Changing brake pads video - For the mechanically uninitiated
Sable
PostPosted: 09:51 - 28 Apr 2013    Post subject: Changing brake pads video - For the mechanically uninitiated Reply with quote
Continuing to do all my own servicing atm, saw this video a while back and used it too change my brake pads. He says in the video most disk brakes are similar, though on bigger bikes the pistons are harder to push back in? His method worked fine on my little Sinnis, only difference was I only had 1 piston to push back in.
https://www.youtube.com/watch?v=CmN7sZzxDM0
Yeah I know most of you know how to do it, but for the uninitiated, this guys video shows how easy it is. So just thought I would share for those that haven't done it before. Thumbs Up
RhynoCZ
PostPosted: 10:32 - 28 Apr 2013    Post subject: Reply with quote
yeah, right in 10 mins. and lots of cuts and editing Laughing
+ you do not need the torque wrench and it takes quite a lot of time to fit the calliper back on the disc Rolling Eyes
Sometimes helps if you drain the system a bit, a previous owner could have just added some fluid into the system when the pads were old/used up. My rear brake was just like that, the previous owner had to change rear pads, instead of that he filled up the system, so when I got new pads it was impossible to push the pistons back, so I had to drain it a bit Thumbs Up
EDIT: If it was meant to be a manual for beginners, I'd mention do not touch your brake lever while the caliper is off the disc.
Sable
PostPosted: 10:35 - 28 Apr 2013    Post subject: Reply with quote
Time scales may vary, but the video still helped me change my pads for the first time. Mr. Green
evoboy
PostPosted: 17:49 - 28 Apr 2013    Post subject: Reply with quote
Clean the pistons before pushing them back in.
Clean the pins the pads slide on, then use a small amount of copper grease.
Loosening off the pad pins is far easier to do before removing the caliper.
APT Motorcycles
The last post was made 13 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 40.61 Kb
