Would you buy - Self flashing indicators?
smegballs
PostPosted: 13:48 - 05 May 2013    Post subject: Would you buy - Self flashing indicators? Reply with quote
Was playing with some electronics the other day, making LEDs flash using a really simple circuit called a multivibrator. The flash rate is set by the values of resistors and capacitors and can be set withing the legal flash rate for indies.
The circuit costs pennies to make, and could be fitted into an indicator body, especially if using surface mount parts. The end result would be a self-flashing led indicator, all you need to do is apply 12V to the positive terminal and the indie will flash - no need for an external flasher relay. Another bonus is that effectively each indie has it's own internal flasher, should one indicator fail, the other will all continue to flash at the correct rate.
PostPosted: 13:49 - 05 May 2013    Post subject: Reply with quote
I wouldn't buy them, but would make some for myself.
smegballs
PostPosted: 13:57 - 05 May 2013    Post subject: Reply with quote
I'm not surprised, the sort of person who is likely to fuck off their indicator relay and start running wires about themselves is likely to be no stranger to a soldering iron.
In future if I ever have to get new indicators I'll knock up some of these and see how they go. That said I wouldn't buy an indicator relay again, I'd just rig up a 555 to a power transistor and that's that.
stuarthouston
PostPosted: 13:58 - 05 May 2013    Post subject: Reply with quote
Clever idea, but I think I actually quite like the fact that if one bulb blows, the others flash quickly. Lets you know something is awry if you haven't already noticed?
'96 Honda CG125 BR-T
fatpies
PostPosted: 14:12 - 05 May 2013    Post subject: Reply with quote
Hold on so you're replacing 1 indicator relay which from a motor factors can cost about £2 for four integrated indicator relay things.
Since you already have to run 12v to them anyway, I am not seeing the advantage of this set-up other than if a bulb goes pop, they stay flashing at a consistent rate.
Which is resolved by a 90p bulb from motor factors Confused
DottyDuck
PostPosted: 14:15 - 05 May 2013    Post subject: Reply with quote
i am going to nod and agree because after reading that my mind has completely been frazzled! Embarassed
CBT- 2012 Theory- 18/12/13 Mod 1- 07/01/14 Mod 2- 15/01/14 Very Happy
Old Bike: Zontes Panther 125cc - wrote off Sad Current Bike: Kawasaki ZR7 Very Happy Wub
Ichy
PostPosted: 14:39 - 05 May 2013    Post subject: Reply with quote
I pay less than £1.50 for an electronic flasher relay. You can use with leds or bulbs and the flash rate remains the same even if a bulb blows.
Just a thought, with your set up how do you flash the tell tale on the dash?
smegballs
PostPosted: 14:48 - 05 May 2013    Post subject: Reply with quote
I see what you mean, for a straight swap with stock parts it wouldn't be worth it.
If you're buying aftermarket indicators however, maybe there would be the benefit? Seeing as often people have problem with flash rates etc after fitting aftermarket indies. LEDs and solid state electronics are pretty rugged these days, time before failure should be in the tens of thousands of hours.
Got me there, I hadn't thought of that!
J.M.
PostPosted: 15:37 - 05 May 2013    Post subject: Reply with quote
Surely with an electronic relay, they continue to flash at a constant rate anyway? Unless the indicators are ran in series.
2004 R1 & 2018 XSR900
Ichy
PostPosted: 15:40 - 05 May 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Electronic-LED-Flasher-Relay-Fix-Turn-Signal-3-Pin-New-/230827912089?pt=UK_Motorcycle_Parts&hash=item35be6a6b99
I've used them a few times and they work just fine. Constant flash rate from 0.2 - 20 Amps.
weasley
PostPosted: 18:23 - 05 May 2013    Post subject: Reply with quote
Presumably also each side indicator would flash independently, meaning they wouldn't flash in perfect synchronisation, and potentially at slightly different rates. That would wind me right up.
silky666
Captain Rulebook
PostPosted: 18:31 - 05 May 2013    Post subject: Reply with quote
I dont understand . How does it know when to flash ?
https://coultonsconjectures.files.wordpress.com/2012/05/confused-dog.jpg
smegballs
PostPosted: 19:04 - 05 May 2013    Post subject: Reply with quote
Occult magics imprisoned in the fabled "black box".
stickybackbob
PostPosted: 19:18 - 05 May 2013    Post subject: Reply with quote
Think of the 12v supply as a cattle prod. This pokes the pixies living in the indicator body who in turn, flick the on/of switch.
What the OP is doing is taking the one pixie out of the usual relay and replacing with 4, 1 in each indicator. Job creation......you wouldn't be a labour voter would you? Smile
smegballs
PostPosted: 19:35 - 05 May 2013    Post subject: Reply with quote
About as far from a labor voter as could be possible Razz
On reflection this idea, does suck a bit. As said with 4 different free-running oscillators, the chances of all leds being synced is pretty low. That said, usually an observer will only see one front or one back indicator, they wont usually see both and see them out of sync.
cimbian
PostPosted: 19:38 - 05 May 2013    Post subject: Reply with quote
But what about the repeater on the instrument cluster? Isn't this a legal requirement?
22PlusY
Current: Moto Guzzi 1100 Breva. Previous: Honda XL650V TransAlp
Bearded, Balding, Born again Buddhist Biker
smegballs
PostPosted: 19:49 - 05 May 2013    Post subject: Reply with quote
I've passed a bike MOT with tape over the repeater as one wasn't working before. I agree though, you can put another flashy thing wired to flash the repeater from either side but by that point you would probs be better just to stick with the single relay like normal Razz
Well that's that idea busted. I'll make some one day for amusement and see how they do.
Teflon-Mike
tl;dr
PostPosted: 21:33 - 05 May 2013    Post subject: Reply with quote
How do you sincronise them?
Read the Construction & Use regulations, lighting requirements.
Not only must all indicators flash at the same rate, they must flash at the same time.
If the indicators are flashed independently, then there is nothing ensuring sync.....
Simpler to use a single flasher to feed all indicators & no risk of sinc error, and I think that that might actually be stipulated in the lighting req's of C&U regs.
Marmalade
PostPosted: 23:28 - 05 May 2013    Post subject: Reply with quote
You have another small flashing led in the tell tale.
Ichy
PostPosted: 23:54 - 05 May 2013    Post subject: Reply with quote
Think about it, there isn't any need.
Marmalade
PostPosted: 01:11 - 06 May 2013    Post subject: Reply with quote
Only if it was a constant light or used standard relay otherwise it would be a flashing supply to a flasher on the leds.
uberkron
PostPosted: 10:59 - 07 May 2013    Post subject: Reply with quote
The fast flash rate is required legally so you know a bulb is out.
With leds, no problem with blown bulbs, but yes, good idea for something like a bike. You could even make the lights communicate with each other to sync the flash rate. Id be annoyed if my indicators got out of time. You could have a revolving pattern for hazards too.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
Islander
PostPosted: 11:12 - 07 May 2013    Post subject: Reply with quote
Overthought solution to an already solved problem IMO but kudos for the ingenuity Mr. Green
The simplest solution as already stated in other posts is to use a load independent electronic flasher relay. It makes sense to keep the control unit centralised - independent flasher controls would need to be synchronised and that would add another level of unnecessary complication. Plus there's the tell-tale as well.
Silky, there's a demon in the relay box and he has electrodes connected to his nipples. When you switch the indicator on, it applies a shock to the relevant nipple and he operates the correct switch at the required rate. Wink
PostPosted: 14:16 - 07 May 2013    Post subject: Reply with quote
Odd. Because the flashers on a tomos moped used to flash front to back on account of it only being capable of lighting up one bulb at a time. They were type approved.
Electronically, the idea is more complicated than it needs to be. The multivibrator circuit is superflous. If you include a single, 1Hz flashing LED in the cluster, the others will flash in synch with it.
In theory, you could use this as the flashing source for your LED flashers. Just use standard LED indicators and replace the dash repeater bulb with two flashing LEDs in paralell (one orientated in either direction). Then you just need simple LED flashers and the flasher unit is built into the repeater lamp.
Flashing LEDs cost somewhere in the region of 40p each.
Ichy
PostPosted: 16:44 - 07 May 2013    Post subject: Reply with quote
Not necessarily, the options are constant lit, unlit or a change in frequency. If the OP used the indicator switch as part of the circuit with the tell tale in series then it would fail to light if an indicator failed.
You can get away without a tell tale on a bike since you can generally see the indicator flashing.
The reality is, if it was legal/cheaper/easier then the OEM would be doing it.
The last post was made 13 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 133.8 Kb
