Using certain gears
rac3r
PostPosted: 00:23 - 06 May 2013    Post subject: Using certain gears Reply with quote
Are there any negative effects of using certain gears more than others?
I tend to use only 1-3 sometimes 4th, 5th has been used a couple of times and 6th never Laughing I never do motorway runs and 3rd/4th is enough for dual carriageways and B roads
Chequered Flag
Snorty
PostPosted: 00:47 - 06 May 2013    Post subject: Reply with quote
You'll wear them out faster. Whether this is a practical or noticeable amount of wear... well somebody else could say.
bridgedino
PostPosted: 09:05 - 06 May 2013    Post subject: Reply with quote
The rear passenger doors on my grandparents car were only ever opened once or twice a year.
They seized up
Slacker24seve...
PostPosted: 09:12 - 06 May 2013    Post subject: Re: Using certain gears Reply with quote
At normal motorway or dual carriageway speeds (honestly officer) a Triple should be sat at about 7 or 8k in 6th gear - bang in the midrange where it is plenty responsive. You must be revving the tits off it to never use 6th!
Banger rallies are ace
Davenaylor
PostPosted: 09:26 - 06 May 2013    Post subject: Reply with quote
On the bikesafe course I did last week with West Yorkshire police they told me off for brakinginto corners. They said if I got my gearing right I shouldn't need to do this.
Since then I have made much more use of 2nd and 3rd gears and the bike is always bang in the power band on the twisties. It's much more noisy but also feels a lot more responsive. I do wonder if I'm been harsh on a 14 year old gear box (bike is a bandit s)
On the long stretches I still get up the gears, I just drop them back down to prepare for the corner.
Wonko The Sane
PostPosted: 09:41 - 06 May 2013    Post subject: Reply with quote
I've just made the move from a big 125 (varadero) to a ZZR600, was up in 5th in a 50 as it just made sense to let the revs drop a bit but keep it revving a little down in 2nd or 3rd at 30.
only done 20 miles on it so still learning, was up in 6th on the motorway.
Sload
PostPosted: 09:52 - 06 May 2013    Post subject: Re: Using certain gears Reply with quote
Cant really see any problem with that and it sounds pretty normal. Your lower gears will see more wear over the life of the bike anyway. As long as you keep your oil in good order and try to be smooth through the changes it should last regardless.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
lihp
PostPosted: 09:53 - 06 May 2013    Post subject: Reply with quote
Can you please explain how this will happen?
Gears are constant mesh, the only thing that could possibly wear more is the dogs though if you're changing gears properly this isn't going to be happening too often
Snorty
PostPosted: 10:16 - 06 May 2013    Post subject: Reply with quote
Things wear, otherwise gearboxes would last forever. I was being pedantic. Rolling Eyes
PostPosted: 10:56 - 06 May 2013    Post subject: Reply with quote
There's some contention about this in the "advanced" riding community. The local IAM are of the "brakes to slow, gears to go" school. Sure, be in the right gear as you enter the bend in order to accelerate out of it, but don't necessarily bang it down pre-emptively and use engine braking to slow down. Brake pads cost less than clutches and gearboxes, they noted.
It gets easier to recommend staying in high revs when someone else is paying for your bike, servicing and fuel. Wink
smegballs
PostPosted: 11:55 - 06 May 2013    Post subject: Reply with quote
ZZR is nice because if you want you can quite happily ride everywhere below 6k and it will just trundle along all relaxed like, but if you need to cane it 8k+ and off it goes.
My sister changes down well early on hers, it hardly ever gets revved above 7k or so.
rac3r
PostPosted: 12:16 - 06 May 2013    Post subject: Re: Using certain gears Reply with quote
Although I haven't properly looked, 60mph in third sat at about 6k revs. IMO 6k is the right zone if you need to go. 3rd can get you to 80/90 so more than enough for dual carriage ways and tight B roads. The way I ride anyway Laughing
Chequered Flag
bladerunner
PostPosted: 12:36 - 06 May 2013    Post subject: Reply with quote
To say that you never use 6th is just bad riding mate. Also using 3rd at 60 is ideal if you need to use your bikes performance at the drop of a hat to get you out of trouble but to ride like that all the time is pure bad riding. Yes the gears are constant mesh....but only under load when you have that gear selected. Your just causing excess wear and tear on your bike and need to service your bike more often ....in line with the hard use or harsh environment recommendations.
Davenaylor
PostPosted: 12:51 - 06 May 2013    Post subject: Reply with quote
Fair point, on yesterday's ride I only did this (used the gears). I was around squires, church Fenton and Sherburn in North Yorkshire. Ill try combine both, I.e. right gear and braking, see how I get on with that. I think it's easier to just do one at first though as there is less going on.
rac3r
PostPosted: 13:37 - 06 May 2013    Post subject: Reply with quote
Where can I use 6th? round town no, B roads not quite, dual carriage way maybe but it will be sitting at about 4/5k which is nothing on the triple.
Any Street Triple/Daytona riders want to chip in?
Chequered Flag
T0MMY
PostPosted: 13:58 - 06 May 2013    Post subject: Reply with quote
I seem to remember someone on here talking about what gears they used and they said they like to be in a low gear all the time so they're in the power band. The funny thing was they were surprised to learn it affected fuel economy. The guy thought that the choice of gear was almost random...just if you wanted it quieter or whatever and that it made no difference to go along the motorway in 2nd for hours on end Laughing
I bang it in to top as soon as I can if I'm just trundling along. It's not that hard to go down a few if you need some poke.
ZX6R + CBR600RR
rac3r
PostPosted: 14:03 - 06 May 2013    Post subject: Reply with quote
Definitely understand 6th for motorway use, dual carriageway I don't ride much but I will try 6th next time. Town and B roads though I can't see 5th/6th being much use
Thinking of MPG while riding is too much for me Laughing
Chequered Flag
T0MMY
PostPosted: 14:05 - 06 May 2013    Post subject: Reply with quote
It's not just the MPG...engine wear too.
ZX6R + CBR600RR
bladerunner
PostPosted: 14:23 - 06 May 2013    Post subject: Reply with quote
I think your getting confused with the riding info you were given tbh.
rac3r
PostPosted: 14:55 - 06 May 2013    Post subject: Reply with quote
Question
Chequered Flag
Slacker24seve...
PostPosted: 15:01 - 06 May 2013    Post subject: Re: Using certain gears Reply with quote
90 in 6th around 7-8k gets me 44mpg. That's the right zone for a straight, multi lane road.
GREENI3
PostPosted: 15:03 - 06 May 2013    Post subject: Reply with quote
And they're usually on an R1200RT or similar shaft drive bike so don't have to worry about chains and sprockets wearing out, so its easy for them to say engine braking's better.
Walloper
PostPosted: 15:09 - 06 May 2013    Post subject: Reply with quote
I try not to wear my fishing gear on Nights-Out but most often wear casual gear Jeans, chinos, with a shirt/pullover or designer T-shirt.
Also when I want to DIY I'll use my own gear i.e. Drilling machine, pliers, hammer and cetera rather than borrow someone else's gear. I hate lending my gear to anyone so like wise I always want to have the gear of my own.
Never a Borrower nor a Lender be.
rac3r
PostPosted: 15:20 - 06 May 2013    Post subject: Re: Using certain gears Reply with quote
Im not saying I sit at 90 in third, I just meant its possible to do those speeds in that gear if needed. I agree though if you are cruising at that speed then 6th is the way however 60 in 6th I'll have to try and see what its like
Chequered Flag
Walloper
PostPosted: 15:51 - 06 May 2013    Post subject: Reply with quote
Seriously (is possible)
Gears are only intended to allow the limited torque an engine can produce propel the machine and overcome 'forces'.
Which gear you select depends simply on what road speed you are at and whether you wish to accelerate quickly or not or cruise.
The other factor is how much torque the engine can produce depending on design.
Design being matched to expected performance.
So, in general, big engine machines can use higher gears at lower road speeds.
For cruising high gears may be fine. And more economical, quieter and less wear on gearboxes. (Stuff will be whirring less which means less wear).
For twisties or more 'active' progress a lower gear would be better simply for for reasons of response.
Scooting along a 30 in 2nd is as daft as being in 5th. Anything in between is maybe a matter of preference.
Most economy guide advise using higher gears as much as possible and not to give it the beans too much.
And of course never ever ever use the brakes. Brakes are the devil.
The last post was made 13 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.42 - MySQL Queries: 13 - Page Size: 132.63 Kb
