SPITFIRE SPARKPLUGS
NSRboi
PostPosted: 12:07 - 27 Mar 2002    Post subject: SPITFIRE SPARKPLUGS Reply with quote
Can anyone comment on Spitfire Sparks? Are they any better than NGK's? 8)
Kris
PostPosted: 12:31 - 27 Mar 2002    Post subject: also... Reply with quote
I need a new spark plug too. Do they come in sizes or numbers (?) and which do I need for my 2000 NSR.......also how much are they?
Thanks
Viper
Get off my bloody bike!
PostPosted: 17:53 - 27 Mar 2002    Post subject: Reply with quote
Kris... I think (from memory) the code is... BR9ECS
And they cost abut £6 ish
PostPosted: 20:10 - 27 Mar 2002    Post subject: SPITFIRE SPARKPLUGS Reply with quote
Save your money. They are not much use. The spark will just jump over the best gap, so you will not get 2 sparks. There only advantage is that as they wear and the gap increases, it will do so more slowly. However, with a 2 stroke where plugs foul up long before the gap gets to be a problem this is not really any help.
Think they have been done in the USA by the equivalent of advertising standard agency for having no proof of their claims of more power
Stevo
Guest
PostPosted: 22:00 - 27 Mar 2002    Post subject: Reply with quote
I did use a splitfire plug in my KMX200, and i think that i found some improvement? I noticed that starting was generally a 1 kick affair, where as before it might have needed a few kicks to start from cold. The throttle response and low end power seemed better, but that may have just been down to the Boyesen Reedvalve, that i fitted at the same time. The plug lasted 2000mile without any real signs of wear, so maybe its a true long life 2 stroke spark plug, but as for performance i doubt that there is much to be gained from a plug change.
PostPosted: 22:19 - 27 Mar 2002    Post subject: Reply with quote
I suspect that any change in starting would be more likely to be down to the slight differences between the heat range equivalents between different plug makers.
As to long life, in 2000 mile the central electrode wont wear much. Plenty of cars these days have spark plugs with a 60000 mile life (which is when you find that having not taken the plugs out for 5 years they are seized solidly in place!)
Kris
PostPosted: 11:30 - 28 Mar 2002    Post subject: cheers viper! Reply with quote
Very Happy Cheers viper! Just bought one...cost £6.04 (you were pretty close!)
Are they a doddle to fit?
The last post was made 24 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 51.22 Kb
