Stuck Right Turn Signals
xGingersUNITE...
PostPosted: 04:50 - 09 May 2013    Post subject: Stuck Right Turn Signals Reply with quote
I own a 1995 Suzuki DR125SE, I hit the right turn signals and they both stay solid. I hit the left and they both blink. Do you think that this could be a turn signal relay problem?
Ichy
PostPosted: 05:00 - 09 May 2013    Post subject: Reply with quote
Quite possibly. How long have you owned the bike? Have the turn signals worked before?
Generally, with indicators it is going to be either wrong wattage bulbs fitted, bad earth, low battery, switch or relay. Check the bulbs first and give the fittings a clean.
xGingersUNITE...
PostPosted: 12:31 - 09 May 2013    Post subject: Stuck Right Turn Signals` Reply with quote
I have replaced some of the bulbs, I bought the bike last summer. The turn signals did work then. I removed the relay but I don't know if I should just buy a new one.
Islander
PostPosted: 12:43 - 09 May 2013    Post subject: Reply with quote
If the relay works on the left hand signal but not on the right then it's unlikely to be the relay at fault.
When you replaced some bulbs, were they on the right hand side and did you use the correct wattage? A non-flashing relay tends to indicate (ba-doom tish!) that the bulbs aren't drawing enough current to cause it to operate correctly. My bet is that one or more of the bulbs are too low a wattage on that side.
garth
PostPosted: 12:53 - 09 May 2013    Post subject: Reply with quote
I hear indicators malfunction if the rider doesn't have a soul.
Islander
PostPosted: 13:15 - 09 May 2013    Post subject: Reply with quote
Depends on whether it was lost to a pact with the devil.
xGingersUNITE...
PostPosted: 13:28 - 09 May 2013    Post subject: Stuck Right Turn Signals Reply with quote
I put in a new bulb that was the same as before, The front right bulb died and after that the right side always stayed solid.
Islander
PostPosted: 14:02 - 09 May 2013    Post subject: Reply with quote
Check the front right bulb initially and make sure it's the correct wattage. Then check the rear right bulb for the same if the front is correct. Then if both are correct, check connections and earths on that side. Something isn't drawing enough current to operate the relay.
Non-electronic flasher relays work on the the principle that heating a bimetallic strip will cause it to bend in a given direction (the strip is made of two metals with different coefficients of expansion sandwiched together so that when heated, one side will expand more than the other and force the strip to bend away from the largest expansion). There's a coil wound around it that's in series with the bulbs and one of the relay contacts is on the end of the strip. When the bulbs light up, the current drawn will heat the coil which in turn will heat the strip. When it's heated, it bends and breaks contact which causes it to cool and bend back. The cycle repeats as long as current is being drawn. If there's insufficient current drawn due to too low a wattage bulb being fitted or a poor connection/contact then the strip won't heat up and the relay won't operate.
The relay works the same for both sides and has a single contact. The flasher switch determines which way the current goes - to the left or right side.
xGingersUNITE...
PostPosted: 15:14 - 09 May 2013    Post subject: Stuck Right Turn Signals Reply with quote
Ok I will took into the bulb, that might be it. I bought the Front right bulb from a store. I should buy it directly from Suzuki.
Ichy
PostPosted: 15:32 - 09 May 2013    Post subject: Reply with quote
No, just take a look at one you didn't change and see what is wrote on it. Generally they are 12v 21w BA15S type. You can get these from any car shop.
Islander
PostPosted: 15:40 - 09 May 2013    Post subject: Reply with quote
Yep, this.
Bulbs are generic. As long as they're rated at the correct voltage, correct wattage and have the same fitting, they'll do the job nicely. No need to splurge on potentially expensive OEM stuff at all . Thumbs Up
xGingersUNITE...
PostPosted: 04:21 - 11 May 2013    Post subject: stuck right turn signal Reply with quote
I took out the turn signal relay and It seemed fine inside. I hit the right indicator and it blinks once and then stays solid. I hit the left and It makes a sputtering noise and then blinks normally. I replaced the front right bulb last summer, I didn't know the voltage, could this be a voltage problem?
Ichy
PostPosted: 09:14 - 11 May 2013    Post subject: Reply with quote
Please just check the bulbs have the correct markings. Until you do that no one can help.
xGingersUNITE...
PostPosted: 13:58 - 11 May 2013    Post subject: stuck right turn signal Reply with quote
I did there are no markings on the bulbs Neutral
Ichy
PostPosted: 14:13 - 11 May 2013    Post subject: Reply with quote
it will be stamped into the metal around the base. This is not the correct bulb but does show where they are marked.
https://i.ebayimg.com/t/PACK-10-x-24v-5w-ba15s-149-SIDELIGHT-BULB-RB149-R149-/00/$(KGrHqEOKjME3tI!eMJLBN-hEyQ8D!~~_12.JPG
Scotsman37
PostPosted: 14:54 - 11 May 2013    Post subject: Reply with quote
The cheapest on ebay sold within UK that I could find that matches the part no. of the turn signal relay as found on an oem site
https://www.ebay.co.uk/itm/SUZUKI-GS125-GN-DR-TS-GSX-GSXF-LS-RG-AN-DF-INDICATOR-RELAY-FZ249SD-38610-31X50-/171026120033?pt=UK_Motorcycle_Parts_13&hash=item27d1f37d61
new one
https://www.ebay.co.uk/itm/SUZUKI-GENUINE-RG500-RG250-RGV250-GS550-GS750-GS1000-FLASHER-RELAY-NOS-/300894092525?pt=UK_Motorcycle_Parts_13&hash=item460eaf7ced
Also, just in case you ever need anything else in a hurry being bought new!
https://www.wemoto.com/bikes/suzuki/dr_125_ses_set/95-96/
OEM supplier of parts
https://www.cmsnl.com/suzuki-dr125-1995-ses_model13149/relayturn-signal_3861031x50/
The last post was made 13 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 88.27 Kb
