My bike's siezed up :o(
Fallen Angel
Franny the Nanny
PostPosted: 17:13 - 25 Nov 2004    Post subject: My bike's siezed up :o( Reply with quote
Don't know why Confused
Don't know how Confused
But I know it's strange Confused
I threw a sicky at work today and since it was nice and dry desided to take the bike out for a run!
Filled up with oil, filled up with fuel, got about 16 miles and it felt a bit funny and I don't even know what I mean about funny, but it was making a wee noise like metal clunking Confused
I had slowed right down at this point and pulled in and stopped at the side of the road.
Anyway, the engine just cut out - you know the way it sometimes does first thing in the morning before it's warmed up!
And it wouldn't start again, was completely siezed up and the kick start wouldn't start Confused
Can anyone give me any advise or has anyone came across this before? Confused
The guy from the AA came and towed the bike home on a trailer and he said he thinks it might be the top end of the engine (pistons Confused) that have siezed up, but he's not sure why that would happen if there's oil in it etc. he didn't look at the bike or anything! Just towed me home - not really sure if they are meant to try and fix it, but the other half seems to think they are! Confused
I'm a bit gutted and hope it's nothing too serious!!! Sad
Was very impressed at loads of people stopping to ask if I was okay! Thumbs Up
Any advise would be much appreciated!
Fran Thumbs Up Karma Thumbs Up
I have an asshole tolerance level of -10 Twisted Evil
Mr. Green Dance! Mr. Green www.cliqueyclanmcc.co.uk Mr. Green Dance! Mr. Green
www.bebo.com/fallenangelfran
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Fallen Angel
Franny the Nanny
PostPosted: 17:25 - 25 Nov 2004    Post subject: Reply with quote
No it's completely seized up, won't kickstart at all - nothing, not a sausage!!!
tatters
Exxon Valdez
PostPosted: 17:28 - 25 Nov 2004    Post subject: Reply with quote
your looking at a top end rebuild, at leased a new over sized piston and rings, re-bore of the cyclinder, gaskets. single cyclinder two strokes are the easyiest to re-build so you could do it your self as part of a learning experance.
Fallen Angel
Franny the Nanny
PostPosted: 17:30 - 25 Nov 2004    Post subject: Reply with quote
What kind of money would we be talking about if we were to get this done at a garage CPL?
tatters
Exxon Valdez
PostPosted: 17:34 - 25 Nov 2004    Post subject: Reply with quote
about £200-300 labour maybe.
piston kit £60-70
re-bore £60? (iron cast cyclinder so no niksol plating)
gaskets £30
possably (small end bearing)
thats if the cyclinder head/con rod/crank is ok
Fallen Angel
Franny the Nanny
PostPosted: 17:42 - 25 Nov 2004    Post subject: Reply with quote
Shocked So you're talking £500 at least!!! Shocked
Do you reckon this could have anything to do with us de-restricting it a couple of weeks back??
tatters
Exxon Valdez
PostPosted: 17:43 - 25 Nov 2004    Post subject: Reply with quote
at a garage yer, re-builds are expensive. you could always get a second hand engine of ebay for about £100
Fallen Angel
Franny the Nanny
PostPosted: 17:46 - 25 Nov 2004    Post subject: Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad
cagiva gezzer
PostPosted: 17:53 - 25 Nov 2004    Post subject: Reply with quote
Umm, this might go over your head, but did you alter the jetting when you de-restricted it Question Question
tatters
Exxon Valdez
PostPosted: 17:55 - 25 Nov 2004    Post subject: Reply with quote
don,t think its need for NS de-restriction, just a guess but did file and clean up that warf around the exhaust manfoil.
only way to really find out that caused the seizer is to strip the top end
Fallen Angel
Franny the Nanny
PostPosted: 17:57 - 25 Nov 2004    Post subject: Reply with quote
Has gone over my head, but don't think we altered anything Confused
Fallen Angel
Franny the Nanny
PostPosted: 18:01 - 25 Nov 2004    Post subject: Reply with quote
Cleaned all the crap up, but didn't file the bits down completely 'cause we didn't have a file, we were going to get one this weekend and file it down then!!
Why??? Embarassed Could that have caused the problem?? Embarassed
cagiva gezzer
PostPosted: 18:04 - 25 Nov 2004    Post subject: Reply with quote
Prices - https://www.davidsilverspares.co.uk/index.html
cylinder/piston £99
gaskets £12.50
Rings £22
Small end bearing £?? (~5)
When i bike is derestricted, you normally have to increase the jetting to allow more fuel through the engine. If you don't increase the jetting, the engine runs too lean and overheats. This can cuase bits to melt/snap/seize.
For example, a cagiva engine has to be upjetted by 10 (from 110-120 i think..) when derestricted.
Not sure about a NS, but common sense says you should have to. Pull the plug out and see what it looks like.
The rebuild is not that hard. A matter of 10 or so nuts and bolts and a bit of common sense. If you managed to de-restrict it, than you can re-build it!
Fallen Angel
Franny the Nanny
PostPosted: 18:12 - 25 Nov 2004    Post subject: Reply with quote
Thanks for that vote of confidence Wink !!! But we might not have de-restricted it properly, ie. alter the jetting, so we might in fact have fucked it up!!!!! Rolling Eyes Embarassed
PostPosted: 18:50 - 25 Nov 2004    Post subject: Reply with quote
Oh dear, another NS gone pop. Sad
The exact same thing happened to mine. I decided it would be easier to source a complete (running) engine from a breakers.
Ended up buying the complete lump for £170 (delivered) and something like £100 to have it fitted by a local mechanic.
They are quite rare and hard to track down but if you can find one, it could be a fair bit cheaper than rebuilding with new parts.
Good look, Angel. Smile
Aprilia RSV Mille R Edwards Replica - Aprilia RS250 - Suzuki GSXR600 Supersport Race Bike
PostPosted: 18:55 - 25 Nov 2004    Post subject: Reply with quote
Normally should the top end seize up then it is a heat seizure. Basically the piston gets too hot and expands so that it is too big to fit in the bore. Can easily wreck the top end of the engine. However every time this has happened to me (loads of times) the engine has freed itself off when it cools down, often within a minute or so. Depending on the damage they will often start then (if the rings are OK) although it might well rattle like hell, but not always.
The only time I have had an engine seize and stay seized was from a failed main bearing. On this occasion the cage (the metal or plastic bit that holds the balls in position in the bearing) broke and jammed.
Neither are going to be that cheap to fix. Cagiva Geezers prices are about the best you are going to get for the top end. The bottom end prices might well be cheaper (eg, doubt a pair of main bearings are much over £20 from Honda) but it is a lot more work to fix. A new barrel and piston is easy to fit, and the manual should show you how easy.
First thing I would suggest is to take the top end off the engine. If you take the bolts out and the barrel slides off then it is almost certain it is the bottom end. If it is the bottom end then it will either be the big end bearing or the main bearings (gearbox bearings are possible but then they would not affect the kick start if the clutch was pulled).
While a dealers rebuild bill might well be quite expensive you can save yourself a substantial amount by taking the engine out yourself, and once the work is done replaceing it yourself. This might well knock well over £100 off the bill. Dropping the engine out is not difficult, just takes a bit of time. Make full use of your digital camera to take pics of where everything comes from.
For a very rough idea we had an RS50 engine rebuilt recently (not my bike and I did not fancy trying to do the bottom end myself) at £265. That was for a new big end bearing, main bearings and a piston (big end bearing had broken up, and I think one of the rollers from it had got into the barrel and turned the top of the piston into a scale model of the moons surface). That was with me taking the engine out of the bike and dropping it in.
ZRX61
Victor Meldrew
PostPosted: 20:38 - 25 Nov 2004    Post subject: Reply with quote
Ok, hold on a minute there Oppenheimer...
1: Why on earth would anyone want to pull the engine out to remove the head & cylinder??
2: Just buy the parts you need & take just the rings, piston & cylinder to the machine shop & have it re-bored. Rebore shoukldn't be more than 30quid tops for a single 2squeek.
3: Do NOT buy the piston etc until you have removed the old one so you can check if it has been rebored before.
4: If possible: Do not buy the OEM piston etc, go with Mahle, better quality & cheaper.
Removing all the parts shouldn't take more than an hour, ditto on reassembly.
Fallen Angel
Franny the Nanny
PostPosted: 20:49 - 25 Nov 2004    Post subject: Reply with quote
UPDATE
Right you lot of mechanically minded genius's (or should that be geniusi Confused)
Anyway, just been down to have a look at the bike. The kickstart was still seized but released itself after semi-bump-starting it and releasng the clutch. Now the kickstart has full freplay, but the exhaust backfires when trying to kickstart and bump-start! Confused
If you put in gear with the clutch in and then push the bike letting the clutch out gradually when you pull the clutch back in the engine take a moment or two to disengage, rather than doing it automatically Confused
Just for the sake of it, we checked the spark plug and it looks absolutely fine, not too rich or too lean! Dunno if that makes any difference or not.
Does this enlighten any of you??? I hope so!
PostPosted: 21:47 - 25 Nov 2004    Post subject: Reply with quote
I must admit, I would also be wanting to strip the top-end. You aren't really going to know what to do until you can have a look in there.
It is not a difficult job, you can follow it through from the workshop manual. I did my first top-end without even the benefit of an english language manual.
You will need a Gasket set, a piston + ring kit and possibly new small end bearings. Last rebore I had cost me 15 quid.
It will cost you nothing to take it apart and have a look, only then can you assess what has gone wrong. If it is something more fundamental then so be it, nothing you can do about it now.
Assuming it is a simple top-end seizure/broken ring, if you do it all yourself, I would be surprised if the parts came to 100 quid.
binge
Emo Kiddy
PostPosted: 00:06 - 26 Nov 2004    Post subject: Reply with quote
Well because the piston has flaked away on my scooter, mechanic at barneys bikes is doing a full engine rebuild (cos the bottom end needs cleaning out) and replacing the whole cylinder and piston and its cost me £120 for a new PM tuning cylinder and £250 labour... I mean fucking hell the whole ped is only worth double that...
Ben...
PostPosted: 00:54 - 26 Nov 2004    Post subject: Reply with quote
The NS uses a plated bore so cannot be rebored. They can be replated but that will cost around £100 + a piston, so a new one from David Silver spares is probably a fair bit cheaper.
Given what you have said I am still not sure where it has seized.
Anyway, not sure how much you know about which bits are where but thought some pics might help.
These are from an early Aprilia engine (have a few spare ones floating round in the garage), but it is fairly similar to the NS engine.
Fairly obvious one, but this is the piston (no rings fitted to this one). You need to make sure this goes in the right way. Normally there is an arrow on the top pointing to the side that goes on the exhaust port side.
https://www.alfa-pages.co.uk/TempPicture/Img_2810.jpg
This is the crankshaft. The white bit is a slieve around one of the main bearings (the other one is still in the crankcase half). The connecting rod is pointing out to the right. The big end bearing lives where the conrod joins the crankshaft.
https://www.alfa-pages.co.uk/TempPicture/Img_2813.jpg
Here you can see the main bearing. You can see the balls in it, and that there is a metal cage locating them.
https://www.alfa-pages.co.uk/TempPicture/Img_2814.jpg
Here is the big end bearing. This is normally a roller bearing on a 2 stroke.
https://www.alfa-pages.co.uk/TempPicture/Img_2815.jpg
Pair of crankcase halves. This are pretty much bare here, with the clutch and everything else removed.
https://www.alfa-pages.co.uk/TempPicture/Img_2816.jpg
Inside of one crankcase half. The section to the left (which is cleaner) is where the gearbox lives. the smaller dirtier section to the right is where the crank lives. The other main bearing is visable in here in this picture.
https://www.alfa-pages.co.uk/TempPicture/Img_2817.jpg
This is just the other crankcase half.
https://www.alfa-pages.co.uk/TempPicture/Img_2818.jpg
This is how the crank fits into one crankcase half.
https://www.alfa-pages.co.uk/TempPicture/Img_2819.jpg
This is the barrel, with the head, reed block and carb rubber in position.
https://www.alfa-pages.co.uk/TempPicture/Img_2820.jpg
As above but with the head off.
https://www.alfa-pages.co.uk/TempPicture/Img_2821.jpg
This is the carb rubber. This connects the carb to the barrel (on this engine, on some engines the carb connects through one of these to the crankcases).
https://www.alfa-pages.co.uk/TempPicture/Img_2822.jpg
This is the reed block. This is basically a one way valve to allow fuel / air from the carb into the crankcases, but not back out again. There is basically a metal block with some thin plastic reeds and a couple of thicker metal plates to prevent the reeds bending too far.
https://www.alfa-pages.co.uk/TempPicture/Img_2823.jpg
Other side of the reed block.
https://www.alfa-pages.co.uk/TempPicture/Img_2824.jpg
Picture of the barrel from below.
https://www.alfa-pages.co.uk/TempPicture/Img_2825.jpg
Obvious one really. Piston half into the barrel.
https://www.alfa-pages.co.uk/TempPicture/Img_2826.jpg
Picture of one crankcase half with the crank, barrel, head, reed block and carb rubber in place.
https://www.alfa-pages.co.uk/TempPicture/Img_2827.jpg
Hope this makes things a bit clearer.
Fortuna
PostPosted: 01:14 - 26 Nov 2004    Post subject: Reply with quote
They have a Nikasil barrel and an aluminium piston.
In the years I owned my bike it needed 2 rebuilds. The pistons are stupidly cheap and you can get reconditioned barrels if it has done the worst.
They are very easy to rebuild, hey I'd help but I live miles away.
The NS125R is restricted by being "choked" in the exhaust as you discovered, and to be honest I never had any problems after I derestricted most where before. You shouldn't have to re jet as it is running in effect how it was meant to.
Make sure you have enough water as even though it's colder they can still overheat.
Sadly I can confirm your worst fears that it's most likely a seized top end.
9 times out of ten it's usually worn rings that have broken causing the seizure.
What year, how long you had it and when was the last rebuild? The NS125R is fast, but sadly known for blowing up.
PostPosted: 02:29 - 26 Nov 2004    Post subject: Reply with quote
Holy crap etc. That is one detailed post.
Do not be put off by that FA, the chances are that you will only have to remove the cylinder head and barrel unless something has gone badly tits-up. I am not familiar with your bike but you are unlikley to have to take the engine out of the frame.
Never the less, those piccys should give you a good overview of how the engine all fits together, if you can get your head round how it all works, it is easier to understand what you are doing when you strip it.
scott
tatters
Exxon Valdez
PostPosted: 09:21 - 26 Nov 2004    Post subject: Reply with quote
Sorry thinking of AR125 (iron cyclinder) Doh! , of course if the NS250r and NS400r have plateing so the ns125r would.
The last post was made 21 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 156.47 Kb
