| Gazz |
 Gazz World Chat Champion
| fatjames |
 fatjames World Chat Champion
| radicalrabit |
 radicalrabit Crazy Courier
| Speed |
 Speed Could Be A Chat Bot
 Posted: 10:48 - 19 Mar 2013 Post subject: |
| fatpies |
 fatpies World Chat Champion
| thx1138 |
 thx1138 World Chat Champion
| jjdugen |
 jjdugen World Chat Champion
| snikks |
 snikks Spanner Monkey
 Posted: 13:02 - 19 Mar 2013 Post subject: |
I have a pair of these: https://www.greentyre.co.uk/bike.html on my push-bike, and they are absolutely fine in terms of comfort etc. I'm not sure why they couldn't do the same thing for motorcycles/cars - but if I had to guess it would be that the tyre manufacturers make a lot of money through damaged tyres needing replacement - so where's the motivation for them to encourage tyres that stand up to it all better? and they have enough heft to influence which tyres are allowed on the road. ____________________ - CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F |
| G |
 G The Voice of Reason
 Posted: 13:22 - 19 Mar 2013 Post subject: Re: Just had a thought - non-flat tyres? |
| fatpies wrote: |
Tyre mousse, they are a hybrid tech, i.e. still contain air. Apparently they give a rough ride can still get punctures and are harder to change but can't be patched like tubes or plugged like tubeless. |
They only contain air as much as any foam does, as far as I know.
You can't get punctures, I didn't think; but yes, are usually a load of hassle to change from what I've read.
No need to patch or plug them.
What they can do is both wear down generally (foam degrades) and it some cases separate - usually where each end is joined I believe.
I've never used them myself, someone who has might come along.
They aren't road legal as far as I know. I'm not sure if they're designed for sustained road use really.
From what I've seen they probably wouldn't last too well under such circumstances.
If you left the valve in, then MOT tester probably wouldn't realise.
Of course, the versions we have, have been produced to work well in off-road circumstances.
Solid tyres are used on some really big things, I think - earth movers and the like.
This is a 20kg 'bumper plate' made almost entirely of rubber:
https://www.savagestrength.co.uk/media/catalog/product/cache/1/image/500x500/9df78eab33525d08d6e5fb8d27136e95/y/o/york_20kg_bumper_plate.jpg
This is a cast iron 20kg plate:
https://www.yorkfitness.com/media/images/small/7383-hammertone-cast-iron-olympic-plate-20kg-high.jpg
Both are on the same size barbell.
Sure, the rubber one is a good bit larger. But not that much larger! Certainly no where near as large as 20kg of compressed air. |
| Suntan Sid |
| c_dug |
 c_dug Super Spammer
| fatpies |
| Teflon-Mike |
 Posted: 18:33 - 19 Mar 2013 Post subject: |
Re-Inventing the wheel.
Ever since John Bull invented the pneumatic tyre, people have been trying to re-invent the solid one!
There have been hundreds of different 'punctureless' tyre designs to my knowledge, appearing on tomorrows world or the automotive trade press, and some getting more or less market viable.
Dunlop developed a 'bullet-proof' tyre during the second world war, especially for the little aircraft they used to drop resistance workers behind the lines; The Mad-Dog-Whatsisname SAS boys that fought behind the german lines in Africa harassing Rommels supply lines aparently had them fitted to thier jeeps. I dont know what the construction technology was, I know the rubber was soft enough that a bullet could go straight through it and it could sort of self 'heal' like cheweing gum after; and that they were low-pressure tyres and I think used internal webs to stuffen them... and I seem to recall that they were evolved into a road tyre for cars in the 1960's, that didn;t prove commercially successful.
I think that the Dunlop bullet-proof tyre may actually have been an impediment to other re-invented wheels, though due to patent issues.
The 'web' designs, like one above seem to have come round at regular intervals, & I recall particularly one that had S shaped webs in carbon-fibre, bonded into the hub-flange so it was both tyre and wheel in one.
Comment about the 'need' for pneumatic tyres being to provide complience in the face of crude suspension systems has been sited very often, in association with re-invented wheels.
However; last twenty years has actually seen suspension systems becoming LESS sophisticated, not more, as product engineering down to a price and 'acceptible' quality and performance levels has taken priority over performance enhancement.
1960's the mini's rubber block 'all round independent' suspension was hailed as innovative, and sophisticated, and shown to endow the little car with better 'handling' than its sports-car rivals.... the copper Minis making something of a mockery of the MG Midget & Sprite sports cars when he stuck the 1275cc engine they used into the Mini! Even the Spitfire, that boasted all round undependent suspension and was applauded for its twin whish-bone front suspension, was humbled by the little Copper S's.
Such sophistication, in the car world, was gradually retro-engineered until the pogo-stick McPhearson strut became the defacto standard suspension solution for almost all cars.
In the bike world; 1950's & 60's any suspension at all was a bit of a novelty, and until the 1970's the hydraulic damped, telescopic front fork, and simple twin hydralic plunger damped rear swing arm was the defacto standard, until via early Motocross, first the long travel cantilever monoshock rear suspension, then the more complex multi-link rising rate system was pioneered.
Those became common on road bikes in the early 1980's, but still paired with the humble telescopic front fork. That got turned upside down in the late 80's early 90's and has switched ands a few times since; but as yet still remains the overall 'best' solution to motorcycle front suspension and the most common.
Back ends meanwhile, have often reverted to plain twin-shock arrangements or during value engineering excersises variants of the crude cantilever mono-shock arrangement.
Or in short.... suspenion technology has NOT come as far as you might presume!
About ten years ago, and I'm Sure G or Kickstart could find some bumph on it; UK student, declared that the modern sportsbikes suspension was 'good enough' to do away with the pneumatic tyre, and re-invented the wheel.... concieving a sort of tank track thing...
It was about a dozen rubberised metal plates, hinged in the middle along the axis of the bike, so that the plates could tilt with the bike and the rubber bit stay flat to the tarmac as the wheel went round..... Was supposed to allow more rubber to be put in contact with the road for better traction, without having to have such a stupidly wide pneumatic donut.......
I seem to recall follow ups said that it 'failed' like so many wonderful bits of British shedlogy, becouse of lack of investment & development.... but there was also comment that I find as or more plausible that it was simply a Dodo from the beginning, and that it didn't offer any great improvement in traction, while being difficult and expensive to make and giving a bludy harsh ride!
Tyre companies have always been demonised and accused of stifling tyre technology innovation, and people have always bemoaned the price of modern sports rubber.....
Yet, they make what the market demands, and over the last twenty years, demand has been for ever softer, lighter carcas sports tyres with ever more performance potential, and less life and robustness.
You roll down the road on a 180 section tyre, with four times the rubber in contact with the road, than an old touring bike with 90 section tyres..... course the chances of you picking up a nail are going to be twice as much! And fact you have demanded a light construction and soft compund tyre so you can go quick round corners, means its that much more likely that that nails going to go through the darn thing!
Its not the tyre makers fault that the market has been demanding these tyres and steering these compromises for however long.... and of course they are going to be happy to flog you new tyres when you get a puncture....
And its a damn site cheaper to make wider lighter pneumatic tyres for a sports-bike than it is completely engineer a solution that doesn't do the job half as well, and solves only a small, if expensive, problem for a few people, pretty infrequently!
And has to be said; modern tyres, for all thier added width, and all thier lighter construction, ARE pretty puncture proof, with thier steel and kevlar belting, compared to tyres of old, that were often made of canvas and contained a bladder tube. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| G |
The last post was made 13 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
