| liamk199 |
 liamk199 Derestricted Danger
| bladerunner |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 22:54 - 20 Mar 2013 Post subject: |
the points ,if the older models....are behind the flywheel and difficult to set.Basically there should be two marks on the flywheel,one 'T' is for lining up against a casing marker,this marker indicates when the spark should fire as the points open.
basically you have to set the points gap...WHEN THE POINTS ARE WIDEST ON THE TIMING CAM to the required setting,usually between two settings in practice.
on many points systems the plate that the points are fixed on can be adjustly slighty,usually rotated,...so the 'timing',as in spark at right height of piston is correct.I.E. the point the contact breaker surfaces seperate and open.
CD ignition does he same but uses a tiny magnet to 'trigger' a tiny 'pulse coil' to trigger the main spark coil.Timing on CDI (pointless) motors is usuallly very accurate and reliable.On points system the timing generally wanders and has to be checked,severe timing issues can melt pistons and waste petrol and power.
many years ago the timing was the first thing to check on many motorbike faults and since CDI sparks,fuel issues seem to cause as much hassle as the high voltage side ,as opposed to two third ,points ignition problems. to one third feul probs in 'the olden days'
you can use a multimeter or simple 6 v bulb to find the point when the contact breakers open,or you could use a strobe if you get it running.Try looking closely at the points and see if there's any scratch marks from sideways screwdriver levering of the points plate......this should show minor adjustment,after 'gapping' the points (main adjustment) is possible....moving the plate moves the points on the cam on the end of the crank....and as other poster has said make sure the flywheel has been replaced ACCURATLY...its amazing how many little bikes I've seen with em on wrong...usually a flattend woodruffe key ...eased to death with a pipe bar!!!!!its amazing how strong small engines are. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| liamk199 |
| bladerunner |
| unitynotsocri... |
 Posted: 21:54 - 23 Mar 2013 Post subject: |
the pickup magnet should nt move on the flywheel and should be an even distance from the sensor for even timed sparking......if its old then it may have dropped its magnetism ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| liamk199 |
| unitynotsocri... |
 Posted: 23:15 - 23 Mar 2013 Post subject: |
the distance between the pickup and flywheel should be constant,if its not then the flywheel is'nt seated on the shaft right(woodruffe key problem)
or its been warped or is not fully tight.A few sensors i've seen are non adjustable,but able to be moved a smidge or have the external pick up mounts drilled a tiny bit to allow some minor adjustment.......but they are usually FIXED.....which is far less hassle than points./To get techy you could use a timing disc card.
connecting a multimeter to the ohm setting and spinning the flywheel around can tell if the sensor is working and be used to set the timing against the timing marks.
usually ....what a word......theres two marks or one on strokers....
some older strokers and nearly all four strokers used an advance /retard sprung bob weight that moved the 'igition timing' ...i.e spark point in relation to piston position..........as the engine revved up.To increase the flexibility of the engines performance the small bob weights adjusted the spark point to make the engine rev higher,and give more power lower down the rev range...
think your welded open powervalve gives you great performance low to mid.The timing should take care of itself.you could connect a 'timing light' on it and check the alignment marks on the flywheel,but i would'nt worry about it.......just make sure the magnet is not rattling out and the pulse coil is pulsing .......(multimeter.....or check for spark from earthed plug with ign on when magnet/screwdriver is whizzed by it).......
if you did play around with the 'timing' options...both cdi units spec ,and microdrilling the sensor screws...(tedious..unecessercary)........i would go for slightly retarded timing,but i havnt much exp on strokers..and hands on tuning em.
it may be worth jetting the carb /filter setup for low to medium grunt,to encourage the welded exhaust powervalve. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| bladerunner |
| liamk199 |
| liamk199 |
| Ariel Badger |
 Ariel Badger Super Spammer
| liamk199 |
| Ariel Badger |
| liamk199 |
The last post was made 13 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
