gel battery charging
hmmmnz
PostPosted: 15:08 - 07 May 2013    Post subject: gel battery charging Reply with quote
ok ive read the internets on gel battery charging,
but couldnt find the specific info i need,
basically i want or is it possible to charge a gel from a led acid,
or using the lead acid (wet cell) as a dampener to charge the gel from the alternator in my camper,
i have a bitchin pure sine wave inverter which when plugged into the mains acts as a battery charger, this has an option to charge type of battery,
but when im not near some mains supply i want to be able to do it on the fly, with me alternator via starter battery
possible? or do i need to waste a few hundred quid on a specialist stering charger
the humans are dead
I kick arse for the lord
hmmmnz
PostPosted: 17:13 - 07 May 2013    Post subject: Reply with quote
hmmm no one?
ok i was thinking about a solar charge controller,
they are designed to work with varying types of batteries, and you can get well over 18v on a hot day from solar panels, and normally they have an electronic version of a voltage sensitive relay built in to them, so it would save me buying one of those,
any neigh sayers on this idea??
the humans are dead
Walloper
PostPosted: 18:18 - 07 May 2013    Post subject: Reply with quote
I wiped out a perfectly good 17 plate maint-free (not AGM) battery in my BMW by having a solar strip connected via the cigar lighter socket when I was at work for a month at a time. (I don't smoke cigars though)
I think the constant dribble was too much for the battery and if boiled the electrolyte off.
I never knew gel bat would need a specific charger, my BMW bikes have AGM batteries and they are maintained using a ctek battery maintainerer.
I used to connect a one of them 12VDC-250AC invertor things off a Heavy duty battery and charger to run my computer when I worked in W. Africa. It was needed to filter lightening strikes and was easier to clash that together than buy a UPS.
This page has some 'stuff' for your perusal.
https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html#3
The last post was made 13 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 37.27 Kb
