| sepher |
 sepher Nova Slayer
| ZebraDriver |
 ZebraDriver Scooby Slapper
| J.M. |
 J.M. World Chat Champion
| Islander |
 Islander World Chat Champion
| Snorty |
 Snorty World Chat Champion
| sepher |
 sepher Nova Slayer
 Posted: 10:52 - 05 May 2013 Post subject: |
Thanks for the replies, the flasher unit is integrated into the side stand relay and all sorts on the GSXR which is a pain. It's not separate. But I suppose I could get a 2 pin flasher unit, and feed the indicator wires into the flasher unit instead of the original relay.
Do you think any 2 pin relay would do? I was looking at this..
https://www.ebay.co.uk/itm/270973992636 |
| smegballs |
 smegballs World Chat Champion
 Posted: 11:31 - 05 May 2013 Post subject: |
No a 2 pin relay won't do.
A 2 pin relay is flashes due to something called a bi-metallic strip, the current flow heats the strip which then bends, breaking contact and turning the indicator off. As it cools, it straightens back out again and remakes the electrical contact, indie comes back on and the cycle starts again.
The problem with these is that if you don't have exactly the right load what they are designed for, they won't be heating/cooling at the right rate and the result is indicators that are two fast or two slow.
What you want is an electronic relay, where the flash rate is set by the electronics in the box and is not proportional to current flow. With one of these you can run LEDs, big bulbs or little bulbs etc etc and the flashing rate will stay constant. These electronic relays will have 3 (or more) pins as there needs to be a constant ground for the electronics inside to function.
So there will typically be 3 connections:
A 12v positive
A ground
A "flashing" output - in reality it's a live being switched on and off at a set rate
Then this flashing output gets routed to the left of right side indies by the switchgear switch.
Personally I wouldn't buy a relay, I'd knock one up from the shizzle in my electronics box. That's just me tho  |
| smegballs |
The last post was made 13 years, 195 days ago. Instead of replying here, would creating a new thread be more useful? |
