speedo
mickwuk
PostPosted: 08:13 - 24 Apr 2013    Post subject: speedo Reply with quote
i have a cb500s and speedo was not working checked the cable and it had snapped near the speedo end bought replacement and fitted it but is still not working feeling in the gap to the speedo where the cable screws in i can feel what seems a spindle is this supposed to be there or is this where the cable snapped a second time sorry this seems a silly question but i am not that technicaly minded
Islander
PostPosted: 09:12 - 24 Apr 2013    Post subject: Reply with quote
Make sure the inner of the cable is properly seated at both ends. Thumbs Up
Hetzer
PostPosted: 09:17 - 24 Apr 2013    Post subject: Reply with quote
Did you take the broken bit out of the speedo before fitting the new one?
mickwuk
PostPosted: 15:19 - 24 Apr 2013    Post subject: Reply with quote
i found a broken bit in the cable its self but as i say putting my finger in the hole were the cable goes i can feel what is either a spindle or part of the cable broken and stuck in there should there be nothing there allowing the cable to push in ?
mickwuk
PostPosted: 17:35 - 24 Apr 2013    Post subject: Reply with quote
Vincent wrote:
Usually the inner cable is square at the speedo head end and just pushes in when lined up with the corresponding square shaped hole. Might be an idea to remove the speedo so you can have a good look at what's going on.
ok thanks
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 47.15 Kb
