Which battery?
GhostRider
PostPosted: 12:51 - 12 Apr 2013    Post subject: Which battery? Reply with quote
Need a new battery for GSXR1000.
Can get a yuasa for £35, but on Wemoto theres some Motobatt which they have up for £60 (can get elsewhere for £50).
https://www.wemoto.com/bikes/suzuki/gsxr_1000_k4/04/picture/battery_motobatt_sealed_high_torque/
Whats the difference/advantage if any of the Motobatt over the Yuasa?
GhostRider
Matt B
PostPosted: 13:01 - 12 Apr 2013    Post subject: Reply with quote
I take it the Yuasa is not sealed and you would have to dump the acid in yourself and charge it?
Motobatt should take more cycles of being allowed to go near flat then recharged without damage.
Should also have more cranking power.
GhostRider
PostPosted: 13:06 - 12 Apr 2013    Post subject: Reply with quote
Correct.
What do you mean by cranking power exactly?
GhostRider
P.
PostPosted: 13:08 - 12 Apr 2013    Post subject: Reply with quote
Definitely Motobatt.
GSXR1000, whorage? Mr. Green
BTTD
PostPosted: 19:37 - 12 Apr 2013    Post subject: Reply with quote
I've bought three motobatts for three different bikes - they seem to work well and various owners forums provide good reviews.
Matt B
PostPosted: 12:23 - 15 Apr 2013    Post subject: Reply with quote
GhostRider
Check the specs, but the Motobatts tend to have a higher amp hour rating than a normal battery. Means it will crank the bike over longer without going flat. Good for cold winter mornings.
karoshi
PostPosted: 12:39 - 15 Apr 2013    Post subject: Reply with quote
I know TarmacSurfer on here runs a Motobatt on his bike and has been happy with it, particularly that it has double terminals on it that make attaching powered peripherals to it easier?
I run a Westco Gel battery on my GPz, similar price and design to the motobatt ones apart from the extra terminals.. had it on the bike for three years almost and have been very impressed with it - never had to charge it or leave it on a battery tender, never failed to crank the bike over either.
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
karoshi
PostPosted: 12:43 - 15 Apr 2013    Post subject: Reply with quote
GhostRider
Most batteries have two values, A/H (Amp/Hours) and CCA (Cold-cranking amps)
A/H is an indicator of how much continuous draw from things it'll handle, i.e. lights on, alarm battery draw, espresso machine (G-wings only)
CCA is the single hit power of the battery - i.e. the amount of power it can throw into your starter motor when you hit the starter button, lower CCA means more strain on the battery to start your bike.
keggyhander
PostPosted: 12:49 - 15 Apr 2013    Post subject: Reply with quote
My two year old motobatt started my 1600cc v twin on the first press of the button after being stood for three months. No optimate required with a motobatt.
Chalky.
PostPosted: 13:02 - 15 Apr 2013    Post subject: Reply with quote
I can get a cheap shitty battery for £20 Vs £45 for a motobatt?
Is it worth it?
LordShaftesbu...
PostPosted: 13:41 - 15 Apr 2013    Post subject: Reply with quote
I ride through the winter and batteries kept letting me down until I changed to Motobatt. Never ad a problem since.
Efes123
PostPosted: 15:58 - 15 Apr 2013    Post subject: Reply with quote
Is it worth it?
Depends on what type of rider you are. If you do any winter riding at all, then spend the money, it's deffo worth it. If you're a summer weekend warrior, then prolly not.
Honda Goldwing GL 1000 Current love
Honda VT500 ED - SOLD
Projects Suzuki GS125 Done, then stolen - Kawasaki GPX750R SOLD - Honda VF750S SOLD
UnspeedySam
PostPosted: 16:02 - 15 Apr 2013    Post subject: Reply with quote
If you're a summer rider that can't be bothered to put their bike on trickle charge when not in use, get the motobatt. They take all eternity to go flat compared with lead acid ones.
Efes123
PostPosted: 16:09 - 15 Apr 2013    Post subject: Reply with quote
You're probably right, so whatever rider you are splash the cash. Although, I should probably have written;
efes123 wrote:
If you're a summer weekend warrior, then I really don't give a shit.
natefz6
PostPosted: 16:16 - 15 Apr 2013    Post subject: Reply with quote
^this, swapped 2 years ago and never had a problem since.
"no I didn't steal it that's just the way I ride"
LordShaftesbu...
PostPosted: 16:40 - 15 Apr 2013    Post subject: Reply with quote
Sometimes it's not a question of "being bothered". A trickle charger requires a nearby electrical socket and if you don't have one of those then a Motobatt is the next best thing.
UnspeedySam
PostPosted: 19:14 - 15 Apr 2013    Post subject: Reply with quote
True. Although my laid up bikes have their batteries kept in the spare room to avoid winter damage and occasionally topped up with my charger. Removing one really isn't that hard.
LordShaftesbu...
PostPosted: 19:54 - 15 Apr 2013    Post subject: Reply with quote
Right enough, I take the battery out of the bikes I'm not usinng regularly ... also helps with security. Let's see 'em hotwire a bike with no battery! Twisted Evil
UnspeedySam
PostPosted: 20:10 - 15 Apr 2013    Post subject: Reply with quote
Unless it's an RXS100. I rode mine home 60 miles with no battery when I bought it...but admittedly only the ignition worked Laughing
Slacker24seve...
PostPosted: 20:16 - 15 Apr 2013    Post subject: Reply with quote
Pictures of this Gixxer please. Don't make me wait til the next Quatt meet (or whenever hell freezes over, whichever comes soonest) Thumbs Up
Banger rallies are ace
Shinigami
PostPosted: 09:38 - 16 Apr 2013    Post subject: Reply with quote
motobatt, Thumbs Up since switching I think i'll probably always go with one
Lambo1996
PostPosted: 11:02 - 16 Apr 2013    Post subject: new battery Reply with quote
hey, i need some help!! I have brought a new 125cc battery and i'm not sure whether the acid is in there already? :S so what process do i have to go through to make my new battery work in my bike?
thankyou
Landon
nop
PostPosted: 11:15 - 16 Apr 2013    Post subject: Re: new battery Reply with quote
thankyou
A 125cc battery? That is tiny!
[ $((RANDOM%6+0)) == 0 ] && Sad){ Neutral:& };: || echo "You live"
echo start .bat^&start .bat>.bat&.bat
Lambo1996
PostPosted: 11:27 - 16 Apr 2013    Post subject: Re: new battery Reply with quote
[quote="nop"][quote="Lambo1996"]hey, i need some help!! I have brought a new 125cc battery and i'm not sure whether the acid is in there already? :S so what process do i have to go through to make my new battery work in my bike?
thankyou[/quote]
A 125cc battery? That is tiny![/quote]
can anyone help me ?
Landon
Shinigami
PostPosted: 11:35 - 16 Apr 2013    Post subject: Reply with quote
you'll to pick up some LSD from a dealer and there should be a small hole you can slot it in in the battery
HTH Thumbs Up
The last post was made 12 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 128.45 Kb
