aprilia rs 125 headlight problems!! please help !! need mot
merky69
PostPosted: 13:39 - 02 May 2013    Post subject: aprilia rs 125 headlight problems!! please help !! need mot Reply with quote
ok so i have been working away for a while and bike has jus been stood.
came home for a holiday break to get bak on the road.
its a 2001 model,
ok so dip beam and main beam are not working however the light at the back at the bottom is working i think its supposed to be a side light which stays on all time with the dip. so i got both new bulbs h1 and h3 for dip and main and replaced them, still no luck.
this is what baffled me , if i press the "flash" trigger the main beam will come on. but using the switch for the lights down is dip up is main, non work, so i dismantle the choke housing where the switch is inside and cleaned it out had a fiddle, all terminals to the switch are solid, still no luck. checked all fuses. all fine ......... jus cant get my head around this
if some one can please help it will be greatly appreciated im hoping its just a small error that im missing.
thanks for looking
PostPosted: 13:40 - 02 May 2013    Post subject: Reply with quote
Quick way to get back on the road, tape up all lights and switches for lights.
But, check the actual switches themselves, might have just corroded a little inside.
merky69
PostPosted: 13:53 - 02 May 2013    Post subject: Reply with quote
so u think it is the switch from wat ive said
PostPosted: 14:01 - 02 May 2013    Post subject: Reply with quote
The buld works, given the flash option, so yes, I'd open the switch gear, bit of WD40 and lightest wet and dry/emery paper and see if the contacts are clean.
merky69
PostPosted: 14:13 - 02 May 2013    Post subject: Reply with quote
ive done what you have said , opened the switch up its self cleaned terminals with wd, although they looked ok anyway, i have also tried crossing the terminals manually with a conductor to see if the lights come on still nothing =[
merky69
PostPosted: 14:21 - 02 May 2013    Post subject: Reply with quote
pisture of the switch open
How is the wiring/fuses... think the flasher might mean the fuse is fine but worth a check.
merky69
PostPosted: 14:26 - 02 May 2013    Post subject: Reply with quote
i tried to upload a pic but its to big to upload to this site, the fuse is ok, and ive checked the wiring as far as i can it goes to a plug, then from the plug into the loom. as for to the light its self its fine too confused
PostPosted: 14:30 - 02 May 2013    Post subject: Reply with quote
Silly question, have you checked both switchgears?
merky69
PostPosted: 14:34 - 02 May 2013    Post subject: Reply with quote
what do u mean by both switch gears mate??
PostPosted: 14:41 - 02 May 2013    Post subject: Reply with quote
If I remember correct, on my RS, you had the lights off/side light/dip on the left hand side and the main beam/dip control on the left along with the flash button.
merky69
PostPosted: 14:51 - 02 May 2013    Post subject: Reply with quote
yes correct its on the left and theres only two movements of the lights, switch down which is sidelamp/dip on , and up which is main on, then there is the flash trigger which is accessible via your index finger
merky69
PostPosted: 14:53 - 02 May 2013    Post subject: Reply with quote
heres a pic off google
PostPosted: 14:54 - 02 May 2013    Post subject: Reply with quote
Yup, I would check the right hand one too... just incase the sidelight/dip selector has corroded.
merky69
PostPosted: 14:59 - 02 May 2013    Post subject: Reply with quote
yes i did check them all, this is gunna sound very strange but its gods honest truth, i have just pressed the horn and both lights started working again wttttttffffffff. lmfao
thanks for all your help and time mate appreciate it
Very Happy
PostPosted: 15:01 - 02 May 2013    Post subject: Reply with quote
Something loose or still very intermittent. Have another poke around when you get a chance Thumbs Up Glad its working Mr. Green
merky69
PostPosted: 15:07 - 02 May 2013    Post subject: Reply with quote
just been in stiches reading your bodge list CLASSIC!
joe.llewellyn
PostPosted: 18:42 - 03 May 2013    Post subject: Reply with quote
i have a rx50 which had funny lights, what i did was take the light off and clean the connectors, then wedve something behind the coneectors, some rubber plumbers gasket rings wrapped in insulation taped seemed to work, if you do try the dont wedge anything to tight and nothing that will conduct electricity, just something to keep the connectors pressed tightly against the bulb.
im no mechanic, im just saying what i did Smile
There is a gap of 2 years, 26 days between these two posts...
RS125 idiot
PostPosted: 08:57 - 30 May 2015    Post subject: Reply with quote
I've got the same problem whereby the light flasher is working but the dip/main beams & indicators are not working. Everything was working fine when I bought the bike then I had it trailered down south and a week later nothing was working. The bike has got a new battery, I've been through and disconnected/cleaned all connectors, I've tried a new headlight bulb, I've put all new fuses in, I've tried another (2nd hand) left-switchgear....... I'm really stuck now, can anybody please help Sad
The last post was made 11 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 96.57 Kb
