| askew |
 askew Scooby Slapper
 Posted: 10:56 - 25 Nov 2004 Post subject: Kill Spills?.... |
I fell quite ignorant asking this, and I'm still not sure why I have never come across, or acknoledged diesel on the road. However, I feel compelled to ask, what exactly is the Kill spills thing all about?
I don't understand why there should be diesel on the road, or the reasoning behind a lorry driver dumping a load of it in the middle of the motorway.
This will no doubt seem like such a retarded question to about 99.9% of everyone that reads this, but any insight would be quite helpful.
Cheers guys. ____________________ What's ya name? What av' ya taken? Chase the lasers, safe as f*ck! |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 11:34 - 25 Nov 2004 Post subject: |
https://www.killspills.org.uk/ have a fairly good description of what they are about. The problem is usually drivers who overfill their tanks, and/or don't put the cap on properly. They go round a roundabout/ corner and the centrifugal force pushes the fuel out of the filling hole so it spills across the road.
Diesel is a very slippery substance, it doesn't evaporate in the same way as petrol, so won't just disappear from the road when it is spilt. The diesel is usually visible as a rainbow streak on the road, particularly visible when wet as it floats on the water, and sometimes noticeable as a petroleum-like smell.
The contact patch which your bike tyre has on the road normally is about the size of a playing card. Tilt the bike over and it becomes even smaller. As a result, the area of crap/ slippery substance which is needed for the tyre to lose grip is not very large. Generally, when the front loses grip, the bike just falls over, sliding away down the road, with you following.
This is also a very good reason not to use the front brake on corners. (I'm 90% certain that both of my lowside incidents have been the result of front brake on crap surfaces). When the back loses grip and slides, the automatic thing for it to want to do is to swap places with the front. Hence if you're leant over and put too much power through the back, it will slide towards the outside of the corner and end up spinning on its side down the road, with you following closely behind.
You might not have seen much diesel perhaps due to where you live meaning that there is a lack of HGV traffic. I know I've only seen diesel once whilst riding, as I was passing the exit of a quarry. Other than that, I've noticed diesel at bus stops primarily, for obvious reasons (start, stop etc making the fuel slosh back and forth in the tank, overfilled tanks spilling over the road).
(An amusing insight to this is that according to a friend of mine, Bentley recommend diesel fuel for lubricating the door hinges on their cars.. )
Other crap surfaces to look out for are gravel, wet leaves, ice and farm muck. Gravel is usually fairly predictably spread at junctions, so with experience you get to know where it is, normally a trianglar shape. It also occurs around the outside of corners I find. Wet leaves where there are trees in autumn. Ice, when it's cold. Beware of shady spots under trees where there hasn't been any sun in the morning, as these have the potential to be icy for a lot longer time than the places where the sun can get to.
On the attachment, turning right into the minor road is how I came a cropper, the gravel was distributed almost exactly like shown in the picture. I have noticed this shape on other junctions too, though I learnt my lesson after the first gravel induced lowside. ____________________ I must not be a troll...
Mmmm, Guinness
| askew |
 Posted: 12:00 - 25 Nov 2004 Post subject: |
Thanks so much, that's incredibly useful. I'm going to be looking down at the ground for entre journeys now searching for some diesel to moan about .
Crikey, you had a low-side going into a junction?! does that mean that you/your bike ended up in the middle of the road you were going towards? Nasty stuff if you ask me.
Thanks again!  ____________________ What's ya name? What av' ya taken? Chase the lasers, safe as f*ck! |
| mchaggis |
 Posted: 12:14 - 25 Nov 2004 Post subject: |
| Ninja |
 Ninja Caption Abuser
 Posted: 13:43 - 25 Nov 2004 Post subject: |
Locked up the front on farmer-giles type mudbath at a junction and carried on about 2 feet into the road...nothing coming at the time, but
yeah - leaves on the road! I've been steering clear (no pun intended) of them just-in-any-case....
touch wood etc now ____________________ James
4 wheels transport the Body ... 2 wheels transport the SOUL |
| pipnet11 |
 pipnet11 Brolly Dolly
| The Tot |
 The Tot World Chat Champion
| mchaggis |
 Posted: 02:59 - 28 Nov 2004 Post subject: |
Here is a good article about the causes, the effects and the ways in which to deal with diesel spills on the roads.
https://www.racfoundation.org/releases/110304rac.htm
| Quote: | How to deal with diesel:
* Firstly, always try to steer around the diesel. If you hit it, keep the bike as upright as possible, maintain a constant throttle and do NOT apply your brakes. If you are cornering, stand the bike up and run a little wider to the other side of the slick.
* Do everything on the bike smoothly, as you would on ice, and you can ride out the other side safely. Remember that there are likely to be more spillages further up the road, so keep a look out.
* If you inform your local council of any spillages, they should get it dealt with. |
Mmmm, Guinness
| m99dws |
 m99dws World Chat Champion
The last post was made 21 years, 324 days ago. Instead of replying here, would creating a new thread be more useful? |
