Aftermarket rear shock
GrumpyGuts
PostPosted: 13:18 - 16 Apr 2013    Post subject: Aftermarket rear shock Reply with quote
Hi,
I was wondering on any recommendations for an aftermarket rear shock for a Hornet 98?
The stock one is absolutely shite - I'm feeling every single imperfection on the road, and so are my bollucks!
My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012
Islander
PostPosted: 13:20 - 16 Apr 2013    Post subject: Reply with quote
I think Hagon do replacement shocks for the Hornet. Thumbs Up
DrDonnyBrago
PostPosted: 15:42 - 16 Apr 2013    Post subject: Reply with quote
Expensive - budget on £200+ for used, £350+ for new.
Try Penske, hagon, nitron, ohlins etc,. What do model specific forums tend to use?
Cheapest way will be to figure out which shocks will fit from different bikes with better shocks.
Benson_JV
PostPosted: 16:01 - 16 Apr 2013    Post subject: Reply with quote
As Dr Brago said, it will be cheaper to suss out which other (better) shocks from other bikes fit.
For instance, a CBR600RR 03-04 shock will fit a Bandit. Dirt cheap that way, better than dropping £300 on a shock. Mr. Green
PostPosted: 16:04 - 16 Apr 2013    Post subject: Reply with quote
Nitron sport is about the best value. Hagon are a little too cheap and unadjustable, Nitron will make a quality shock for you to your specifications, and are based in Oxfordshire.
https://www.nitron.co.uk/site/products/bike_sport.aspx
anthony_r6
PostPosted: 16:14 - 16 Apr 2013    Post subject: Reply with quote
Grumpy are you a member of the Hornets Nest? Those guys are really knowledgeable on all things Hornet.
But as above, Ohlins and Hagon are good.
yen_powell
PostPosted: 16:24 - 16 Apr 2013    Post subject: Reply with quote
I fitted a Nitron to my bike a few months ago and I'm really pleased with it. I fitted the cheapest one they do but splashed out the extra on a remote pre-load adjuster as my shock is totally buried if you wanted to adjust that part.
XT1200Z and a DR350 in bits
Drake
PostPosted: 17:24 - 16 Apr 2013    Post subject: Reply with quote
my hornet didnt seem that bad tbh. but nitron are your best bet. i will most likely get one for then bandit unless i starting getting into drag racing on it
The Tot
PostPosted: 20:04 - 16 Apr 2013    Post subject: Reply with quote
Hagon ARE adjustable. I had a replacement on my ZX6R. Just like the cheapest Nitron shock, the rebound and compression damping controls are all done on 1 dial. Set and forget, and they're rebuildable. Mine was £260 IIRC. Nitron are very good for the pricepoint as well, so if you want to fork out the extra £80, it might be well worth doing, in addition to doing the oil and seals for the forks as well to give your suspension a full refresh.
Never argue with autism
The last post was made 13 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 60.51 Kb
