| Scutter |
 Scutter Two Stroke Sniffer
 Posted: 20:00 - 20 Apr 2013 Post subject: In line 4 compared to V twins ?? |
So I was after opinions regarding the engine characteristics of the in-line 4's compared to V-twins...
The reason being, is that I now have this V Strom 650 and it's the first v twin that I've owned. (Incidentally it's also the first fuel injected bike I've owned.) Anyway, although I love the bike I find that it's much more 'snatchy' than the 4's I've had previously. The throttle seems much more ' on or off' than bikes I've ridden before, and even the 600r that I also still own.
Im aware that I've been away from bikes for some time, so it could well be me, but as I said I don't get it on the 600r. I also wondered if it was something to do with it being FI compared to carbs?
Any ideas?
Thanks. ____________________ Current bike: FJR1300
Previous: SS50, GS50, TS50, GP125, NS125, GSX250, GPZ305, GPz550 81 twin shock, GPZ550 UniTrack, GSX550es, 2x GPZ600r, GPZ1000rx, v Strom 650 GT |
| G |
 G The Voice of Reason
| Scutter |
 Posted: 20:21 - 20 Apr 2013 Post subject: |
That makes sense, as the engine feels very smooth through the rev range, and as long as I'm overly delicate with the throttle it's fine. I was a bit concerned for when I'm going to be carrying a pillion - ill just have to be a bit more careful! Thanks  ____________________ Current bike: FJR1300
| yen_powell |
| c-m |
 c-m World Chat Champion
| _Troy_ |
 _Troy_ World Chat Champion
| colin1 |
 colin1 Captain Safety
| Fowlersrs |
 Fowlersrs World Chat Champion
| stonesie |
 stonesie World Chat Champion
 Posted: 21:38 - 20 Apr 2013 Post subject: |
I'm the other way round, the SV was a snatchy thing but I got used to it in time, the Triumph is lovely and smooth, or it was until I fitted a 1050 throttle tube and still nowhere near as harsh as the SV was.
Granted, it is a later and improved injection system than they used on the Speed Four. |
| Nick_Giles |
 Nick_Giles Could Be A Chat Bot
 Posted: 21:44 - 20 Apr 2013 Post subject: |
My Hornet (carb version) was 'snatchy' at lower revs.
Balanced the carbs ( only one was out of sync ) and that cured it.
Nick ____________________ Peter Cook: "I have learned from my mistakes, and I am sure I can repeat them exactly". |
| G |
 Posted: 22:00 - 20 Apr 2013 Post subject: |
Also - for the 'vast engine braking' - less than a sports 600, I'd say. It's just that the SV is geared lower, so you notice it more.
Had more problems with the R6s locking up or trying to than the SVs when on track.
Never found a curvy SV particular snatchy and I've had five or something as well as having ridden others. They do get lumpy at low revs in a higher gear, but not really the same thing. |
| Scutter |
 Posted: 22:26 - 20 Apr 2013 Post subject: |
The bike is great, the engine very responsive and it revs right through to red line freely, so no issues with it generally. I just find that, for example, when slowing for a junction and then seeing its clear so not stopping and accelerating away it 'snatches' causing the bike to jerk. It seems from most opinions that it's due to less than sophisticated FI - and if that's the case - its fine, I'll adapt. Im still enjoying the bike though - so that's all good  ____________________ Current bike: FJR1300
| Rogue_Shadow |
 Rogue_Shadow World Chat Champion
 Posted: 22:29 - 20 Apr 2013 Post subject: |
The V-Twin on the SV Is a great little engine but the engine braking takes a lot of getting used to.
Getting off the throttle can kill the speed before you intend to, I'm teaching myself to downshift much later in my approach.
If I'm riding towards a junction at 40mph in 4th, a simple blip of the throttle and downshift to 3rd will instantly bring my speed to little more than 28mph. It really took me by surprise at first, but now I know to downshift later and keep the throttle on ... Well a work in progress
I do find the throttle response snatchy, but only in low gears at low speeds. Smooth roll on & off ( Thanks Keith Code )
I imagine other engine configurations like a IL4, would allow the engine to engine brake more progressively / freely.
Might find out one day, till then I'm more than happy with my SV  |
| Scutter |
 Posted: 22:36 - 20 Apr 2013 Post subject: |
Yeah Rogue, the engine braking really takes me by surprise! I back the throttle off and it's like I've grabbed a handful of brake! Much, much different from the IL4's I've had in the past that seem to give loads of over run. I'm glad I asked this now  ____________________ Current bike: FJR1300
| kiddakidda |
 kiddakidda Spanner Monkey
 Posted: 07:51 - 21 Apr 2013 Post subject: |
I had the SFV650 Gladius up until June last year. It was pretty smooth and was not snatchy as I remember.
I do know that Suzuki modified the V Twin engine a little when the released the Gladius. I believe they tweaked the inlet system and the modified engine is in the current V Strom & Gladius.
 ____________________ Suzuki SFV 650 (Gladdy) > Triumph Street Triple R |
| G |
| Teflon-Mike |
 Posted: 12:37 - 21 Apr 2013 Post subject: |
| yen_powell wrote: | I blame the poxy EU making manufacturers do strange things to the fuel mapping to meet over zealous emission tests at certain revs. |
That's pretty much the nub, I think.
But often not so much leaning the fueling map at certain revs, but also over the entire rev-range at fixed revs.
The 'Standards' for engine testing are drafted around testing an engine on an engine brake, rather than a rolling road; so the tests for emmission measurements generally stipulate an engine running at constant rpm, constant throttle, before they sniff the gas mix coming out the exhaust pipe.
On the road, engines don't often run like that, even on a fairly flat, level straight road, like cruising along the motorway, engine speed and throttle will be varying slightly as you maintain following distance or the inclines change.... its 'close' but not identical.
Carburating in the real world, the throttle is changing a lot more widely, the revs changing over the operating range, the 'snatchyness' of some modern fuel injection maps can be in the map-switch from a lean-mix to a richer one, not just between revs, but on 'rates' of throttle opening.
Eg: open the throttle slowly, without revs changing, the map doesn't get as much instant enritchement as if you 'crack' the throttle open.... when you get the same sort of over-rich hesitation, that you can get from doing the same on a 'pumper' carburettor, that is jetted lean, but has a nozzle to squirt a little neat fuel in for acceleration enrichement as the throttle is twisted. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 13 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
