aprilia rs 50 HELP
cmoy57000
PostPosted: 19:11 - 19 May 2013    Post subject: aprilia rs 50 HELP Reply with quote
hi i brought this bike and the only problem is when i turn the key off it dosen't kill the engine but when i looked at the coil box where there is some wires and there one with stop just wondering if anything one could help me out
thanks Smile
Cmoy
PostPosted: 20:28 - 19 May 2013    Post subject: Re: aprilia rs 50 HELP Reply with quote
cmoy57000 wrote:
hi i brought this bike and the only problem is when i turn the key off it dosen't kill the engine but when i looked at the coil box where there is some wires and there one with [what?] stop just wondering if anything one could help me out[missing period]
thanks[missing period] Smile
Happy to help.
<dis-gun-be-good.gif>
cmoy57000
PostPosted: 20:39 - 19 May 2013    Post subject: aprilia rs 50 help Reply with quote
hi Rogerborg i have sent you a pm message
Cmoy
Fnatic
PostPosted: 00:10 - 20 May 2013    Post subject: Re: aprilia rs 50 help Reply with quote
Hi,
Assuming you have the AM6 engined RS50 which is any RS50 pre-MY06 I believe, then it is but a simple solution. If you are not familiar with the process of bump starting a car or motorcycle then I suggest you do this now.
What you need to do is to put the bike in first, pull the clutch in and instead of bumping it forwards, push the bike backwards before releasing the clutch in order to turn the engine over. This should fix all of the issues you stated above.
All the best,
Keith.
reed
PostPosted: 00:32 - 20 May 2013    Post subject: Reply with quote
If you have the RS50 from pre 2007, it may also be a good idea to have someone else push you backwards as you may not get enough speed by yourself.
This is due to the huge compression that is found on a post 2007 engine.
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
Fnatic
PostPosted: 02:57 - 20 May 2013    Post subject: Reply with quote
Thinking about it now, it could actually be a port polishing issue. I'd suggest feeding sand in through you air intake meanwhile running the engine. You have to do this at the engine side of the air filter or else it won't get through.
It essentially acts like sandpaper and polishes your cylinder and piston, allowing it to run more efficiently. It is the best upgrade you can do for less than a few hundred pounds, other than a powerband upgrade obviously.
Ariel Badger
PostPosted: 06:52 - 20 May 2013    Post subject: Reply with quote
If that is all that is wrong with it then it is not an Aprilia.
Knacker
PostPosted: 07:21 - 20 May 2013    Post subject: Reply with quote
I think what this forum needs is a help/garage section so that General chat doesn't end up with thousands of broken bike threads.
Rolling Eyes
Previous: K1 GSXR 1000
PostPosted: 07:29 - 20 May 2013    Post subject: Reply with quote
I almost regret deleting that PM unread now...
OK, OP:
Does it start with the ignition turned off?
Does it exhibit the bad behaviour if you turn the ignition off shortly after starting up, or does it only do it when the engine is hot?
When you bought it in a pub car park for cash with no V5, was there a screwdriver in the ignition barrel?
Linux
PostPosted: 23:42 - 20 May 2013    Post subject: Reply with quote
Why are you all giving him the wrong advice?
It's a 50cc not a 125cc, the sand goes in the petrol tank.
Two wheels are all I need.
The last post was made 13 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.09 - MySQL Queries: 13 - Page Size: 65.49 Kb
