Needed - Kawasaki Generator Puller
yambabe
PostPosted: 20:02 - 29 Nov 2004    Post subject: Needed - Kawasaki Generator Puller Reply with quote
Anyone know where I might be able to beg, steal, buy or borrow one from?
All suggestions gratefully received.
Guest
PostPosted: 20:48 - 29 Nov 2004    Post subject: Reply with quote
You'll often find that one of the engine mounting bolts is the correct thread. Just screw it in tight and give it a sharp tap wi th'ammer. Then re-tighten and bash again.
Have something soft underneath to catch it when it flys off Wink
cagiva gezzer
PostPosted: 20:57 - 29 Nov 2004    Post subject: Reply with quote
Or by a cheap harmonic puller from www.machinemart.co.uk
PostPosted: 10:43 - 30 Nov 2004    Post subject: Reply with quote
Got one somewhere in the garage which I can probably lend you. Not 100% certain it will fit a particular bike (it was bought 15 years ago from Kwak, so maybe they have changed the thread sizes).
It is a very crude device. 4 different threaded bars, to you put the right one in place then belt it with a mallet.
Note that the bolt holding the rotor onto the crank often has a reverse thread Embarassed .
yambabe
PostPosted: 02:44 - 06 Dec 2004    Post subject: Reply with quote
Thanks Keith, but Himself seems to think it probably won't do. I have taken some photos of the offending "bit" today, this is what we need to fit........
yambabe
PostPosted: 02:50 - 06 Dec 2004    Post subject: Reply with quote
Damn, pic is too big and not got photoshop on this pc! Will try again tomorrow.
yambabe
PostPosted: 23:59 - 06 Dec 2004    Post subject: Reply with quote
The pic will probably be too small now.... Rolling Eyes
yambabe
PostPosted: 00:00 - 07 Dec 2004    Post subject: Reply with quote
That's more like it! We just can't find anything the right size to do the job.
PostPosted: 14:22 - 24 Dec 2004    Post subject: Reply with quote
Whoops, forgot.
Anyway found it so here it a picture:-
https://www.alfa-pages.co.uk/TempPicture/kawasaki_flywheel_puller.jpg
Basically you put it into the flywheel and then smack one of the arms with a mallet. Frees them off quite quickly.
The last post was made 21 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 61.53 Kb
