Honda CBR600 F SPORT engine rattle
FORDYUK
PostPosted: 15:11 - 04 May 2013    Post subject: Honda CBR600 F SPORT engine rattle Reply with quote
Hi people.
Recently bought a CBR600 F sport, 2002 model, noticing a engine rattle, which I can feel vibrating through the bars, not at all rpm but mainly between 3.5k - 5k rpm, and also when been out for a ride and put it into neutral when stopped you can hear it for around 30 seconds or so.
Any ideas? Cheers.
Mod 1 passed 17/10/12 .....Mod 2 passed 12/12/12
Current ride: Honda CBR 600 F SPORT 2002
CaNsA
PostPosted: 15:16 - 04 May 2013    Post subject: Reply with quote
Cam chain tensioner?
FORDYUK
PostPosted: 15:41 - 04 May 2013    Post subject: Reply with quote
Yes mate, looking on a few Honda forums, it seems quite a common issue with the CBR's. Need to find a manual APE one from a UK site, can only see them from the states.
CaNsA
PostPosted: 15:48 - 04 May 2013    Post subject: Reply with quote
Have a look at this
https://www.howtomakeonline.org/0XQj5MoneyT_OnYT/Honda-CBR-600-Cam-Chain-Tensioner-%28CCT%29.html
Also, it is fairly easy to convert a buggered automatic CCT into a manual one.
BUT, you can only add tension to the chain so much before the chain needs replacing, just like a drive chain.
lihp
PostPosted: 18:00 - 04 May 2013    Post subject: Reply with quote
If you go to a manual, remember you're currently running a hydraulic tensioner so will need to block off oil supply.
Drake
PostPosted: 21:16 - 04 May 2013    Post subject: Reply with quote
pull your clutch lever in when it does it in neutral, just try it.
anthony_r6
PostPosted: 11:35 - 05 May 2013    Post subject: Reply with quote
As above, if you pull your clutch in and it goes away, whilst sitting in neutral, you're fine.
The last post was made 13 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 50.39 Kb
