kmx 200
chad200
PostPosted: 00:17 - 20 Apr 2013    Post subject: kmx 200 Reply with quote
Hi I am currently restoring a kmx 125 with 200 conversion a DIY job gone well so far just after a bit of advice would a kx 125 carb fit straight onto my 200? And this may sound daft but would a fmf shorty tailpipe off a yz 125 fit my kmx with slight changes or is it to much messing around? Any advice would help thanks
_mjs_
PostPosted: 01:01 - 20 Apr 2013    Post subject: Reply with quote
Sick bike bruv. Yeah should all fit together easily, just make sure you use high temp gaffer tape though cos normal stuff will just melt when you start the engine gnome sane?
Seb
PostPosted: 09:22 - 20 Apr 2013    Post subject: Reply with quote
In fairness, if it ends up being close to a real kmx 200 it's worth it, wicked little bikes them Thumbs Up
Back on track, no idea if the carb will actually fit though, suck it and see? Failing that it's time for a lap of the local breakers and more likely ebay.
2010 Triumph 1050 Sprint ST
chad200
PostPosted: 10:05 - 20 Apr 2013    Post subject: Reply with quote
Thanks for the help was in a bad way when I got it the previous owner used a 125 exhaust obs didnt fit so decided he would just ram a sock down the front pipe haha. I also currently own a 00 kmx 125 with racing reeds full gianelli pipe sounds nice. Any more info would b a big help
C.Metcalf
andys675
PostPosted: 19:22 - 20 Apr 2013    Post subject: Reply with quote
kx125 carb is a pwk28, pretty common and std issue on KR1 etc, plenty of copies on ebay
stevo as b4
PostPosted: 15:01 - 21 Apr 2013    Post subject: Reply with quote
I very much doubt any KX125 had a PWK28, maybe a PWK38 on some of them though.
Any carb with the same size inlet spigot should fit the intake manifold, but the hight of some carbs can be an issue, with clearance to the oil pump etc.
The Mikuni VM28/28 TM28 and TM/TMX30 will all fit the std intake manifold. The PWK28 might also fit as i think it's a similar OD on the spigot.
The KX125 carb depending on the year will be anything from 34mm to 36 or 38mm. I'm not sure if they used Mikuni, Kehin or both over the years.
The KDX200 intake manifold will fit the KMX reedblock and allow you to use the Kehin PWK35 carb. The KDX220 inlet will allow the PWK33 to fit.
Other carbs have been fitted to KMX's, but modification or fabrication of a new inlet manifold is normally required.
I'd be quite suprised with a new bracket and maybe a slight amount of cutting down or bending the pipe, that you couldn't get the FMF silencer to fit. It's certainely much less work that getting a different front pipe to fit anyway.
The last post was made 13 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 46.98 Kb
