CG 125 strange seal around gearbox
Commuter_Tim
PostPosted: 13:38 - 19 May 2013    Post subject: CG 125 strange seal around gearbox Reply with quote
There is a rubber seal around the joining edge of my gearbox.
Does anybody know what this seal is, and if it should even be present?
I have not seen it on other CG's
I was about to take the cover off to clean it, but whatever that seal is, if required I dont have more so im hesitant to take it off now. Sad
Im just taking some pictures now then ill sign up for a photobucket account.
I ride a Bandit 600... badly.
Commuter_Tim
PostPosted: 16:50 - 19 May 2013    Post subject: Reply with quote
So yeah heres a shot of the rubber sealant along that edge, is this normal or has someone bodge jobbed it?
https://i1274.photobucket.com/albums/y439/Timothyallen85/IMAG0149_zps2fb2cb06.jpg
Walloper
PostPosted: 18:25 - 19 May 2013    Post subject: Reply with quote
It looks like Silicon gasket compound.
Commuter_Tim
PostPosted: 18:41 - 19 May 2013    Post subject: Reply with quote
Ah, do you think I can remove this cover without replacing that sealant? or am I best off finding a proper seal for it?
Walloper
PostPosted: 18:46 - 19 May 2013    Post subject: Reply with quote
It is probably one of the vague areas some manufacturers build into their shit. It is quite normal for some places to use a sealant rather than a gasket/seal due to the design.
You can get suitable sealant from Halfords or some place.
DMCpro
PostPosted: 06:28 - 21 May 2013    Post subject: Reply with quote
What side is it? If its the generator side there is no need for a gasket atall
Honda CB-1, TS125X
VW Golf Estate
Cyclingbiker
PostPosted: 07:20 - 21 May 2013    Post subject: Reply with quote
DMCpro wrote:
What side is it? If its the generator side there is no need for a gasket at all
Looks like it, that plate with the bolt through it on the left looks like the base of the cylinder. If so that is the generator cover and doesn't have any form of gasket fitted as standard, there is an oil seal inside but it is part of the stator plate itself. Maybe someone has put that around there as a water seal Confused
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
Commuter_Tim
PostPosted: 08:33 - 21 May 2013    Post subject: Reply with quote
Since I'm too stupid to know which the "generator" side is, it's the sprocket/gear side.
I bought some new silicone sealant from amazon so once it arrives, I shall attempt to remove it and see what kind of mess is inside.
mudcow007
PostPosted: 09:02 - 21 May 2013    Post subject: Reply with quote
Sprocket side, doesn't need a gasket
in front of the drive sprocket is the flywheel, behind the flywheel is the generator
Commuter_Tim
PostPosted: 00:59 - 26 May 2013    Post subject: Reply with quote
Thanks again for all the help.
To avoid creating another thread, I took the cover off, but and it seems to have cleared up some stuff, I can see the gasket in this case is a shitty, soggy piece of green cardboard, with a bit missing, hence the silicone sealant, which I have purchased.
I'm assuming its to keep those electrical cables dry, whatever they're for...
This is after I brake cleanered the shit out of all inside the sprocket housing to remove the black stuff, but the sprocket nut thing in the centre of the 2 silver bolts appeared like it may have had some kind of lubricant/grease underneath all the dirt.
Is this supposed to be there or was it just gunk and it is a dry component?
https://i1274.photobucket.com/albums/y439/Timothyallen85/IMAG0176_zpsdb360e7d.jpg
cb1rocket
PostPosted: 09:40 - 26 May 2013    Post subject: Reply with quote
that is the sprocket and genny cover side. No it doesn't need a gasket although Honda made one anyway to purchase.
Front sprocket doesn't need any grease, its all oiled when you oil the chain.
Commuter_Tim
PostPosted: 14:32 - 26 May 2013    Post subject: Reply with quote
Ah many thanks!
The last post was made 12 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 81.45 Kb
