hornet suddenly lost all power, help!
Shinigami
PostPosted: 20:13 - 10 May 2013    Post subject: hornet suddenly lost all power, help! Reply with quote
Just come off the m62 and the bike has just lost all electrics, trid a charged spare battery I have on me but still nothing.
No dash lights or anything.
Any ideas?
PostPosted: 20:25 - 10 May 2013    Post subject: Reply with quote
Wiring all intact? Main fuse not blown?
Shinigami
PostPosted: 20:34 - 10 May 2013    Post subject: Reply with quote
Nothings melted and the fuses behind the left panel all look fine, Sad sat in the freezing cold waiting for recovery now.
Wouldn't be so bad but ive just travelled 140 miles and its died 4 miles from my destination grr
Islander
PostPosted: 20:39 - 10 May 2013    Post subject: Reply with quote
Check the fuse in the starter relay.
Shinigami
PostPosted: 20:40 - 10 May 2013    Post subject: Reply with quote
Where abouts would that be? Would that effect all of the electrics or just the starter?
Islander
PostPosted: 20:45 - 10 May 2013    Post subject: Reply with quote
All the electrics - its a 40A fuse from memory and its the main fuse.
IIRC it's near the rear brake reservoir. Thumbs Up
Shinigami
Hmm, reckon it could be the reg/rec? It had a knackered one when I bought it which I swapped out. Other battery could be fooked as that was the one in it when I bought it which I switched for a motobatt
Shinigami
PostPosted: 20:48 - 10 May 2013    Post subject: Reply with quote
Hmm that fuse. Plastic cover came off when I tried to pull it but the contact looks fine
Islander
PostPosted: 20:52 - 10 May 2013    Post subject: Reply with quote
It's not always easy to see if a fuse has blown. Have you got a spare fuse that you can stick in there to test it?
ETA it should be a 30A fuse.
Shinigami
PostPosted: 21:07 - 10 May 2013    Post subject: Reply with quote
Not got a spare Sad its a 20 in there though so thats not right for a start!
JUst switched back to the motobatt and the hiss flashing dash light came on for a sec then died again
Islander
PostPosted: 21:15 - 10 May 2013    Post subject: Reply with quote
That tends to suggest the main fuse is intact.
Start checking for loose connections - is the main earth ok?
Shinigami
PostPosted: 21:38 - 10 May 2013    Post subject: Reply with quote
Aye checked everything was connected and gave everything I could get to a good wiggle about.
Looks like multimeter will have to be purchased tomorrow and some testing done. At my mams so all my tools are back at home 140 miles away lol
Islander
PostPosted: 21:41 - 10 May 2013    Post subject: Reply with quote
At least the Honda manual is available for download - the wiring diagrams are nice and easy to follow.
Good luck with it. Thumbs Up
Scotsman37
PostPosted: 22:06 - 10 May 2013    Post subject: Reply with quote
Was it pouring down with rain when it died on you because you may have water in one or more connector blocks of the wiring harness underneath fuel tank that continues on to the ignition because that can cause a short. You need WD40 to spray or similar to drive out the moisture!
Like others have stated replace main fuse just in case its a bad one and you should have really carried a spare set which is usually found in the within the main fuse box too, but at least you will know the next time for the possibility of a faulty/blown main fuse.
these are the fuses found in a hornet 900
Fuse Main fuse 30 A
PGM-FI fu se 20 A
Sub fuse 20 A X 1, 10A X 4
Islander
PostPosted: 22:23 - 10 May 2013    Post subject: Reply with quote
Just for completeness, I've attached the 600 wiring diagram. Thumbs Up
Knacker
PostPosted: 22:36 - 10 May 2013    Post subject: Reply with quote
Sounds to me like reg/rec the wiring plugs melted themselves on my gsxr a couple of weeks ago and lost all power, it would bump start with no lights on but absolutely nothing with them on.
Previous: K1 GSXR 1000
Shinigami
PostPosted: 08:43 - 11 May 2013    Post subject: Reply with quote
Actually, the night before it was pissing down when I was riding, battery was dead in the morning charged it up and it started fine again, looks like the charge from this morning ran out somewhere along the route and due to doing a consistant motorway speed the engine kept firing as the engine cut out when I slowed to give way after leaving the motorway. .
Off to b&q for a meter in a mo, battery is charged again. Will see what happens
Cheers for the help all!.
anthony_r6
PostPosted: 11:07 - 11 May 2013    Post subject: Reply with quote
Sounds like your reg/rec is screwed. It's common on the Hornets. I had to change mine a few months ago. Just wasn't charging the battery and the bike completely cut out several times before I realised it wasn't the battery.
Charge the battery and start the bike and check the output from the alternator to the battery. Should be above 13.5ish at 5k revs. Stick the lights on and such, see it drop, and see if it picks up again.
J.M.
PostPosted: 11:21 - 11 May 2013    Post subject: Reply with quote
Had the same thing happen to me. Rode about 120-130 miles down the motorway, came off, did a few more miles without stopping. Came to stop at a junction and the bike just cut out. No power.
Turns out the battery was as flat as a pancake. Somehow the fact that the bike was in motion must have been keeping it going, but it just couldn't idle.
Anyway, turns out that it wasn't my reg/rec, it was the charging circuit. Wired the reg/rec directly in to the battery and all problems disappeared! I suspect it was due to a leaking earth.
2004 R1 & 2018 XSR900
Shinigami
PostPosted: 12:46 - 11 May 2013    Post subject: Reply with quote
Yup definitely not charging, spare battery was also completely toast at 9v lol.
Put a working battery in and not seeing any increase in voltage with revs.
Will limp it home tomorrow with the 2 batteries, got a reg/rec on order
Shinigami
PostPosted: 12:52 - 11 May 2013    Post subject: Reply with quote
Got a cheap spare battery to get it home tomorrow, cheaper for me to potentially knacker a spare battery than take other transport
Scotsman37
PostPosted: 13:51 - 11 May 2013    Post subject: Reply with quote
Volt meters are always a life saver as they tell you so much what is going on with an electrical device - good going finding out the route of the problem!
Shinigami
PostPosted: 17:32 - 11 May 2013    Post subject: Reply with quote
aye, picked up a pocket multimeter from b&q for £5, actually quite impressed with it, better than my more expensive one at home and much smaller physically, reckon i'll keep it under my seat
ordered a whole new set of fuses too as the ones in it are all over the place amp wise, completely wrong compared to what the label on the fuse box suggests
Shinigami
PostPosted: 19:50 - 12 May 2013    Post subject: Reply with quote
lol. got home on 2 batteries....just.
Stopped outside my garage on the 2nd battery and wouldn't start again as was drained too much.
Gotta wait a couple of days for new reg/rec to turn up
Islander
PostPosted: 20:32 - 12 May 2013    Post subject: Reply with quote
When it arrives, stick some heat sink compound between it and the frame to help with heat transfer. Thumbs Up
The last post was made 13 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 123.34 Kb
