| matty67832011 |
 matty67832011 Derestricted Danger
| at106 |
 at106 Brolly Dolly
| CaNsA |
 CaNsA Super Spammer
| map |
 map Mr Calendar
 Posted: 21:33 - 17 May 2013 Post subject: |
As said above electric start only works if you apply left lever. Microswitch on that may be faulty or not as same must be done if kick starting it.
Actually electric start not needed for MOT. My lad's Varadero just passed and he has to push start that every time. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Ariel Badger |
 Ariel Badger Super Spammer
| matty67832011 |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| matty67832011 |
| Ariel Badger |
| matty67832011 |
 Posted: 22:18 - 17 May 2013 Post subject: |
just give the starter a slap and wire straight from red straight to battery and it worked and started but still not from the button on the bars so should i take that appart and clean or is there anything along the wiring loom between start button and starter motor that i should also check? Any mature help would be very much appreciated
Cheers |
| P.addy |
 P.addy Red Rocket
| matty67832011 |
| P.addy |
 P.addy Red Rocket
 Posted: 22:40 - 17 May 2013 Post subject: |
Not tested so won't fail.
Electric start wires could just be a bit crapped up. You could remove the switch gear and see if its corroded inside, again, you could bodge this but you might want to find out why its not working as intended. |
| matty67832011 |
 Posted: 22:50 - 17 May 2013 Post subject: |
yeah im gonna check switchgear in morning but have been reading up on starter relay and read that if its not the relay the relay should click but then thats actual bolox cos why would the relay click if it doesnt know im pressing the start button pfft what a load of Agro bloody french bikes!
If worse comes to worse and i bodge the starter switch straight to the motor can i cut out the relay or do ya need that there?
im not very good with electrics as u may of guessed lol wtf does a relay even do! :-/
Anyway like i say will check sqitch gear 1st, and yes my rear break light works so it knows im pulling break on.
Cheers for reply pal.  |
| Ariel Badger |
| CaNsA |
 CaNsA Super Spammer
 Posted: 07:12 - 18 May 2013 Post subject: |
The op marked my post as "abusive".
If he thinks being called a retard is abusive, he wont last long. |
| carlosthejack... |
 carlosthejack... World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| carlosthejack... |
 Posted: 07:37 - 18 May 2013 Post subject: |
Just to add to that, and without wanting to be a grammar Nazi, however. Piss poor punctuation and spelling throughout:
I'll
you've
disgusting (and it doesn't need capitalising)
fucking. I mean, who puts fkng other than a total moron?
And what's with the footstamping? Piss off child unless you can respond appropriately without having to resort to something that upsets you without threatening to run off and tell your mum. Cansa's right, nobcat was fully justified and is potentially warranted again in this thread. ____________________ Responsibility. It's a difficult reality for some. I'm running the 2014 Sheffield Half Marathon on behalf of Bluebell Wood Childrens Hospice. Please sponsor me, even if it's just a quid.
Current rides: '05 VFR800 VTEC, '57 Mondeo 1.8 TDCi #58LEGEND |
| Robby |
 Robby Dirty Old Man
 Posted: 12:03 - 18 May 2013 Post subject: |
Trying to pull the issues apart into something clear. Correct me if I'm wrong, this is what I can work out from your somewhat rambling description:
1. The electric start isn't doing anything at all on the button. When you bridge the terminals on the relay, it turns over.
2. The horn isn't working.
Are the horn and start button on the same switchgear unit? Does anything else on that switchgear unit work? If the switchgear unit is totally dead, it could just be disconnected.
Assuming it is connected, you need to get your multimeter out and start checking for continuity along the various wires, and trying a direct 12v feed on some parts.
For the horn, try applying a direct 12v feed across it. Horns do suffer from corrosion and stop working. A strong feed may free it up, try also giving it a hard tap on a hard surface. It may sound like a duck's fart at first, but a few operations will free it up.
For the starter, the relay is suspect. Again, give it a hard knock then a strong 12v feed. A car battery is worth trying.
Make sure the scooter battery is fully charged for all work.
In short, some bits may have seized up a bit. The application of a little percussion and a strong electrical feed should free them up, then repeated use should get them working reliably again. |
The last post was made 13 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
