HONDA CBR 2000 won`t Start
Biker1977
PostPosted: 12:01 - 15 May 2013    Post subject: HONDA CBR 2000 won`t Start Reply with quote
Hello everyone
After a long rest in winter, my lovely CBR will not start unless I go for a run and kick start on 2 gear..I have tried leaving it on and I even went for a 15 minute ride to get the battery charged up but no success ..will not start with the button.
Any suggestions please ?
Thank you
Honda CBR1100
P.
PostPosted: 12:03 - 15 May 2013    Post subject: Reply with quote
Have you even bothered charging the battery of getting it checked, batteries die and a short ride won't charge it up, especially if its proper flat.
nowhere.elysium
The Pork Lord
PostPosted: 12:05 - 15 May 2013    Post subject: Reply with quote
I presume you mean bump starting - last I checked, no CBR ever had a kick start.
have you tried removing the battery and plugging it into a battery charger overnight? That's the traditional fix for a flat battery.
DrDonnyBrago
PostPosted: 12:15 - 15 May 2013    Post subject: Reply with quote
Charge the battery.
Biker1977
PostPosted: 07:18 - 16 May 2013    Post subject: HONDA CBR 2000 won`t Start Reply with quote
Thank you so much guys for your reply ,,you wright I meant bump start it ..silly me .. Embarassed
if you let me.. just a last damp question, I looked under seat and I can`t work out how to get the battery out ...how easy it is ? and if there is a video out there specific to this model ( I can t find it so far ) to point out for me that would be great!! ..
Thanks again
Honda CBR1100
DrDonnyBrago
PostPosted: 09:02 - 16 May 2013    Post subject: Re: HONDA CBR 2000 won`t Start Reply with quote
Surprised
Undo the two clips on the battery cover, lift the cover, undo the neg (black wire) terminal first, then the pos (red wire) terminal, lift the battery out....
Biker1977
PostPosted: 11:38 - 16 May 2013    Post subject: Re: HONDA CBR 2000 won`t Start Reply with quote
DrDonnyBrago wrote:
Surprised
Thanks for that.. I am guessing the charger on the link.."Maypole 7416 6A Battery Charger 12 V up to 1800cc
" .. is what I need....half price to Halford`s..so good deal ..I m going for it !!
Honda CBR1100
map
Mr Calendar
PostPosted: 11:52 - 16 May 2013    Post subject: Re: HONDA CBR 2000 won`t Start Reply with quote
You are best getting a charger that either is specific for motorcycles or has a motorcycle battery setting. So that will not be that Maypole 7416 one. As in (from this link)
amazon.co.uk wrote:
...Suitable for cars and vans with petrol engines up to 1800cc (1.8 litres)...
No mention of motorcycles.
Motorcycle batteries need to be charged at a lot lower amps than car batteries. Using a car charger can damage the battery internals. This may not be immediately obvious (you'll just think battery charged). However, you'll find it will not hold its charge and/or life expectancy reduced somewhat drastically.
This is true of the older style with the lead plates. These are small and close together so can easily be warped by too much current. Also true for the gel type as these require specific current charging and can be damaged if not.
If Halfords is your only source you'll need something like this one - click this text for link.
However, there are other and better bike specific kit available. Accumate/Optimate kit is very good. They have specific cycles to handle gel type batteries. Can be had online or from most bike dealers. Even the likes of WEMoto offer a good charger as an alternative. If you're bothered about an alternative cheaper then check out Aldi/Lidl when these things come along in their annual offers.
HTH Thumbs Up
Biker1977
PostPosted: 12:18 - 19 May 2013    Post subject: Re: HONDA CBR 2000 won`t Start Reply with quote
Thanks for the extensive Answer, I ended up ordering Roxter Motorcycle Battery Trickle Charger Motorbike Scooter Optimiser from
Amazon, and I also managed to get the battery out like a big boy Very Happy
Thanks all for the useful advises.
Honda CBR1100
FireStorm-X
PostPosted: 14:14 - 19 May 2013    Post subject: Reply with quote
Bike charger is a must, not a car charger Sad cooked a new bike battery that way already Sad silly me Sad
Lexmoto Street 125 (sold) - Kawasaki ZR7S
Biker1977
PostPosted: 09:11 - 24 May 2013    Post subject: cbr 600 2000 with fully charged battery tempremntal start Reply with quote
Hello thought with the battery charged up starting problem should be gone for at least a while..just after the charge it started well..then when I sopped left it out for few hours (it was raining) it struggled to start ..and then nother ride stop for an hour ..and then I had to bump start ..is it still the battery ?
Honda CBR1100
Ripp3rCrust
PostPosted: 09:33 - 24 May 2013    Post subject: Re: cbr 600 2000 with fully charged battery tempremntal star Reply with quote
How long did you charge it for? Make sure you have left it to charge for long enough, for example, over night.
The battery may be knackered though and not capable of holding a charge (quite common if it is an old battery that hasn't been looked after for long cold periods). Do you have a multimeter that you are able to check its integrity with?
Current: '05 CBR600F - Previous: '01 GSF600S Bandit, '06 XR125
mudcow007
PostPosted: 09:33 - 24 May 2013    Post subject: Reply with quote
volt meter on the battery
the battery might be goosed an not holding a charge?
Biker1977
PostPosted: 12:53 - 24 May 2013    Post subject: battery Reply with quote
I have left it to charge over night..till green came up..which according to charger' manual mean that battery is "ready " I may have something in the back of the draw to check battery with.or maybe I ll go down to halfords..is checking battery easy ?[/img]
Honda CBR1100
Aff
PostPosted: 12:55 - 24 May 2013    Post subject: Re: battery Reply with quote
What are you battery voltage readings?
Less than 12.5 and the battery is probably dead.
If its less than 13.5 when charging then you have an issue in the charging system.
Electric Bike Project
mudcow007
PostPosted: 13:12 - 24 May 2013    Post subject: Re: battery Reply with quote
dead easy, just turn the tester to DC an set voltage range to 20v put each probe on black terminal then red an look at the screen on the tester, take it to any garage they should test it for free though
im guessing your battery is dead an it will accept a charge but then as soon as you disconnect from the charger, the charge dissipates = dead battery
PostPosted: 13:22 - 24 May 2013    Post subject: Reply with quote
To be healthy a battery needs to have sufficient voltage and capacity reserve. A battery charger can report a healthy battery by measuring the feedback voltage but a heavily sulphated battery can have this voltage but no capacity or 'store of energy' to do any work.
If you have used that conventional charger on your battery, then even if it WAS healthy it probably now isn't. It depends on the type of battery.
Yours displays all the signs of the battery being knackered. The tests outlined above can give you a good indication, but if you think your battery is ok you can check the charging system by putting a meter over the terminals and running the engine. You should get somewhere between 14 and 15 volts at the battery at 5000rpm. If you're seeing this, the battery is knackered for sure. If you're not it could be the charging system. 90% chance it's the battery.
Biker1977
PostPosted: 14:16 - 24 May 2013    Post subject: battery Reply with quote
Everything is pointing. To the battery,..If a new reliable battery can do the trick..I ll go for it..can anyone recommend one ? Halford ' s Bosh start from 38 pounds ..
Honda CBR1100
Aff
PostPosted: 14:19 - 24 May 2013    Post subject: Re: battery Reply with quote
Check everything first, but if it is the battery go for a Motobatt or something.
https://www.bitzforbikes.co.uk/Fully_Sealed_Motobatt_Battery_MBTX9U-ref-18022-2056-106.html
whitedevil
PostPosted: 16:39 - 24 May 2013    Post subject: Reply with quote
Test the rec/rec and stator before wiring up a new battery or you may end up killing it. Reg/recs are a common thing to go on Most older Hondas. I had to replace mine on my cbr600 2002
https://www.electrexworld.co.uk/pdfs/Troubleshooting-3P-PMG-&-RR.pdf
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
DrDonnyBrago
PostPosted: 19:07 - 24 May 2013    Post subject: Re: battery Reply with quote
+1 to test the reg rec, then buy a motobatt.
The last post was made 12 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 122.25 Kb
