Triumph Bonnie 2004 800cc
Ariel Badger
PostPosted: 19:39 - 22 Apr 2013    Post subject: Triumph Bonnie 2004 800cc Reply with quote
Any one worked on one of these? I am thinking of getting one and turning it into a fast sprint bike. The motor is very soft as standard but that leaves a lot of room for tuning. Tell me what is available and how many horses can I get in the stable? How strong is the bottom end, would it take a turbo or not?
Ariel Badger
PostPosted: 22:47 - 22 Apr 2013    Post subject: Reply with quote
Ok, I guess this is not within the BCF knowledge base so I have asked the same on a Triumph forum. What attracts me to this project is its historical precedence, in the 60s if you wanted to go fast you used a Bonnie and I want to do that again with a Hinkley bike.
PostPosted: 23:24 - 22 Apr 2013    Post subject: Reply with quote
Just get a GSXR1000 and some 'bonnie' stickers .. spend your time riding Wink.
Drake
PostPosted: 04:58 - 23 Apr 2013    Post subject: Reply with quote
speak to bob farnham. big bore kit your cams and skimming and port work. dads efi is on the dyno at the moment. he has junked all the emissions stuff. oh and you hsve the hairier cams. will let you know what his is doing
Ariel Badger
PostPosted: 06:29 - 23 Apr 2013    Post subject: Reply with quote
Where is the challenge in that? Every one is riding a GSXR or a Bussa, I want to pay homage to the 60s tradition of using a Triumph motor and there is plenty of room for improvement in that motor.
PostPosted: 06:30 - 23 Apr 2013    Post subject: Reply with quote
You don't want Bob Farnham... You want Tony Scott!
https://www.t3-racing.co.uk/custom.html
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
P.
PostPosted: 06:38 - 23 Apr 2013    Post subject: Reply with quote
Another vote for T3... having seen them work on some stuff in there race prepping Daytonas and Street Triples to over 140hp, I'd be well up for them playing with my bike Laughing
YBR Ric
PostPosted: 08:41 - 23 Apr 2013    Post subject: Reply with quote
https://www.triumphrat.net/twins-technical-talk/92225-1087-cc-big-bore-kit-dyno-run.html
The motors will handle the power, just depends how much you want to spend!
PostPosted: 09:02 - 23 Apr 2013    Post subject: Reply with quote
The challenge would be in the Riding Wink.
Though, if you're talking about Drag Racing, fair enough - as sure there is certainly some 'skill' in it and it's fun enough to do, but not that fun without corners, never mind that they won't run with teeniest bit of moisture on the ground. And if you're not - go ride a Busa around a twisty course and see where the Challenge is Wink.
Ariel Badger
PostPosted: 17:09 - 23 Apr 2013    Post subject: Reply with quote
I just want a straightliner, drag strips are very enjoyable!
PostPosted: 17:57 - 23 Apr 2013    Post subject: Reply with quote
While I do appreciate the skill in a good launch, especially if there isn't a big queue when you're done - I'm not convinced, personally.
Would like to try a proper 350hp+ turbo bike, but suspect I'd get used to that pretty quickly too.
Ariel Badger
PostPosted: 21:50 - 23 Apr 2013    Post subject: Reply with quote
A great deal of the pleasure I get from riding a bike is building it and defying the manufacturer's intentions by making it run fast! This satisfies something very deep within my DNA, as a Brummie I am genetically programmed to tinker with bike engines.
moonzoomer
PostPosted: 22:36 - 23 Apr 2013    Post subject: Reply with quote
Good luck with the bonnie but that is one heavy lump of an engine and a lot of mass to get on the move, what about the 800cc BMW vertical twin which is barely wider than a single and would probably tune a lot better?
Ariel Badger
PostPosted: 22:43 - 23 Apr 2013    Post subject: Reply with quote
I am looking at Triumph because one is up fo grabs if I can get a price but yes the BMW is a superb motor. A stock Beemer ran about 8.6 this weekend Twisted Evil
PostPosted: 22:45 - 23 Apr 2013    Post subject: Reply with quote
Erm, over a quarter mile Confused.
I know the S-RR is fast and can probably get in the 9s with some straps, but that is a tad silly-quick.
If not, what distance?
moonzoomer
PostPosted: 22:55 - 23 Apr 2013    Post subject: Reply with quote
The motor is lazy @86mm (b) x 68mm so things could be done, a flatter cam and a better overlap on the valve timing would help it rev a bit harder. The bottom end seems very well made and up to the job and old skool carbs could be fitted easily methinks. Go for it.
Drake
PostPosted: 04:45 - 24 Apr 2013    Post subject: Reply with quote
if he get a 790 he will already have the good set of cams. if he wants more its regrind time
Raffles
PostPosted: 07:04 - 24 Apr 2013    Post subject: Reply with quote
Will you be changing your name to Bonnie Badger?
Nick_Giles
PostPosted: 10:46 - 24 Apr 2013    Post subject: Reply with quote
Not sure this choice of machine is the best one even if the bottom end is beefy enough.
I may be wrong but ain't that a an engine that uses push-rods to operate the valves and not an over head cam setup.?
If so would there not be a danger of 'valve bounce' at high revs.? Resulting in at best considerable loss of power and at worst turning the whole contraption into a plate of spaghetti. Crying or Very sad
Nick
Drake
PostPosted: 11:26 - 24 Apr 2013    Post subject: Reply with quote
double over head cam. cam chain runs from crank to idler in the head then the cams run off gears. also for more midrange you advance the inlet up by one tooth
Drake
PostPosted: 11:30 - 24 Apr 2013    Post subject: Reply with quote
also a thruxton cdi lifts the rev limiter up by 500rpm iirc
Drake
PostPosted: 11:32 - 24 Apr 2013    Post subject: Reply with quote
stevo as b4
PostPosted: 12:43 - 24 Apr 2013    Post subject: Reply with quote
What kind of power are you looking for for the bike or the sprint class it would be running in etc?
It would seem that without doing anything to the bottom end that an 865cc twin with a big bore kit and all the usual tuning work on top can make about 90-95bhp at the crank or 80-85bhp at the back wheel. I bet with the right tuning and parts that a big bore motor has 100bhp potential and not become unreliable.
If i were wanting to tune a Triumph for racing though, id much rarther start with the original speed triple motor or the 1200cc 4pot. They are both heavy engines, but are also understressed and can make good power gains over std. I've heard of 1200cc Daytona engines making over 160bhp with big flat slide carbs, cams and headwork etc.
If you get the twin at the right price thats a good enough reason IMO to use one of them. I like the whole idea of use what you've got more than buying a competetive machine to start with.
I wonder as an alternative approach waht you get safely get from the Triumph twin with forced induction? i'd guess at least 110bhp? Just for my curiosity can you explain what if any effect this would have on the classification system for sprinting?
i.e would it put you into a bigger cc class having forced induction, or up against turbo'd 4cyl engines like an anything goes kind of class?
Ariel Badger
PostPosted: 18:04 - 24 Apr 2013    Post subject: Reply with quote
stevo as b4 wrote:
Some good stuff!
Thank you, you see my vision, I would enter it in class 8, 750-1000 cc racing.
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 124.5 Kb
