QUICK HELP PLEASE!
Baller
PostPosted: 20:13 - 25 Nov 2004    Post subject: QUICK HELP PLEASE! Reply with quote
Day before test and the back brake on my Yamaha SR 125 won’t release its self !
I have to release the brake by flicking up the pedal to go again.
When the back brake is pressed it won’t let go.
Help what I can do.
Sad
Baller
PostPosted: 20:24 - 25 Nov 2004    Post subject: Reply with quote
please help i`ve only got 1-2 hours
PostPosted: 20:28 - 25 Nov 2004    Post subject: Reply with quote
Slightly daft suggestion, but have you actually checked if the spring which makes it go back up is still there and correctly attached as if it was missing then it would do what you describe.
ts50x0
PostPosted: 20:29 - 25 Nov 2004    Post subject: Reply with quote
if its adisc brake the calliper just needs taking apart and cleaning, but it might take a bit longer than that,
if its a drum brake then the cable is getting stuck somewhere and you need to locate the point and find out whats causing it, could be a number of things.
good luck!
Baller
PostPosted: 20:40 - 25 Nov 2004    Post subject: Reply with quote
drum and rod connection, no cables
mchaggis
PostPosted: 20:49 - 25 Nov 2004    Post subject: Reply with quote
No springs along the rod? If there aren't any, how long has the brake been doing it? Either it's not properly adjusted or something has gone ping inside. The springs inside the brake to pull the shoes away from the drum are pretty strong.
It sounds as though you will need to take the rear wheel off and make sure everything is still in place inside the drum.
I must not be a troll...
Mmmm, Guinness
Baller
PostPosted: 21:14 - 25 Nov 2004    Post subject: Reply with quote
thanks im taking the rear wheel off now
Frost
PostPosted: 06:13 - 26 Nov 2004    Post subject: Reply with quote
Used to happen alot on my old CB. i took the spring off and stretched it a great deal to get it to return, And adjusted the rear brake rod to make the brake stay completly off when the peddel isnt pressed.
This only worked for a short period of time before i have to take out the back wheel, dismantle the drum, clean it out, file the edge on the brake shoe, and stretch and lube the springs. After that it worked perfectly for as long as i owned the bike.
If you need a quick fix just use force to release the brake and ride using just the front brake. But dismantling the drum is the only long term solution.
8316
PostPosted: 11:20 - 26 Nov 2004    Post subject: Reply with quote
or dont use the rear brake....
Now own a Fireblade!! Speed Limits? Bah!
mchaggis
PostPosted: 13:52 - 26 Nov 2004    Post subject: Reply with quote
For which you will get minors, and could fail the test for if the examiner is feeling particularly strict.
Mmmm, Guinness
The last post was made 21 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 63.59 Kb
