Author |
EazyDuz |
 EazyDuz World Chat Champion
 Posted: 12:10 - 13 Apr 2013 Post subject: Stuck pilot screws |
Some potato has messed with the pilot screws in the past, but never put the rubber bungs back in the ends to protect them from the elements.
One screw turns freely, but the other has a mangled head and is seized. I have already sprayed Plus Gas on it and left overnight but there just isnt enough grip there to undo it. I was going to richen the mix to see if it cures my exhaust backfire on decel. Have lightly tapped a screwdriver with a hammer to try and create a new slot but to no avail, not going to try that again as i run the risk of fucking up the threads in the carb body as well.
How would i go about removing it now? its about an inch deep into the carb body, shown almost in the centre of this pic:
https://i.imgur.com/pDgPuZy.jpg ____________________ To shreds you say? Tss tss tss |
Back to top |
The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:20 - 13 Apr 2013 Post subject: |
I've read on another forum that drilling a shallow pilot hole in the centre of the screw then hammering in a Torx bit works - I'll try to find the thread. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Back to top |
The Shaggy D.A. |
 Posted: 12:42 - 13 Apr 2013 Post subject: |
Found it - shame the piccies aren't there now.
https://suzukisavage.com/cgi-bin/YaBB.pl?num=1350749896/0#0 ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Back to top |
EazyDuz |
Back to top |
Ariel Badger |
 Ariel Badger Super Spammer
Back to top |
Pete. |
 Posted: 16:00 - 13 Apr 2013 Post subject: |
If I was to tackle that I would strip the carbs down on the bench, heat the area with a hot air gun, get some release agent in there, heat it again and then have a go.
One thing - NEVER us copper grease on idle mixture screws, or any other brass part in a carb housing. It's a good way of making them seize in solid due to dissimilar-metal corrosion. ____________________ a.k.a 'Geri'
Back to top |
EazyDuz |
Back to top |
Vincent |
 Vincent Banned
Back to top |
EazyDuz |
Back to top |
Pete. |
 Posted: 19:45 - 05 May 2013 Post subject: |
Nope, it's carbs-out time. ____________________ a.k.a 'Geri'
Back to top |
EazyDuz |
Back to top |
EazyDuz |
Back to top |
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
