suzuki ts125r timing , backfires
liamk199
PostPosted: 21:01 - 19 Mar 2013    Post subject: suzuki ts125r timing , backfires Reply with quote
just did a engine change on my ts125r as the old one blew up.
the new one wont start and backfires while kicking it over, how do you adjust the timing on these never done 2 strokes, does the flywheel need to come off , any help would be great thanks
l d kirton
bladerunner
PostPosted: 22:57 - 19 Mar 2013    Post subject: Reply with quote
You can't really adjust the timing on this bike....unless your woodruff key has snapped......try a new plug and check the timing with a strobe light if you can borrow one
liamk199
PostPosted: 19:12 - 23 Mar 2013    Post subject: help Reply with quote
have looked at it there one small pick up coil on the outside off the flywheel , it wont adjust round but does move closer and away from the flywheel, i manged to get it running fine the it just lost power and cut out and know wont start , has a good spark and compression , carb has been cleaned and set up, one thing i noticed is the power valve has been welded wide open which have been told can change the timing , if you hold the throttle open it back fires . not sure what went wrong it happend so quick . does having the exhaust wide open stop it starting , pulling my hair out lol.
l d kirton
bladerunner
PostPosted: 21:07 - 23 Mar 2013    Post subject: Reply with quote
Having the power valves welded open will not effect the ignition timing. On some suzukis they open the power valves just above tickover( so you can check adjustment without having to rev the nuts off it ) then close them again before 3k rpm........ Deffo try a new plug and cap and a bit of fuel down the plug hole.I've seen plenty of dead plugs that spark when not under compression but fail when exposed to the working end of an engine.....and deffo try a strobe to check timing. And like I said possible woodruff key failure. Mark a line from the crank to the flywheel, kick it over a few times and see if the marks move?
Failing that if your sure compression is good. Maybe check the reeds
liamk199
PostPosted: 22:46 - 23 Mar 2013    Post subject: . Reply with quote
yeah that was the first thing i did change the lead and a new plug the only one they had was this irodium one that was like £9, was the right size , but after looking on the internet people dont rate them compered with the standerd copper ones, i will check the flywheel and the timing , but if the timing is off how can i change it if the pick up wont move, also how do i set the distance up between the pick up and the flywheel . thanks guys
l d kirton
bladerunner
PostPosted: 00:21 - 24 Mar 2013    Post subject: Reply with quote
Welded open power valve will give you bugger all mid range...and I mean big hole in the power curve! Just a point of interest...Suzuki did tend to use 2 different manufacturers for ignition parts. Are you sure the genny and fly wheel are correct for your Cdi? I had this problem with an RGV 250 a while back. Try your known good genny and flywheel. Sometimes you'll see the pickup lug is in a different position relative to the crank position or the pick up lug is a different length! Deffo worth looking if your using ones supplied with the new motor.
liamk199
PostPosted: 10:45 - 24 Mar 2013    Post subject: timing Reply with quote
right just looked at it and the spark is very retard , the little slip of metal on the flywheel is passing the pick up before the piston is at tdc , looking at my old engine which is spot on. cant see any timing marks but i will pull the flywheel off to have a look at the key and see if it has sliped . hopfully this may have solved it . does the flywheel just have one slot which the key fits into which lines it up or is there a few . thanks
l d kirton
liamk199
PostPosted: 10:52 - 24 Mar 2013    Post subject: timing Reply with quote
also quick question when the piston is at tdc , the bit slip of metal on the flywheel does the pick up need to be in the middle of it or start of end ? thanks
l d kirton
Ariel Badger
PostPosted: 11:01 - 24 Mar 2013    Post subject: Re: timing Reply with quote
That is advanced not retarded.
Edit.A quick look at some books tells me your spark should be about 22 degrees BTDC (or 2.4mm of stroke) I have not seen the book for your bike but these are comparable 2T machines so there will be some slight variation.
liamk199
PostPosted: 13:04 - 24 Mar 2013    Post subject: timing Reply with quote
is that with the pick up in the middle of the flywheel magnet ? thanks
l d kirton
Ariel Badger
PostPosted: 17:31 - 24 Mar 2013    Post subject: Reply with quote
It is wherever the signal fires, can you put a strobe light on it?
liamk199
PostPosted: 19:07 - 24 Mar 2013    Post subject: timing Reply with quote
yeah have done that the timing is done , but a new problem has come up . the new piston i put in a few days a go has had it big scores down it, well P**ed off. it looks like there was a hole in the little pipe that goes from the auto oil pump to the carb think this was the problem first and last time i trust autolube systems . i have a good cylinder that came of another engine will get a new piston and just premix the fuel at least i know the engines geting oil. its been one thing after another with this bike , but will see it through .lol thanks
l d kirton
The last post was made 13 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 91.37 Kb
