Hardened steel is brittle and can shatter if hit with a hammer. It will be nearly as quick to cut if someone comes with power tools or a gas-axe.
What you want is a really BIG bit of mild steel.
Get a wide, U-shaped piece of steel pipe and set it into the concrete with the bottom of the U down and the top of the pipe flush with the surface of the concrete. Set two long bits of rebar into the concrete in an X-shape across the middle of the U.
Run your chain down through the U-bend. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| yen_powell |
 yen_powell World Chat Champion
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 23:31 - 16 Mar 2013 Post subject: |
I welded an enormous D-shackle shut and then sunk it into concrete with rebar. Cheap and simple. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| FireStorm-X |
 FireStorm-X Nitrous Nuisance
 Posted: 02:19 - 17 Mar 2013 Post subject: |
I was lucky with making mine as I used some old 1/4in steel plate and some thick steel pipe cut down. 4 holes drilled through the steel plate, welded the pipe to the plate, painted it all up then bolted it to the floor  ____________________ Lexmoto Street 125 (sold) - Kawasaki ZR7S |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 03:38 - 17 Mar 2013 Post subject: |
I've used old D-locks a couple of times in the past.
I had one concreted into a garage floor, and one was built in to a wall ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| alan0259 |
 Posted: 10:14 - 17 Mar 2013 Post subject: |
| stinkwheel |
 Posted: 11:13 - 17 Mar 2013 Post subject: |
I mentioned the U-bend thing because I've seen it done elsewhere and it doesn't stick up out of the floor.
The more I think about it, If you're in there at the concreting stage, a plastic U-bend like you'd use under a sink would be fine, as long as you remember to use the rebar set into the concrete across it. All you need is a tunnel under the rebar to put the chain through.
Then any potential thief would essentially have to lift or smash a large area of the concrete floor to get the chain off. Cutting into steel reinforced concrete is very difficult.
A bit of rebar mesh would be even better. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Killer Rat |
 Killer Rat Trackday Trickster
| willis1337 |
 willis1337 Brolly Dolly
 Posted: 14:21 - 17 Mar 2013 Post subject: |
https://www.yanchor.com/index.html
£60 but it seems good and worth putting in if you're doing a concrete base. Might even save you a bit of cash off your insurance. ____________________ Current bike: KTM SD1290GT
Previous bike: BMW K1300S |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| zapmole |
 zapmole Borekit Bruiser
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 20:36 - 17 Mar 2013 Post subject: |
Waterbutt filled with concrete or the likes and chain around that? ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| manc33 |
 manc33 L Plate Warrior
| stinkwheel |
| SQL |
 SQL World Chat Champion
 Posted: 21:08 - 17 Mar 2013 Post subject: |
| Depleted |
 Depleted Two Stroke Sniffer
| sidewinder |
 sidewinder World Chat Champion
 Posted: 21:48 - 17 Mar 2013 Post subject: |
I found 3 large links of chain of a crane so sank two of them in ground with part of the third link sticking out  ____________________ "Nitrous is like a cheap hooker, you want to hit it but are scared of the consequences |
| UnspeedySam |
 UnspeedySam World Chat Champion
| Im-a-Ridah |
 Im-a-Ridah World Chat Champion
| DottyDuck |
 DottyDuck Nearly there...
 Posted: 03:38 - 18 Mar 2013 Post subject: |
| Yoyo |
 Yoyo Brolly Dolly
| RyanTZR125 |
 RyanTZR125 Scooby Slapper
| Cardinal |
 Cardinal L Plate Warrior
 Posted: 22:25 - 18 Mar 2013 Post subject: |
The last post was made 13 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
