Finding neutral on CBR125
Fowlersrs
PostPosted: 19:00 - 24 Apr 2013    Post subject: Finding neutral on CBR125 Reply with quote
This might seem like an odd question to ask but picked up a cbr125 last night for the mrs, nice tidy little bike, so simple it beggars belief but I have a question..
Something im really puzzled by is at a standstill it hates going into neutral from first gear? Is this normal?
If I ride it down the road I can change up lovely and then down from second to neutral quite easy, then when I coast to a stop it sits in neutral, but if I go down to first and then stop, try and engage neutral it doesnt want to play ball??
Is this something thats particular to 125's? or am I missing something? All my road bikes have never done this... need to brief the mrs on this if thats the case!!
I did have to tighten the cable slightly to move the biting point closer to the bars as to start with I almost had to let the lever right out to go anywhere, now it just this puzzling me?! Is this normal and should I leave it alone?
PostPosted: 19:04 - 24 Apr 2013    Post subject: Reply with quote
Release the lever a bit and rev to a few thousand rpm whilst holding the selector to go into neutral, if it works and just slips in, change the oil and adjust the cable.
Fowlersrs
PostPosted: 19:10 - 24 Apr 2013    Post subject: Reply with quote
So it definately doesnt sound right to you then mate? I have tried slipping it a bit but the gear lever is real stiff in first I dont wanna force it, I wonder if its the cable and its not engaging properly?
At the engine end of the cable there are 2 nuts on a spindle that attaches to the mechanism that engages the clutch, should I be winding them down or up? Embarassed
PostPosted: 19:14 - 24 Apr 2013    Post subject: Reply with quote
Bikes won't go into neutral very well if the chain is too tight. This is often the cause of problems as you describe.
Fowlersrs
PostPosted: 19:18 - 24 Apr 2013    Post subject: Reply with quote
Into neutral from first or from second as well? Il check that tomorrow!
PostPosted: 19:20 - 24 Apr 2013    Post subject: Reply with quote
Easier from 2nd than 1st.
Slack or stupidly loose on the Vara makes it impossible.
From the umpteen CBR125s I've had, it sounds normal to a degree, but usually its just a fettling of the clutch cable and oil ... or in this case also, the chain Laughing
Fowlersrs
PostPosted: 19:26 - 24 Apr 2013    Post subject: Reply with quote
Ok cool, in terms of the clutch cable, how do u find the correct adjustment? The clutch lever, whilst it works there doesn't seem to much tension when u let go of the lever? It returns out ok but I dunno, maybe I'm just use to the feel of a hydraulic clutch?!
Turkish
PostPosted: 20:25 - 24 Apr 2013    Post subject: Reply with quote
If you can't get it in by rocking back and forward, slipping the clutch or revving, and the gear lever is really stiff then it's the lever adjustment.
With the lever fully returned (out), you should not be able to pull it in more than 5-10mm before feeling resistance. If it moves more than this the cable is way too slack. Measure from the ball end.
ZX-6R G2
CBR125R RW6
anthony_r6
PostPosted: 20:30 - 24 Apr 2013    Post subject: Reply with quote
When my bike doesn't slip in at a stand still I just roll it forward a few mm and it'll go in after that.
Fowlersrs
PostPosted: 20:32 - 24 Apr 2013    Post subject: Reply with quote
I think this is what it sounds like, there is no real resistance hence why I guess the clutch isn't disengaging?!
So with the nuts at the engine end which way do I turn them to tighten it up so to speak, do I wind them down the threaded shaft or up it?! Could it be it's already tightened to its max and I need a new cable?!
Fowlersrs
PostPosted: 20:34 - 24 Apr 2013    Post subject: Reply with quote
It's definaty not that mate, I do that with my offroad bike but this is resistance inside the box, feels like the clutch isn't fully disengaging?!
Turkish
PostPosted: 20:43 - 24 Apr 2013    Post subject: Reply with quote
Wind them down the shaft so more thread is showing. If the nuts fall off you've ran out of adjustment Laughing . You can take the slack up at the lever end as well though.
ZX-6R G2
CBR125R RW6
Fowlersrs
PostPosted: 20:47 - 24 Apr 2013    Post subject: Reply with quote
I think we could be making progress here, looking at them tonight theres already quite a bit been wound down so the cable is obviously stretched, is it relatively easy to fit a new one, does the lever action purely just pull the mechanism on the engine end? Is that it?
I see cables are only a tenner!
Turkish
PostPosted: 22:03 - 24 Apr 2013    Post subject: Reply with quote
Yep that's it. Should be straightforward to thread a new cable in, just make sure you lube it properly so it lasts Wink.
I would definitely try adjustment first though. For the sake of a few turns of a spanner you don't have anything to lose.
ZX-6R G2
CBR125R RW6
Fowlersrs
PostPosted: 12:12 - 25 Apr 2013    Post subject: Reply with quote
UPDATE:
Right I've adjust it at the engine end and it's made the changing gear side of things smooth as a babies bum, no problem with first or anything.
However with the adjustment on the lever part I have it wound as close to the bars as I can get it but the biting point is still quite a way out, is this just that the cables stretched and a new one would bring the biting point closer to the bar?!
The last post was made 13 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 85.48 Kb
