 Posted: 21:43 - 11 Apr 2013 Post subject: Fitting highway pegs to my Enfield Bullet |
Progress so far.
Look at that engine mounting bolt, the one that's holding the exhaust bracket on. That looks meaty and in about the right place.
https://farm9.staticflickr.com/8406/8641403756_45425133c3_c.jpg
It's got a 1/2" BSF bolt through it. I've tried replacing this before using a long bit of studding with rubber hose over it and experienced total metal fatigue fail. Luckily before the engine fully parted company with the frame so it's going to require the application of some engineering and material technology rather than brute force and bodgery.
One trip to the steel stockholders later and I have a 12" length of EN16T steel alloy bar as recommended by a mate. Cost £7 mind, which is in some ways reassuringly expensive.
https://farm9.staticflickr.com/8262/8641403686_f8fc3d8190_c.jpg
There is something quite theraputic about cutting a thread. I've opted for UNF rather than BSF on the basis that dies are cheaper and it's easier to get nuts.
https://farm9.staticflickr.com/8246/8641403606_27d0742541_c.jpg
My mate also advised me that EN24T would be stronger still but a total sod to cut using a die. I'm glad I went with the EN16 then because this took an hour doing about 1/4 turn at a time!
https://farm9.staticflickr.com/8099/8640299385_18921be73c_c.jpg
So I guess this ought to be stronger than the original, all torqued-up.
https://farm9.staticflickr.com/8527/8641403466_e112987505_c.jpg
A pair of genuine Enfield footpegs and rubbers take 14 days to come from Deli but only cost £6.50!
https://farm9.staticflickr.com/8121/8641403392_584142cd82_c.jpg
Mock-up for position.
https://farm9.staticflickr.com/8404/8640299203_f9c8d0f438_c.jpg
https://farm9.staticflickr.com/8540/8640299051_754d2a87dc_c.jpg
Thing is, if I leave it like this, I'm putting a bending force on the stud itself. This is NOT what I want to achieve but I want this setup to act as two seperate parts (ie the bit that's holding the engine in and the bit that's holding the footpeg on). If it decides to snap, I want it to do so on the threaded portion of the stud, not on the bit that's holding my engine in. What I need to do now is make a spacer to fit in the gap between the peg and the middle nut and tighten it all down against that nut using a nylok on the end. Might even drill the middle out of four nuts and use those as spacers. Does that sound like a good idea to everyone else?
The other potential fail is that the peg will have a tendancy to rotate around the threaded bar. Even if I ramshee it up really tight this could be an issue (it's a 1/2" diameter hole in them). I'm condisering a couple of options, neither of them particularly elegant if I'm being honest. One is to drill and tap the peg casting for a grubscrew. The other is to get everything where I want it, drill all the way through the footpeg casting and the stud (obviously I'd pre-drill the footpeg casting) and fit a rowl-pin.
The latter appeals most to me because it should work without damaging the threads too much. It would introduce a weakpoint in the system but perhaps that is not a bad thing, if it snaps there, I lose a footpeg rather than having the bike fold in half at the next pothole.
https://farm9.staticflickr.com/8118/8641403120_6611556e50_c.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mysterious_rider |
 mysterious_rider World Chat Champion
 Posted: 00:23 - 12 Apr 2013 Post subject: |
+1 for drilling it and creating a weak spot. Sounds like the safer option chap. Personally I would have cut the bolt shorter, and tack welded it in place. Rather than break the peg, it'll just break the tack weld. Pick up off floor, put in pannier for welding later.  ____________________ KAWASAKIIIII |
| Ollie1995 |
 Ollie1995 Banned
 Posted: 00:56 - 12 Apr 2013 Post subject: |
I should point out, crashing is not that much of a worry. The standard footpegs will hit the ground first and the frame is a bolt-together modular thing, if that gets damaged, you just bolt in a new bit.
My previous attempt at highway pegs made from studding self-destructed due to metal fatigue from the constant vibration. If I lose that bolt, the frame top-tube will snap in half at the next bump/pothole. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DrDonnyBrago |
The last post was made 13 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
