Ratchet straps
fozzym
PostPosted: 20:35 - 24 Apr 2013    Post subject: Ratchet straps Reply with quote
Hey guys,
Talk to me about ratchet straps!.....I've just bought a trailer and need to get sorted with straps to tie the bike down when I take it for track days.
I've had a look round on websites and ebay and to be honest there are that many to choose from its bewildering. You can pick up cheap ones for a couple of quid or expensive ones for 20 or 30 quid.
Recommedations welcome as is advice on the best way to tie the bike down, I've noticed Oxford do straps that slip over the handlebars ....good idea or not??
Cheers everyone.
Raffles
PostPosted: 20:59 - 24 Apr 2013    Post subject: Reply with quote
Machine Mart usually have a good selection at reasonable prices and the quality is quite good.
dragstaar
PostPosted: 21:02 - 24 Apr 2013    Post subject: Reply with quote
just dont buy shitty quality ones. not worth dropping your bike over. Now that's not to say you need to buy expensive, just buy good quality.
It might also be worth getting a handlebar sleeve. Makes attaching the straps easier
Ariel Badger
PostPosted: 21:27 - 24 Apr 2013    Post subject: Reply with quote
I do not like ratchets as they jam up, I use the pull up straps,
https://www.machinemart.co.uk/shop/product/details/25mm-cam-buckle-strap
Easter Bunny
PostPosted: 22:23 - 24 Apr 2013    Post subject: Reply with quote
ALWAYS check them after a couple of miles Thumbs Up
Raffles
PostPosted: 22:25 - 24 Apr 2013    Post subject: Reply with quote
Me too, though I prefer to use the 2-part ones with a hook on each end:-
https://www.machinemart.co.uk/shop/product/details/cht207-tie-down
binge
Emo Kiddy
PostPosted: 22:27 - 24 Apr 2013    Post subject: Reply with quote
Them pull-up straps are the best.
Remember, you dont need to strap the living fuck out of the bike. I cringe when I see people pulling the forks right down to the bump stops. It's a one-way ticket to burst fork seals.
Ariel Badger
PostPosted: 23:14 - 24 Apr 2013    Post subject: Reply with quote
That was what I was looking for and use, search on MM is rubbish.
Peirre oBollox
PostPosted: 06:04 - 25 Apr 2013    Post subject: Reply with quote
IF they jam up, your probably not using them right. I see too many people trying to over ratchet them and they wind too much slack onto the spool, which is how they usually jam.
Its better to pull down as much slack thru the ratchet by hand, then use the ratchet to finish of the last turn or so to get the tension. Personally I use more industrial straps used on trucks, in particular some from Tesco`s trucks Embarassed that hold the roll cages in place in the trailers, as these have hooks on each end
Slacker24seve...
PostPosted: 06:30 - 25 Apr 2013    Post subject: Reply with quote
If possible get some with rubber coated hooks. It'll probably save your paintwork at some point Wink
Banger rallies are ace
Easter Bunny
PostPosted: 08:43 - 25 Apr 2013    Post subject: Reply with quote
I use ratchets on the back of the bike for boxes that I carry as an absolute fail safe, never have one jam up, as has been said pull as much slack through as possible, the ones I use have hooks and attach to the grab rails
BTTD
PostPosted: 09:20 - 25 Apr 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Ratchet-Strap-1500kgs-25mm-Wide-/170980171009?pt=UK_BOI_Industrial_Tools_Construction_Tools_ET&var=&hash=item27cf365d01
These are my favourite type for heavier loads. The hooks on these can link into each other securely to make a single long strap.
I've never had a ratchet jam up on me, so not sure what the issue with that is.
Also, I've made my own strap sacks! I've blatantly ripped off this guys design and used some old tent material. Saves a lot of strap flying about, and keeps the ratchets tidy. Couple evenings stitching in front of the tv.
https://www.tie-down-storage.com/
The cam buckles are also good and I use them for securing bulky stuff onto the bike. Got the machine mart ones mentioned above.
Poseidon
PostPosted: 10:52 - 25 Apr 2013    Post subject: Reply with quote
I use these'uns...
https://www.wickes.co.uk/content/ebiz/wickes/invt/156529/Ratchet-Strap_medium.jpg
https://www.wickes.co.uk/invt/156529
Got a few sets of them. Cost me around £18 each about 5 years ago. They've been used to transport the triumph at least a half dozen times in a van, and the kwak a couple of times too. Use them pretty much every other weekend to tie down ice-hockey kit bags on the roof rack of a transit van. Not once have they failed or jammed or anything! Thumbs Up
1977 Honda CG125
fozzym
PostPosted: 20:26 - 25 Apr 2013    Post subject: Reply with quote
Thanks for all your replies and advice guys. I'm gonna get the job sorted this weekend. I'll let you know which ones i go for.
Drake
PostPosted: 20:49 - 25 Apr 2013    Post subject: Reply with quote
i use the ones from work either these red ones that are safe to about a ton
https://sphotos-c.ak.fbcdn.net/hphotos-ak-frc1/469492_10151110765946320_1884883119_o.jpg
or some stronger ones that are rated to about 5 ton safely
fozzym
PostPosted: 21:58 - 26 Apr 2013    Post subject: Reply with quote
Orderd a set of 4 from machinemart online, think they should work nicely. I'd imagine that being from a reputable firm they should work within the tolerances stated.
https://www.machinemart.co.uk/shop/product/details/cht206-tie-down
Vracktal
PostPosted: 22:14 - 26 Apr 2013    Post subject: Reply with quote
https://washford.scene7.com/is/image/Washford/251574?$PDP_ENLARGE$
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_798343_langId_-1_categoryId_165734
These are the ones I use, they[re a bit pricey but completely worth it in my opinion just for not having to untangle them all the time.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
PostPosted: 22:34 - 26 Apr 2013    Post subject: Reply with quote
I've never had a ratchet strap jam, and I certainly wouldn't trust those sprung jaw type straps, nor would I trust rope or anything like that.
I usually go for cheapo ebay ratchets, which are fine for tying a bike down. It's not like you're using them to hold a one tonne weight. Most bikes will weigh under 250kg anyway, so four cheap ratchets will do the job.
MarkJ
PostPosted: 22:43 - 26 Apr 2013    Post subject: Reply with quote
I also prefer the pull straps Thumbs Up
https://shop.1stmx.co.uk/ekmps/shops/andyhutch/images/tie-down-pull-straps-for-motocross-bikes-twin-pack-257-p.jpg
Raffles
PostPosted: 23:29 - 26 Apr 2013    Post subject: Reply with quote
I use those 'sprung jaw types' whenever I transport my bikes and I never have any issues with them. I also use similar type straps every day in my workplace and can only praise them.
I find the ratchet type straps to be cumbersome and hazardous to my pinkies.
The last post was made 12 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.68 - MySQL Queries: 13 - Page Size: 108.46 Kb
