Cylinder ticking noise
xGingersUNITE...
PostPosted: 02:06 - 16 May 2013    Post subject: Cylinder ticking noise Reply with quote
I took my 125 to 55 mph today and then lost power and it started to make a ticking noise. Now it tops at 35 and still has this annoying noise.
duzzer
PostPosted: 02:34 - 16 May 2013    Post subject: Reply with quote
it sounds like a semi-seize, engines got to hot down to runing lean or no oil in the engine, what make model is your bike and is it 2 or 4 stroke
xGingersUNITE...
PostPosted: 02:50 - 16 May 2013    Post subject: cylinder ticking noise Reply with quote
1995 Suzuki DR125SE 4 Stroke
duzzer
PostPosted: 09:19 - 16 May 2013    Post subject: Reply with quote
my first thing to check is small end n big end bearings for excessive play on the crank. the valves in the head for any bluing on the cam n sticky or bent valve.
also check the bore n piston for any damage like scoring,, also check the oil level
xGingersUNITE...
PostPosted: 19:24 - 16 May 2013    Post subject: Reply with quote
could it be that one of the valves is super loose?
bladerunner
PostPosted: 23:42 - 16 May 2013    Post subject: Reply with quote
Post up a vid showing the noise and it'll help us identify possible causes.
matty67832011
PostPosted: 23:24 - 17 May 2013    Post subject: Reply with quote
piston rings maybe
sickpup
Old Timer
PostPosted: 08:47 - 18 May 2013    Post subject: Reply with quote
Hmm air cooled four stroke making a ticking noise and down on power, thats a hard one.
Head gasket, compression test to be sure.
Ignore all the other suggestions.
The last post was made 13 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 52.96 Kb
