My bike has started honking at me wtf?
Wonko The Sane
PostPosted: 07:47 - 08 May 2013    Post subject: My bike has started honking at me wtf? Reply with quote
Didn't do it / notice it yesterday but at 5500rpm my bike seems to be making a noise that sounds like a truck horn in the distance but doesn't do it at any other engine speed.
By holding the revs constant I can make the sound for as long as I can hold the throttle constant.
It's not related to road speed as ive done it in 1st and at motorway speeds.
Any ideas.
Bike has a double bubble screen fitted so wondered at first if it was wind vibration.
The bike did get rained on overnight as I forgot to put the cover on it but don't see how that can have affected anything
DrSnoosnoo
PostPosted: 08:24 - 08 May 2013    Post subject: Reply with quote
I don't know what that could be, have you had a look for any obvious loose screws? Particularly around the screen, that can rattle for me and make some noise.
PostPosted: 08:28 - 08 May 2013    Post subject: Reply with quote
Sounds like something resonating at the engine vibrations at 5500rpm.
DrDonnyBrago
PostPosted: 08:30 - 08 May 2013    Post subject: Reply with quote
Whistling of air through the airbox?
Andyk
PostPosted: 08:31 - 08 May 2013    Post subject: Reply with quote
maybe a dumb question but does it do it when the bikes stationary or just when its moving?
Wonko The Sane
PostPosted: 08:46 - 08 May 2013    Post subject: Reply with quote
Fair question, not sure. I checked if it was road speed related but not if it did it when stood.
Minor differences to yesterday's run.
Rained overnight and bike started out wet
Road was damp
Had a small item of luggage bungee netted to the pillion seat
Had set the alarm off when starting the bike.
McJamweasel
BCF Junkie
PostPosted: 09:53 - 08 May 2013    Post subject: Reply with quote
[quote="Black Sheep"]
That's your answer. Will be the bungee vibrating, kinda like a guitar string.
UnspeedySam
PostPosted: 10:24 - 08 May 2013    Post subject: Reply with quote
Various bits of my ZZR used to rattle at different revs but that was mostly down to half the fairing lugs being snapped/bodged/damaged. I think the bungee strap theory is a good one. Failing that, go and check for loose screws.
MarkJ
PostPosted: 10:28 - 08 May 2013    Post subject: Reply with quote
As posters above have said, sounds like something vibrating/resonating to me. I had a rear fairing that wasn't screwed quite tight enough that used to do it.
Wonko The Sane
PostPosted: 11:10 - 08 May 2013    Post subject: Reply with quote
Makes excellent sense
Will put the bungee on differently and see if I can get a different note Smile
Wonko The Sane
PostPosted: 19:54 - 08 May 2013    Post subject: Reply with quote
just been out to fill up with fuel and found it still does it,
thinking it must just be the plastics.
The last post was made 13 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.27 - MySQL Queries: 15 - Page Size: 69.26 Kb
