chain master link
flumpy7
PostPosted: 20:06 - 22 Apr 2013    Post subject: chain master link Reply with quote
Hi all
I fecked up the rivets on my new chain master link today...is a new master link likely to be universal as long as its for the right size chain? Ive got the x rings from the link I bodged up.
2012 Sinnis apache
stickybackbob
PostPosted: 20:13 - 22 Apr 2013    Post subject: Reply with quote
Size should be stamped on the chain e.g. 525 Should be able to get another link easy enough. How did you muck it up?
flumpy7
PostPosted: 20:49 - 22 Apr 2013    Post subject: Reply with quote
I need a link with hollow pins....my riveter is just a ball bearing press and I couldnt get it dead centre of the pins and they just got mashed. So do all chains have the same shape links?
2012 Sinnis apache
flumpy7
PostPosted: 20:50 - 22 Apr 2013    Post subject: Reply with quote
2012 Sinnis apache
Islander
PostPosted: 20:58 - 22 Apr 2013    Post subject: Reply with quote
Find one that matches your chain on here:
https://www.wemoto.com/parts/chain_link/
stickybackbob
PostPosted: 21:03 - 22 Apr 2013    Post subject: Reply with quote
Never come across hollow pin split links but a quick google search seems to point to push bike chains.
I'm no engineer but somehow doubt that hollow pins would be ideal on a motorcycle chain - could be wrong though.
When I replace chains, I usually use the two hammer method to peen the exposed edges of the pins. Never had a failure yet in over 20 years of riding/maintaining Smile
If you're not sure of your chain size, this site may be useful https://www.sprocketsunlimited.com/Chainspecifications.html
yen_powell
PostPosted: 06:37 - 23 Apr 2013    Post subject: Reply with quote
Get one from the same manufacturer. I once saw my mate cut a 525 chain to put a new link of the same size on, only to find it wouldn't fit.
XT1200Z and a DR350 in bits
flumpy7
PostPosted: 08:11 - 23 Apr 2013    Post subject: Reply with quote
They definitely exist!
https://www.ebay.co.uk/itm/DID-525-VM-X-Ring-Hollow-Soft-Rivet-Link-Lube-/360381803813?pt=UK_Motorcycle_Parts&hash=item53e86ded25
The tool I've got will only really work for that type of link so I've discovered.
2012 Sinnis apache
flumpy7
hmmm that's what I was worrying about.... so they're not universal then?
2012 Sinnis apache
yen_powell
PostPosted: 11:31 - 23 Apr 2013    Post subject: Reply with quote
I think that although the pitch will be the same, pin diameters can vary according to chain grade. In the case I mentioned the pins were too large on the rivet link to go through the holes in the side plates on the chain.
Islander
PostPosted: 12:04 - 23 Apr 2013    Post subject: Reply with quote
Wemoto stock a large range and will probably have the right one for your chain in stock. Thumbs Up
DrDonnyBrago
PostPosted: 12:48 - 23 Apr 2013    Post subject: Reply with quote
DID soft links have a hollow tip.
This is flared by the chain tool which has a ball shaped end on it.
Can't confirm the diameter of the pins though.
flumpy7
PostPosted: 15:55 - 23 Apr 2013    Post subject: Reply with quote
Thanks guys. Took a punt on an RK master link with hollow tipped ends. The shop guy said he couldn't guarantee the pin size would fit but it did! Sound.
2012 Sinnis apache
The last post was made 12 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 76.27 Kb
