Rev counter
steveh
PostPosted: 00:26 - 22 Nov 2004    Post subject: Rev counter Reply with quote
Well i have a Gz marauder 125 (4t) and im after a rev counter, it doesnt come as standard but was wondering if there is anyone or anywere i could buy one, dont mind if its digi or clock.
cheers, Steve.
mattsmith95
PostPosted: 00:35 - 22 Nov 2004    Post subject: Re: Rev counter Reply with quote
cheers, Steve.
if it hasn't gone to start with I don't think you can simply add one
because it's not designed to have one.
I have a Honda CD250U which doesn't have one but I can fit one
because I can get a CB250 clutch case which has the hole for the
cable. (mainly because both bikes have the same engine)
Ask your dealer if one can be fitted, I don't think it's possible.
Frost
PostPosted: 00:35 - 22 Nov 2004    Post subject: Reply with quote
'Doesnt come as standard' as in, it has the mechanics to potentially have one but yours is just a model without one?
If so then stealing one of the model the does have one is all you need to do.
Otherwise if your bike never had one, and was never suposed to have one then i would say fitting one isnt possible sorry.
PostPosted: 00:36 - 22 Nov 2004    Post subject: Re: Rev counter Reply with quote
You probably can get one that will need to be wired into the ignition system.
However, I doubt it's worth it, especially on that bike, you should get used to how the engine feels quickly enough.
steveh
PostPosted: 00:41 - 22 Nov 2004    Post subject: Reply with quote
yeah cheers for the info, basicly wanted to know if it was possible, but by the relpys obviosly not.
cheers tho
Steve.
mr.z
PostPosted: 00:45 - 22 Nov 2004    Post subject: Reply with quote
If it can be done it would be horribly expensive and difficult, unless a version of your bike was made with rev counter its going to be pritty pointless, and even if they did make one with one then its going to be an engine out job!
The thing is, rev counters are usually driven from the camshaft or something similar inside the engine, which means allot of hassle!
Best bet is to get a noiseyer helmet and listen to the revs!
Lone-Wolf
PostPosted: 00:51 - 22 Nov 2004    Post subject: Reply with quote
Wotcha.
They make electronic rev counters that pick up the ignition pulses - they even do re-chargeable ones for magneto equiped race bikes . . . the bad news is, they are bloody expensive.
Now how badly do you want one ? Wink
Cheers.
L.W. - www.moonshiners.org.uk
proximity
PostPosted: 01:29 - 22 Nov 2004    Post subject: Reply with quote
Im making one to work with the ignition system. When its done ill let you know Very Happy
Robby
Dirty Old Man
PostPosted: 09:42 - 22 Nov 2004    Post subject: Reply with quote
You should be able to get one that just has a sensor that clips onto the HT lead to pick up the pulses, and you could wire it into something in the headlamp shell for power.
I'm pretty sure dynos use an HT lead clip to work out the revs, so it should work.
That said, its only a 125. It should be doing redline+1000 rpm at all time, and sod the engine life. You'll be selling it before its knackered.
stryker
PostPosted: 09:47 - 22 Nov 2004    Post subject: Reply with quote
Here is the electronic one. Its the 4th one down, costs £38. It just measures the pulses from the ignition or maybe even the rotary arm if you have one.
https://www.vehicle-wiring-products.co.uk/VWPweb2000/gauges/gauges.html
Now what?
mchaggis
PostPosted: 12:19 - 22 Nov 2004    Post subject: Reply with quote
I'd only break it again though, it only goes up to 8000rpm! Very Happy
I must not be a troll...
Mmmm, Guinness
pipnet11
PostPosted: 12:49 - 22 Nov 2004    Post subject: Reply with quote
The GZ engine is exactly the same as the GS engine (which does have a counter) except for the cam/rocker cover. The gear drive is still there under the cover its just not used. Problem is GS engines tend to be black and the GZ engine is polished. Dont know if its worth it really. Red line on the GS was 50 in 4th thats the only one i can remember, may be different on the GZ though cos of wheel size/gear ratios etc.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
PostPosted: 14:31 - 22 Nov 2004    Post subject: Reply with quote
Found an Elliot one for £126.61 in a Demon Tweekes catalogue, or about double that for the very nice Stack ones.
The M&P catalogue shows one for about £30, but only mentions the version to pick up the revs electronically in passing.
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.32 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 77.91 Kb
