| smegballs |
 smegballs World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:49 - 05 May 2013 Post subject: |
I wouldn't buy them, but would make some for myself. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| smegballs |
| stuarthouston |
 stuarthouston Trackday Trickster
| fatpies |
 fatpies World Chat Champion
 Posted: 14:12 - 05 May 2013 Post subject: |
Hold on so you're replacing 1 indicator relay which from a motor factors can cost about £2 for four integrated indicator relay things.
Since you already have to run 12v to them anyway, I am not seeing the advantage of this set-up other than if a bulb goes pop, they stay flashing at a consistent rate.
Which is resolved by a 90p bulb from motor factors  ____________________ "It's easy to attack and destroy an act of creation. It's a lot more difficult to perform one" |
| DottyDuck |
 DottyDuck Nearly there...
 Posted: 14:15 - 05 May 2013 Post subject: |
i am going to nod and agree because after reading that my mind has completely been frazzled!  ____________________ CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14
Old Bike: Zontes Panther 125cc - wrote off Current Bike: Kawasaki ZR7  |
| Ichy |
 Ichy World Chat Champion
 Posted: 14:39 - 05 May 2013 Post subject: |
I pay less than £1.50 for an electronic flasher relay. You can use with leds or bulbs and the flash rate remains the same even if a bulb blows.
Just a thought, with your set up how do you flash the tell tale on the dash? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| smegballs |
 Posted: 14:48 - 05 May 2013 Post subject: |
| fatpies wrote: | Hold on so you're replacing 1 indicator relay which from a motor factors can cost about £2 for four integrated indicator relay things.
Which is resolved by a 90p bulb from motor factors  |
I see what you mean, for a straight swap with stock parts it wouldn't be worth it.
If you're buying aftermarket indicators however, maybe there would be the benefit? Seeing as often people have problem with flash rates etc after fitting aftermarket indies. LEDs and solid state electronics are pretty rugged these days, time before failure should be in the tens of thousands of hours.
| Ichy wrote: | Just a thought, with your set up how do you flash the tell tale on the dash? |
Got me there, I hadn't thought of that! |
| J.M. |
 J.M. World Chat Champion
| Ichy |
 Posted: 15:40 - 05 May 2013 Post subject: |
| weasley |
 weasley World Chat Champion
| silky666 |
 silky666 Captain Rulebook
 Posted: 18:31 - 05 May 2013 Post subject: |
I dont understand . How does it know when to flash ?
https://coultonsconjectures.files.wordpress.com/2012/05/confused-dog.jpg ____________________ There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffa tape.
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together. |
| smegballs |
 Posted: 19:04 - 05 May 2013 Post subject: |
Occult magics imprisoned in the fabled "black box". |
| stickybackbob |
 stickybackbob Trackday Trickster
 Posted: 19:18 - 05 May 2013 Post subject: |
Think of the 12v supply as a cattle prod. This pokes the pixies living in the indicator body who in turn, flick the on/of switch.
What the OP is doing is taking the one pixie out of the usual relay and replacing with 4, 1 in each indicator. Job creation......you wouldn't be a labour voter would you?  |
| smegballs |
| cimbian |
 cimbian World Chat Champion
 Posted: 19:38 - 05 May 2013 Post subject: |
But what about the repeater on the instrument cluster? Isn't this a legal requirement? ____________________ 22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker |
| smegballs |
| Teflon-Mike |
 Posted: 21:33 - 05 May 2013 Post subject: |
How do you sincronise them?
Read the Construction & Use regulations, lighting requirements.
Not only must all indicators flash at the same rate, they must flash at the same time.
If the indicators are flashed independently, then there is nothing ensuring sync.....
Simpler to use a single flasher to feed all indicators & no risk of sinc error, and I think that that might actually be stipulated in the lighting req's of C&U regs. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Marmalade |
 Marmalade World Chat Champion
| Ichy |
| Marmalade |
 Posted: 01:11 - 06 May 2013 Post subject: |
Only if it was a constant light or used standard relay otherwise it would be a flashing supply to a flasher on the leds. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| uberkron |
 uberkron Crazy Courier
| Islander |
 Islander World Chat Champion
 Posted: 11:12 - 07 May 2013 Post subject: |
Overthought solution to an already solved problem IMO but kudos for the ingenuity
The simplest solution as already stated in other posts is to use a load independent electronic flasher relay. It makes sense to keep the control unit centralised - independent flasher controls would need to be synchronised and that would add another level of unnecessary complication. Plus there's the tell-tale as well.
Silky, there's a demon in the relay box and he has electrodes connected to his nipples. When you switch the indicator on, it applies a shock to the relevant nipple and he operates the correct switch at the required rate.  |
 Posted: 14:16 - 07 May 2013 Post subject: |
| Teflon-Mike wrote: | How do you sincronise them?
Simpler to use a single flasher to feed all indicators & no risk of sinc error, and I think that that might actually be stipulated in the lighting req's of C&U regs. |
Odd. Because the flashers on a tomos moped used to flash front to back on account of it only being capable of lighting up one bulb at a time. They were type approved.
Electronically, the idea is more complicated than it needs to be. The multivibrator circuit is superflous. If you include a single, 1Hz flashing LED in the cluster, the others will flash in synch with it.
In theory, you could use this as the flashing source for your LED flashers. Just use standard LED indicators and replace the dash repeater bulb with two flashing LEDs in paralell (one orientated in either direction). Then you just need simple LED flashers and the flasher unit is built into the repeater lamp.
Flashing LEDs cost somewhere in the region of 40p each. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ichy |
The last post was made 13 years, 59 days ago. Instead of replying here, would creating a new thread be more useful? |
