Bit of a spring clean
Davenaylor
PostPosted: 17:02 - 18 May 2013    Post subject: Bit of a spring clean Reply with quote
I walked into the house last night and the wide was watching Vampire Diaries Thumbs Down Thumbs Down Thumbs Down
So I walked out again and got to work on my front sprocket. I hadn't looked at it since buying the bike and riding it through winter and i was fairly certain it would need a clean Confused
So went from this;
https://imageshack.us/a/img854/1227/photo1lf.jpg
Uploaded with ImageShack.us
To this;
https://imageshack.us/a/img805/865/photo2ed.jpg
https://imageshack.us/a/img850/9382/photo3dst.jpg
I gave the inside of the sprocket cover a really good clean. The clutch mechanism was caked in crud and now its all nice and clean.
One thing i didn't do was lube any of it after i cleaned it. Should I have?
Also, on the last pick there is a rod sticking out circled. What is it? it was covered in what i can only describe as thread or cotton. Its now cleaned back to bear metal. Does that need greasing?
2 hours well spent if you ask me.
Thanks.
Davenaylor
PostPosted: 19:42 - 18 May 2013    Post subject: Reply with quote
Thanks,
I figured it was something to do with the clutch or gear box but i can quite fathom how pulling up on the clutch cable makes something that is 90 degrees to it, go in.
its voodoo i tell yee
trevor saxe-coburg-gotha
PostPosted: 20:50 - 18 May 2013    Post subject: Re: Bit of a spring clean Reply with quote
Bet she loves you calling her that. Mr. Green
PostPosted: 20:51 - 18 May 2013    Post subject: Reply with quote
That front sprocket is FOOKED!
Davenaylor
PostPosted: 21:11 - 18 May 2013    Post subject: Reply with quote
It's not. It's the camera on my phone with a dodgy focus. I checked the sprocket carefully. That was the point in me taking the cover off in the first place.
She loves being called wide Embarassed
So, do I need to lube these ball bearings jobby wotsit doodaas
Ta
Commuter_Tim
PostPosted: 21:14 - 18 May 2013    Post subject: Reply with quote
Davenaylor wrote:
Thanks,
Was it difficult taking that case cover off and putting it all back together again?
I only ask as when I clean my chain, the moment the chain runs back through the front sprocket housing it gets shitty and dirty again, that cant be a good sign right? Shocked
I ride a Bandit 600... badly.
mysterious_rider
PostPosted: 21:31 - 18 May 2013    Post subject: Reply with quote
I tell you one thing mate if you pulled that rod out and pushed it back in without oiling it you will have broken the seal.
I was gentle with mine, and the sod still leaked like mad.... Gs500 I assume?
Keep an eye on the bottom of the case for oil. In bad cases it will run onto the shifter.
KAWASAKIIIII
Davenaylor
Commuter_Tim wrote:
Davenaylor wrote:
Thanks,
It was a piece of piss. The bolts were quite stiff though and they are different lengths from the different places they came from. So I just laid them out on the floor the way they came out.
On my bandit you have to be careful you know the angle of the dangle for the gear changer arm. I marked the alignment of mine before I took it off. There is a speed sensor cable (I think) that I had to be careful not to trap when it went back on.
I went to town with WD40 to clean the inside. By the sounds of it, you need to do the same!
Davenaylor
PostPosted: 21:35 - 18 May 2013    Post subject: Reply with quote
I didn't push by hand but I did operate the clutch. Isn't there oil on the inside? What I mean is the gear box is soaked in it?
mysterious_rider
PostPosted: 21:37 - 18 May 2013    Post subject: Reply with quote
If you didn't pull it out and clean it you are fine. Take it out, clean it, oil it, insert VERY gently.
yeah there is oil behind there (well when the engine runs at least)
KAWASAKIIIII
Commuter_Tim
PostPosted: 21:41 - 18 May 2013    Post subject: Reply with quote
Cheers man, I've got a proper torque wrench now so may aswell use it.
No worries on the removing and adjusting the gear lever foot pedal though, I've pulled my bloody hair out in frustration over the course of days adjusting that thing last time I got new boots, I'm practically a pro at that now Thumbs Up
There is also some kind of weird glue along some of the seal around my case cover, anybody know whats up with that? Confused
Davenaylor
PostPosted: 21:51 - 18 May 2013    Post subject: Reply with quote
Any idea why it was wrapped in what can only be described as thread?
MattJ
PostPosted: 21:58 - 18 May 2013    Post subject: Reply with quote
This has just reminded me that I need to clean there on my bike. Thanks Thumbs Up Laughing
The last post was made 12 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 79.24 Kb
