New parts on Friday.
JiveBunny This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 14:36 - 25 Mar 2013    Post subject: Reply with quote
Please buy 2 new crush washers for your Banjo bolt...
Fork oil... you'll need to drain your old one, a repair kit is likely to be shit, you need new seals.
Spark plug is about £4 from a shop and the gap will not matter on your bike, all mine have worked fine outside of the box.
Sable
PostPosted: 14:48 - 25 Mar 2013    Post subject: Reply with quote
Theres easy guides for everything you want to do on YouTube, and everything you want to do is basic stuff so shouldn’t give you any troubles.
Spark plug gap tools £6 from Halfords. Valve clearance tool is about the same. Have you ever checked your valve clearances? Your bikes done 11k miles? IMHO garages never check them unless they have a reason the bikes not running right, so I prefer to give them an odd check every so often myself. If your doing all that too your bike you may aswell give them a check too.
Also, over £10 for a spark plug? You can get the same one from Halfords for £8.99, Iridium version I think of your spark plug for £6.50 on Ebay CR8EHIX-9 ? https://compare.ebay.co.uk/like/350619616876?var=lv<yp=AllFixedPriceItemTypes&var=sbar&cbt=y
moppy
If riveted chain, you're gonna need a riveting tool and angle grinder. If not, I can't imagine that's particularly hard. Gonna need a breaker bar to get the front sprocket nut off I woulda though.
You're gonna have to remove the forks to drain them (unless Paddy has a bodge) so yeh, you're gonna have to take the wheel off.
Yes, you'll need to do that.
You also want crush washers, not just normal washers.
There are bodge ways of doing fork seals and oil... but fuck that, I'll get banned Laughing
_Troy_
PostPosted: 14:54 - 25 Mar 2013    Post subject: Re: New parts on Friday. Reply with quote
JiveBunny wrote:
How hard to install the above?
The average person? Probably not too hard, but time consuming.
For you? LOL! Take many photos for BCF fun times.
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
LockyUK
PostPosted: 15:11 - 25 Mar 2013    Post subject: Reply with quote
paid on friday ? glad to see your dole has resumed Thumbs Up
h00dwink
PostPosted: 15:17 - 25 Mar 2013    Post subject: Reply with quote
plug, oil, pads is easy enough to figure out as you go along.
if it's not a split link chain you're changing from/to then good luck as it's a ball ache without the tool.
changing fork seals is not fun, get a haynes or do a fair amount of research in to what you're going to be doing.
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
anthony_r6
PostPosted: 15:28 - 25 Mar 2013    Post subject: Reply with quote
As above - if you are not mechanically minded, do not attempt the fork seals yourself unless you can afford the bike the time off the road while you deal with working it out and getting it right.
Levers, oil filter, brake pads and spark plugs depending on access to them are all easy.
Sable
PostPosted: 19:20 - 25 Mar 2013    Post subject: Reply with quote
You may just have to increase idle speed a touch. Google daelim idle screw. should just be an easy to reach philips screw under the tank.
regarding riding with leaky seals, when my cgs seals went I ended up with a rainbow coloured front wheel and the eternal feeling my front end was going too wash out. I would say its very unsafe.
Sable
PostPosted: 19:33 - 25 Mar 2013    Post subject: Reply with quote
idle screw should be on the carb doohickey
https://www.scootusa.com/images/carb_adjust_idle.jpg
something like that. let the engine warm up and adjust it while its running. it shouldn't need much.
Fisty
PostPosted: 20:05 - 25 Mar 2013    Post subject: Reply with quote
Friday 6:30pm. New thread from jizzbunny.
How do I fix my bike after I tried to fix it?
I Put money on it happening.
Fatter and faster than Fret
PostPosted: 20:41 - 25 Mar 2013    Post subject: Reply with quote
Fork seals, they'll probably change a few hours labour, £20 an hour labour is just never going to happen.
jeddy11
PostPosted: 11:15 - 26 Mar 2013    Post subject: Reply with quote
I actually think he is mentally retarded Confused
(this was a reply to sable who had a dodgy private message from bunny) Which has now gone..
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
CaNsA
PostPosted: 11:18 - 26 Mar 2013    Post subject: Re: New parts on Friday. Reply with quote
JiveBunny wrote:
I get paid on Friday and can finally afford to order parts.
/me waits for the "fucking tax man took all my money" thread.
Sable
PostPosted: 11:39 - 26 Mar 2013    Post subject: Reply with quote
Wrong place for it. Hit delete. Brain was up bum this morning. I assume it was something to do with this thread that prompted a PM. *shrugs*
Raffles
PostPosted: 11:50 - 26 Mar 2013    Post subject: Reply with quote
Along with your finger* Wink
*I was up early and read the PM that you have now deleted.
Sable
PostPosted: 12:26 - 26 Mar 2013    Post subject: Reply with quote
Hah, yeah yeah, we all have mornings where that sort of mongtardery will catch us off guard I'm sure. Learned me lesson. Be more awake when posting on BCF and don't offer help to Jive or he wants to bum sniff.
Suntan Sid
PostPosted: 12:46 - 26 Mar 2013    Post subject: Reply with quote
£111.71 in parts, that's a write off! Mr. Green
LockyUK
PostPosted: 14:11 - 26 Mar 2013    Post subject: Re: New parts on Friday. Reply with quote
you got it wrong mate, my thread entitled jizzbunny took my tax money!
PostPosted: 14:12 - 26 Mar 2013    Post subject: Reply with quote
I've told him it's good money after bad, but he's a determined wabbit.
With the fork seal, run a piece of thin plastic or a feeler gauge between the seal and the fork stanchion, all the way round. Sort out any burring on the stanchion as well - very gentle abrasion to take off any sharp edges and then nail varnish to smooth it out.
Might work, might not, but you can DIY it and it might save you a lot of time and money.
Dying at idle is likely to be your idle jet. Fuel filter, clean fuel, or strip the carb and clean the jet and check the float height while you're in there.
JizzBunny wrote:
wheel axle is not all the way in. Buying a new one also.
Or, and bear with me, figure out what's wrong with the current one. Has it shrunk?
The last post was made 13 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 130.64 Kb
