 hmmmnz Super Spammer
 Posted: 15:08 - 07 May 2013 Post subject: gel battery charging |
ok ive read the internets on gel battery charging,
but couldnt find the specific info i need,
basically i want or is it possible to charge a gel from a led acid,
or using the lead acid (wet cell) as a dampener to charge the gel from the alternator in my camper,
i have a bitchin pure sine wave inverter which when plugged into the mains acts as a battery charger, this has an option to charge type of battery,
but when im not near some mains supply i want to be able to do it on the fly, with me alternator via starter battery
possible? or do i need to waste a few hundred quid on a specialist stering charger ____________________ the humans are dead
I kick arse for the lord
 Posted: 17:13 - 07 May 2013 Post subject: |
hmmm no one?
ok i was thinking about a solar charge controller,
they are designed to work with varying types of batteries, and you can get well over 18v on a hot day from solar panels, and normally they have an electronic version of a voltage sensitive relay built in to them, so it would save me buying one of those,
any neigh sayers on this idea?? ____________________ the humans are dead
 Walloper Super Spammer
 Posted: 18:18 - 07 May 2013 Post subject: |
I wiped out a perfectly good 17 plate maint-free (not AGM) battery in my BMW by having a solar strip connected via the cigar lighter socket when I was at work for a month at a time. (I don't smoke cigars though)
I think the constant dribble was too much for the battery and if boiled the electrolyte off.
I never knew gel bat would need a specific charger, my BMW bikes have AGM batteries and they are maintained using a ctek battery maintainerer.
I used to connect a one of them 12VDC-250AC invertor things off a Heavy duty battery and charger to run my computer when I worked in W. Africa. It was needed to filter lightening strikes and was easier to clash that together than buy a UPS.
This page has some 'stuff' for your perusal.
https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html#3 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
