My CBR 600F is backfiring (I think?)
Notj7
PostPosted: 11:02 - 19 Mar 2013    Post subject: My CBR 600F is backfiring (I think?) Reply with quote
Hi guys, yesterday I noticed a few things whilst riding. These have only started happening recently.
A quick throttle-off say, in first from revs > 5k, gives a bit of a pop/bang.
And when accelerating in any gear, go over 4k then keep the speed constant and there's a kind of bubbling noise from the exhaust. I don't know how else to describe it. It's not the smooth sporty noise, it's more cruiser-y.
It doesn't sound healthy really. I've had it less than a year from a local Honda dealer, only done 10k on it. It's currently at 33k miles, service less than 6 months ago. Anyone have any ideas / suggestions?
Left the forum.
Minty
PostPosted: 11:10 - 19 Mar 2013    Post subject: Reply with quote
I have a CBR 900 and rolling off the throttle whilst the engine is under load and at quite high revs (say going down a hill) will make my exhaust pop away like a good 'un.
Does it still feel okay?
My fingers smell of your mum.
CarlosCBR
PostPosted: 11:11 - 19 Mar 2013    Post subject: Reply with quote
Sounds to me like hole in exhaust or a split in the inlet manifold. Check your PAIR system is still connected properly too. you are on about the CBR125 yeah?
Minty
His current bike is listed as a CBR600.
Notj7
PostPosted: 11:13 - 19 Mar 2013    Post subject: Reply with quote
It's an 05 CBR 600F - I'm not too good with the mechanics of it, still learning!
Is this sort of stuff covered by a warranty when you buy from Honda then?
It's mainly the gargling noise when at any revs higher than 4k I guess.
Left the forum.
_mjs_
PostPosted: 11:26 - 19 Mar 2013    Post subject: Reply with quote
Sounds like a loose exhaust to me.
Legsy.
PostPosted: 11:31 - 19 Mar 2013    Post subject: Reply with quote
A you running a standard exhaust?
My 2004 CBR 600F has been doing this ever since I changed the can a while back.
I might go for a remap one day, but doubt I'll ever be arsed for the sake of a couple of extra N.m.
Notj7
PostPosted: 11:34 - 19 Mar 2013    Post subject: Reply with quote
Yep, nothing's changed on the bike really, it's all stock. And well looked after, or so I thought until I really heard the rumbling this morning...
Left the forum.
DrDonnyBrago
PostPosted: 11:35 - 19 Mar 2013    Post subject: Reply with quote
Lambda sensor* plugged in still?
* a thing screwed into your exhaust, just before the can.
Fbyte
PostPosted: 12:29 - 19 Mar 2013    Post subject: Reply with quote
Have the same bangs on my 2001 when closing the throttle.
Some small holes on the downpipes which I fixed using some exhaust repair paste.
Two track session later, this happens.... Wink
https://cdn.bikechatforums.com/files/camerazoom-20130306122842086.jpg
No more track for the day 8(
Check for any holes. Just after starting the bike move your hand around the pipe, you should be able to feel if there are any leaks
Acemastr
PostPosted: 13:05 - 19 Mar 2013    Post subject: Reply with quote
My '97 600F used to do this, spit flames too, but that was because of a slight gap between the exhaust join that let air in, which then hit a hot exhaust and combusted.
Looked epic
2016 Toyota Tacoma Limited
keggyhander
PostPosted: 19:04 - 19 Mar 2013    Post subject: Reply with quote
Embrace it.
Backfiring is ace.
Snorty
PostPosted: 19:51 - 19 Mar 2013    Post subject: Reply with quote
Definitely an exhaust issue if it has just started happening. Run the bike and put your hand (carefully) in various places on the downpipes, see if you can feel any air pressure.
Preferably when cold before the headers have a chance to heat up, though they do heat up bloody quick.
I'd suspect a hole personally.
Notj7
PostPosted: 23:31 - 19 Mar 2013    Post subject: Reply with quote
Yep, you guys were right. There's a bloody hole somewhere underneath. It's 'blowing'. I can feel it with my hand.
Took it to Honda for an opinion and the sales guy told me ballpark worst case scenario, £500 for the whole system vs best as £100 to patch it that'll "last a few years", but it'll "need a new system eventually anyway".
Also been told that this sort of thing isn't covered by any warranty. Just a little pissed that I bought it from a dealer under the premise of paying more for a safer buy, and it's got a bastard hole in it!
Left the forum.
Snorty
PostPosted: 00:05 - 20 Mar 2013    Post subject: Reply with quote
£100 to weld a patch on? I'd just get it done by someone else, not through the dealer.
Acemastr
PostPosted: 00:14 - 20 Mar 2013    Post subject: Reply with quote
Downpipes are only £250 or so aren't they? generally anyway
CaNsA
PostPosted: 05:16 - 20 Mar 2013    Post subject: Reply with quote
Laughing Laughing Laughing Laughing
They seen you coming a mile off.
You only need downpipes.
Fbyte
PostPosted: 09:21 - 20 Mar 2013    Post subject: Reply with quote
The cheapest downpipes I managed to find was around 280 (Motad stainless steel)
If the hole is not huge (like mine Smile ), try first using some repair paste (I used Nural 300) but any one exhaust repair paste from Haldfords will do it.
It is only a temporal fix, but it was fine on mine.
No more bangs for a couple of weeks until I did a track day and the whole section where I applied the paste blow off due the condition of the pipes. (badly corroded)
DrDonnyBrago
PostPosted: 11:05 - 20 Mar 2013    Post subject: Reply with quote
The welding will last about a week, and should cost £20.
Get downpipes from motad, don't be tempted to use cheap shitty ones i.e. delkevic, sandys bike spares, chingchong etc - they will give you a flat spot at 7-8k rpm that will you drive you mental. Don't ask how I know Evil or Very Mad .
Notj7
PostPosted: 12:43 - 20 Mar 2013    Post subject: Reply with quote
Looking on eBay for downpipes, I see £280... however they're for the F1, F2, F3.. so < '05 versions... anyone have any links or would one of these be okay?
Also saw about the slowness after having new downpipes fitted, seems the fix is to have the ECU completely reset because it might've been running rich from when the downpipes had the hole...
Edit: also, for cheap, they're only scraped and would be an alright temp right? https://www.ebay.co.uk/itm/HEAD-PIPE-HEADER-EXHAUST-MINOR-DENTS-SCRAPE-CBR600F4I-CBR600-F4I-CBR-600F4I-05-C-/230943891744?pt=Motorcycles_Parts_Accessories&hash=item35c5542120
Left the forum.
Acemastr
PostPosted: 13:25 - 20 Mar 2013    Post subject: Reply with quote
An ECU won't 'get used' to a particular scenario, it adjusts as and when, don't worry about that unless the new downpipes don't have a hole for a lambda
Notj7
PostPosted: 15:15 - 20 Mar 2013    Post subject: Reply with quote
Okay, Motad have offered me part: D6HFSC, set of downpipes for my 600F, for £159.99 Very Happy These hard to fit? BCF fancy walking me through it this weekend?
Left the forum.
Bofh5
PostPosted: 15:35 - 20 Mar 2013    Post subject: Reply with quote
Just soak the header nuts in plusgas.
Other than that its straightforward enough.
Fairings off obviously and new gaskets are worth fitting.
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
DrDonnyBrago
PostPosted: 15:43 - 20 Mar 2013    Post subject: Reply with quote
That is a good price. How did you get it, I want in!!!
Changing downpipes requires a prayer to the god of exhaust studs. A sacrifice wouldn't go amiss. Failing that, start soaking them in plus gas now.
If they snap, it turns a simple job into a disaster. If they don't snap, it is piss easy. On your bike, fairings off, endcan off, helps a lot for access if the radiator is drained and removed too, otherwise you remove the bottom bracket and pull it forwards (better to remove, bike is probably due new coolant anyway).
Next time I have to do them, I'm cutting the nuts off (dremel, nut spitter) and cleaning the studs up with a die.
Refit using brass nuts, lots of copper grease and new gaskets.
motad_uk
PostPosted: 09:15 - 25 Mar 2013    Post subject: Reply with quote
2 years ago with loads of buyers having grief with the chinese copies- we introduced our Venom range of collectors which are the ones offered at lower prices
3 year warranty instead of 10 years for Motad but still stainless 304 but perhaps with less time spent on the cosmetics
Dont want to sell on the forum of course- and also dont want to undermine our hard working dealers
Would prefer to discuss these "offline" - pm me or email ianmcdonald@motad.co.uk
The last post was made 13 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 3.45 - MySQL Queries: 13 - Page Size: 125.87 Kb
