Rough Idle - with pics and video
mumbles
PostPosted: 17:49 - 24 Mar 2013    Post subject: Rough Idle - with pics and video Reply with quote
Hello again,
I have uploaded a video and pictures this time to help diagnose the problem which is a follows; you see at the start of the video (engine already warmed up) it has a very rough idle with the mixture screws quite far out (rich) and the idle speed screw quite far in. When I rev the bike it hangs at 3000rpm and if I drop the idle speed screw it idles normally but most times just stalls and if i go out for a ride with the idle speed screw that low it will stall at lights, rounder-bouts ect. so just a case of leaning out the mixture right? nope because it idles slower if I make the mixture leaner and stalls more often and it also makes if much harder to rev from idle.
Just to add compression on my bike is low 130psi but it's 130psi on both cylinders so it's irrelevant right? and their is a nose coming from the top end it's not tapping it just sounds like loud moving parts (Im not sure how to describe it better)
https://www.youtube.com/v/4_Rx-zpBQzM
https://i1054.photobucket.com/albums/s492/mumbles_8P/GOPR2011.jpg
https://i1054.photobucket.com/albums/s492/mumbles_8P/GOPR2012.jpg
https://i1054.photobucket.com/albums/s492/mumbles_8P/GOPR2013.jpg[/url][/code]
Warming the world 2 strokes at a time.
2008 rs50 (SOLD) - 2006 gz125 - (Winter Bike) - 1981 CB250N (In Restoration)
Ollie1995 This post is not being displayed because the poster is banned. Unhide this post / all posts.
mumbles
PostPosted: 17:54 - 24 Mar 2013    Post subject: Reply with quote
Ollie1995 wrote:
First thing I'd do is buy some new plugs. Shocked
I have a second set and clean both sets with a wire brush they because they look like this after just 5-10 minutes idling
yen_powell
PostPosted: 18:21 - 24 Mar 2013    Post subject: Reply with quote
Is the choke stuck on, cos those plugs look very sooty so it's running rich.
What bike are we talking about, does it have a cable choke or a plunger direct on the carb?
XT1200Z and a DR350 in bits
mumbles
PostPosted: 18:24 - 24 Mar 2013    Post subject: Reply with quote
No choke my friend they have been removed, Its a CB250N 1981 inline twin
WULFSTAN
PostPosted: 18:58 - 24 Mar 2013    Post subject: Reply with quote
What condition is the air filter in
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
mumbles
PostPosted: 18:59 - 24 Mar 2013    Post subject: Reply with quote
Im not sure how to check properly but last time I checked it was slightly damp
yen_powell
PostPosted: 19:18 - 24 Mar 2013    Post subject: Reply with quote
If you remove the choke on my Africa Twin (which I did many years ago, much better runner since) you have to put the plungers in before blanking them off, otherwise the choke is permanently on. I have known people just blank their chokes off and leave out the plungers as they think it's part of the cable.
mumbles
PostPosted: 19:46 - 24 Mar 2013    Post subject: Reply with quote
I have just realized what you mean by plunger, I don't have that type of choke my choke works on butterfly valves which I have removed completely
mumbles
PostPosted: 12:26 - 25 Mar 2013    Post subject: Reply with quote
It just occurred to me that I don't have the stock exhaust on this bike I have bolted on 2 125cc pit bike exhausts with I think are being more restrictive, could this cause the problems im having ?
radicalrabit
PostPosted: 14:08 - 25 Mar 2013    Post subject: Reply with quote
Can I ask why the fk do people mess with their bikes if they dont know what the fk they are doing or what effects its going to have?
is it TINKER management ?
VF1000 F2F, BLACKBIRD with carbs, 2nd VF1000F2F just need somewhere to go now..
R1stu
Shrek!
PostPosted: 15:08 - 25 Mar 2013    Post subject: Reply with quote
Ive been having the same issues on my cb350. took the tank off yesterday and found the carbs were caked in crap around the choke mech. so when the choke was on, then turned off the lever went down, but the plunger was stuck in the on position.
This caused my bike to idle at 4k.
Cleaned it off with brake cleaner and wd40 and seems OK now.
Maybe something is gunked up sticking it.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
mumbles
PostPosted: 16:45 - 25 Mar 2013    Post subject: Reply with quote
I like to mess with my bikes because it makes them more accustom to me but more importantly every time I pick up a spanner and 'tinker' with stuff I learn something new, most times more than one thing which helps me to be a better mechanic.
As I said before I have removed the whole choke system nothing remains apart from blanking plates and my carbs are spotless but thankyou for your help all the same Smile
R1stu
Shrek!
PostPosted: 16:49 - 25 Mar 2013    Post subject: Reply with quote
Yes, but did you strip the carbs all the way down a remove everything? something may be sticking even if you removed the mech.
paddlesat16
PostPosted: 16:54 - 25 Mar 2013    Post subject: Reply with quote
The cb250n or superdream needs a choke for the cold weather, I would suggest you put it back on
This will fix the cold starting. Buy a Haynes manual as this will stop you making stupid errors while owning the bike.
The air screws on the bottom of the carbs need to be set at 2 turns out from fully screwed in, your idle speed should be set at 1300 rpm+/- 100 with the black knob under the carbs.
Once set up the black plugs will disappear and a nice tan brown will magically appear.
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
mumbles
PostPosted: 18:39 - 25 Mar 2013    Post subject: Reply with quote
yeah the whole mechanism is gone including the butterfly valves the idle speed booster the choke shaft everything and nothing is sticking and everything is clean
mumbles
PostPosted: 18:49 - 25 Mar 2013    Post subject: Reply with quote
I have a Haynes manual first thing i brought haha, the choke was removed because it was broken and I cant afford a new one but cold starting is not to bad I just bump start it takes less than 5 minutes Smile
as for the problem I have removed the exhaust baffles and now have a LOT more flow, I have also set the mixture screw to 2 turns out and the idle to 1400 (I prefer 1400 to 1300 because my generator does not really kick in till then when warming my heated grips) but the idle is still a little rough will video tomorrow but i think it's just an air leak now Smile
paddlesat16
PostPosted: 19:18 - 25 Mar 2013    Post subject: Reply with quote
Balance the carbs first, this should cure the rough idle
The last post was made 13 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 108.77 Kb
