Indicators
craigie b
Citizen Smith
PostPosted: 21:22 - 26 Nov 2004    Post subject: Indicators Reply with quote
Hi guys,
I have just installed new micro indicators to the front of my bike and I've noticed that both front and rear indicators blink faster and there is a funny noise prior to them lighting up (on initial blink....there fine after that). I'm not gonna fry my NSR's electrics am I?
NSR125-Kid-UK
Attention Whore
PostPosted: 21:33 - 26 Nov 2004    Post subject: Re: Indicators Reply with quote
craigie b wrote:
Hi guys,
I doubt it. What you need to do is check the number on your indicator bulbs - check for wattage.
On the indicator relay, which is vaguely under the grabrail, nestled right at the back of the bike covered by the rear fairing panels should be a few numbers i.e. 18/34 - AFAIK this means that your relay (the bit that controls the flashing) is designed to operate two 18 watt bulbs (for example) coming to a total of 34 watts.
To make your indicators flash at a decent speed, make sure the number on the relat - 15/14/18 whatever, matches the wattage on the indicator bulbs.
You'll probably need to but a new relay, about £7, or you could just swap the bulbs round in your indicators until the wattages match Smile.
https://www.bikepics.com/members/nsrandy/96rs250/ My Bike!
"I'm either going to teach andy to get his knee down, or I'm going to get him killed. One of the two" - Teaman
map
Mr Calendar
PostPosted: 22:11 - 26 Nov 2004    Post subject: Reply with quote
I believe Acumen do a unit to correct the flash rate if you've changed the wattage or using LEDs.
Click here for link to the M and P site search result.
It's the Indicator Driver you'll need, either universal or for your model (but make sure it'll fit, if not get universal).
Any queries give them a 'phone call.
HTH Smile
paul
PostPosted: 22:38 - 26 Nov 2004    Post subject: Reply with quote
yeh mate I got the same with my nsr, I fitted some little indicators and they blink faster and make like a sort of clicking/grinding noise before they turn on, I hope it aint gonna fry my electrics too, Neutral . On mine it's because the wattage is different, i.e. it should be 30 but the indicators only give out 15 watts or something like that anyway.
Paul
PostPosted: 23:52 - 26 Nov 2004    Post subject: Reply with quote
I bet it sounds like a kind of grating 'boing' noise. This is just the tag on the relay bouncing slightly when it hits the electromagnet as the new flashers are drawing less current than the original ones and so don't attract the tag as firmly. Don't worry about it.
Providing your flashers give between 60 and 120 flashes per minute, it is perfectly legal. I even find that a faster flash rate tends to attract drivers attention more than standard in a 'look how fast those flashers are going' way. Try it and see.
craigie b
Citizen Smith
PostPosted: 04:05 - 27 Nov 2004    Post subject: Reply with quote
Cheers stink....Excellent diagnosis!!!! Thats exactly whats happening! Thanks for putting my mind at ease! Thumbs Up
BLOFLY 636
PostPosted: 17:04 - 01 Dec 2004    Post subject: Reply with quote
also I should add that if the light bulbs or L.E.D.'s can not be swapped for the correct wattage then you can over come the problem by fitting 8 power resistors, each being 10 watts each.
The way to do it is by fitting 2 of the resistors in PARRALEL of the indicator wires thus creating a 20 watt circuit for the relay to come under load and drawing enough current to cure the fast flashing problem, you need 8 of the resistors to complete a bike (2 resistors on each indicator) but if some of your indicators are still the standard incandecnt bulbs it would not be neccessary to install the resistors at that particular indicator hope this is some help to you Very Happy
Those bloody footpegs......they ought to do away with em!
The last post was made 21 years, 284 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 55.87 Kb
