Exhaust woes!
MeatHelmet
PostPosted: 08:15 - 29 Mar 2013    Post subject: Exhaust woes! Reply with quote
I am having real problems getting my exhaust to seal properly.
I have had the end can and the mid pipe off the down pipe twice now, and it will not seal right, it’s blowing at both joints.
Has anyone got any advice?
I have cleaned the pipes, inside and out properly, used exhaust paste to join them, clamped them up tightly, but they continue to blow!
I’m at a loss as to how to fix it!
It’s really starting to irritate me.
Bike - 2003 Kawasaki ZX6R 636 Ninja (A1P)
Walloper
PostPosted: 08:59 - 29 Mar 2013    Post subject: Re: Exhaust woes! Reply with quote
The can should be quite a tight fit on the pipe. They call it slip-on but that just means not welded.
If it's a loose fit it willnot seal.
You may be able to put a bit of sheet metal around the pipe to make it a bit fatter then fit the can over that and tighten the clamp on it.
The clamp doesn't actually do any sealing but only acts to secure the joint.
Pics are good. Make sure you have good lighting and hold the phone steady. Smile
PostPosted: 11:52 - 29 Mar 2013    Post subject: Reply with quote
Shim that sucker. Cut up strips of beer or bean cans, get it as tight as you can so that you can barely persuade it together before clamping.
croup7
PostPosted: 13:16 - 29 Mar 2013    Post subject: Re: Exhaust woes! Reply with quote
don't bother with paste it sets like thin fibre glass then flakes to bits go-to a car parts shop and find some copper silicone gasket repair it looks like copper grease in a white tube but sets like mastic and is perfect for exhaust manifold and joints .works a treat on my aprila exhaust manifold and silencer joint.
PostPosted: 13:57 - 29 Mar 2013    Post subject: Reply with quote
Instant gasket works, but it's filling gaps that shouldn't be there.
temeluchus
PostPosted: 14:16 - 29 Mar 2013    Post subject: Reply with quote
Beer/coke can shims help.
"Versachem Muffler Weld" works pretty good too, far better than gungum and the like.
MeatHelmet
PostPosted: 15:10 - 29 Mar 2013    Post subject: Reply with quote
Cheers chaps.
I have a few beer cans laying around.
Unfortunately, they have beer in them, so I will have to drink that first Rolling Eyes
temeluchus
PostPosted: 16:44 - 29 Mar 2013    Post subject: Reply with quote
MeatHelmet wrote:
Cheers chaps.
I look forward to the " I tried to fix mah bike whilst pissssht" thread!
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 58.33 Kb
