outer race of front wheel bearing stuck in hub.
PostPosted: 13:17 - 24 Apr 2013    Post subject: Reply with quote
Got a MIG welder?
Run a ring of weld around the inside face of the shell. This will then contract and cool and pull the race inward and hopefully pop out.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
damienbish
PostPosted: 13:56 - 24 Apr 2013    Post subject: Reply with quote
Had this happen to me recently.
Everyone was trying to tell me I wasn't doing it right and there was no way it could be that stuck.
They changed their tune after having a go. As a last resort been as I didn't have access to a welder we cut dremmel slots and tried to use a chisel to get it out. Even after cutting all the way through the race and using a chisel bits just sheared off but as a whole it looked like a piece of the hub!
Ended up ebaying a second hand wheel. Only cost as much as the bearings did in the first place!
lihp
PostPosted: 14:39 - 24 Apr 2013    Post subject: Reply with quote
Hydraulic Press is your friend.
lihp
PostPosted: 15:00 - 24 Apr 2013    Post subject: Reply with quote
Front or back wheel?
lihp
PostPosted: 15:07 - 24 Apr 2013    Post subject: Reply with quote
no problem. Only need the front when you stop Laughing
Is there a lip on the inside of the bearing or is it flush against the stop?
If you can get on the lip, I have a bearing puller that would get it out.
lihp
PostPosted: 15:43 - 24 Apr 2013    Post subject: Reply with quote
Let me know if you get stuck. My puller should work but will require you to remove the opposite disc
MaybeGuy
PostPosted: 16:57 - 24 Apr 2013    Post subject: Reply with quote
have you taken the circlip out? lol if you haven't.
Anyway, get a socket the same size as the outer race and just wallop it.
stocksmenace
PostPosted: 18:29 - 24 Apr 2013    Post subject: Reply with quote
had the same problem didn't have a burner so i had to figure another way to do it...myself and cheap ....no cutting or burning involved and took 10 mins.....here is the video hope it helps
Thumbs Up Thumbs Up
https://www.youtube.com/watch?v=nvZ069bTTME&list=UUmWypgW7miqv35lAo8nH-jA&index=2
Triumph Sprint 900..Prev-ZZR600-Derbi terra-Mz251-Hyo Aquila
temeluchus
PostPosted: 19:13 - 24 Apr 2013    Post subject: Reply with quote
Most fail comment in history of BCF.
Chalky.
PostPosted: 20:59 - 24 Apr 2013    Post subject: Reply with quote
Woll is more man than you.
Chalky.
PostPosted: 21:10 - 24 Apr 2013    Post subject: Reply with quote
Rob Fzs wrote:
That he is, or moar ham fisted with the hammer
Lanky powahhh
Islander
PostPosted: 21:50 - 24 Apr 2013    Post subject: Reply with quote
Nah. Jivebunny would consider that a goer. Laughing
SQL
PostPosted: 22:25 - 24 Apr 2013    Post subject: Reply with quote
Rob Fzs wrote:
https://i825.photobucket.com/albums/zz176/robyarr/317476_10200513167965990_1009208772_n_zps63945f99.jpg
abit fucked likeeee
pfffttt repack with grease it will be fine
don't do this
The last post was made 12 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 117.67 Kb
